Subwoofer box option
Discussion in 'Audio & Video' started by claysae12, Jan 7, 2016.
  1. Jan 7, 2016 at 12:33 PM
    claysae12
    claysae12 [OP] Active Member
  2. Jan 8, 2016 at 10:00 AM
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
    I am curious also. If I didn't just buy MDF to build a box I would buy this one. It does look like you have to cut the rear panel at the bottom to make it fit.
  3. Jan 8, 2016 at 3:32 PM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    ‘Berta
    06 Rad Red DCLB SR5, ‘25 SS Red Sport Prem. (on order)
    ********* has a very questionable reputation around these parts. You may get what you ordered in no time, or it could take 6 months. There's no communication or information given when items ship. I would go to SuperCrewSound.com to source a box first. They have very quick turnaround, and the boxes are top notch.
    claysae12[OP] likes this.
  4. Jan 8, 2016 at 5:02 PM
    tacotunesJosh
    tacotunesJosh Well-Known Member
    Joshua
    Tundra
    System
    @claysae12 hey buddy
    That box goes well behind the seat in the 05-11 body style. Just need to remove a couple things so it can fit perfectly.
    We're good in stock so it can be shipped out and on your way the day after you order it.
    Any questions I can answer at Tacotunesjosh@gmail.Com
  5. Jan 9, 2016 at 10:46 AM
    claysae12
    Thanks Josh and appreciate your assistance in resolving a previous order issue so promptly. How does this box fit in the 2014 model?
  6. Jan 9, 2016 at 1:33 PM
    tacotunesJosh
    Joshua
    Tundra
    System
    @claysae12
    No problem at all. And same thing for the 2014 model just needa remove a couple peices on the back wall.
  7. Jan 11, 2016 at 11:55 AM
    hyper15125
    NJ (609)
    Can you be a little more specific as to WHAT has to be removed? Does the panel require being cut & DOES THE PLASTIC HAVE TO BE TAKEN OFF OF THE BACK SEAT?
    I have an MB Quart DS1-254 10" shallow mount I would like to utilize.
  8. Jan 13, 2016 at 2:13 AM
    hyper15125
    NJ (609)
  9. Jan 13, 2016 at 5:47 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Not the source, but I believe the child anchor(s) need to be removed. As for the seatback plastic, depends on the sub you get and it's actual excursion.
  10. Jan 14, 2016 at 2:15 AM
    hyper15125
    NJ (609)
    Thank you! I did remove the one anchor on the drivers side already for the box I am building. I don't want to hack the back of the truck up to fit a sub in, I want to keep the stock look. If that doesn't work out I may try the TT box, however, the statement above by ZMan2k2 comes into question.
  11. Jan 14, 2016 at 5:00 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    My only advice is do some searching and reach your own opinion on TT, it seems they are hit and miss, not sure if they are moving forward or same ol', same ol'.
    BTW, I bought a Supercrewsounds double sub box and cut one sub box off to make a sub box + amp board that fits on the passenger side. Leaves the driver's side bin in place.
    Lastly, if you want a total quality box and are willing to pay a bit more, talk to MrMarv. He will also help you get a sub in their that fits your needs.
  12. Jan 14, 2016 at 8:44 AM
    ZMan2k2
    Richard
    ‘Berta
    To fit the box, you don't need to remove child anchors. You do need to remove one or both storage bins back there, depending on which side you're putting the sub box on. There is a piece on the longer storage box, that may or may not need to be cut off, it's the piece that snaps the two storage boxes together. Not a big deal, just a sharp knife and you're done. You don't have the JBL system, so you don't need to worry about the stock sub or amp.
    As for TT, do your due diligence. Research here on the site, read the reviews and such. I went with SuperCrewSound.com when I got my first double box, they shipped to Canada via UPS, packed it great, and it was a solid box. I've since stepped up to 12" subs, so I had to custom make my box. But they were great.
  13. Jan 14, 2016 at 1:53 PM
    tacotunesJosh
    Joshua
    Tundra
    System
    @hyper15125 with this new enclosure all you need to remove is the plastic behind the seat and the foam pad.
    it is secured with only 3 10mm bolts. takes no time at all to install, just slip it in and anchor it. also advise to take the plastic that's attached to the back of the seat off (to keep vibrating to a minimum)
    -josh
  14. Jan 14, 2016 at 4:22 PM
    hyper15125
    NJ (609)
    Thank you for the response!
  15. Jan 14, 2016 at 4:23 PM
    hyper15125
    NJ (609)
    Much appreciated thank you.
  16. Jan 14, 2016 at 4:23 PM
    hyper15125
    NJ (609)
    Thanks
