Subwoofer boxes
Discussion in '3rd Gen. Tacomas (2016-2023)' started by chealy86, Nov 21, 2015.
  1. Nov 23, 2015 at 1:31 PM
    chealy86
    chealy86 [OP] Well-Known Member
    South Carolina
    2016 SR 2.7L 6spd
    The jl stealth box with sub is about $700....
  2. Nov 23, 2015 at 1:31 PM
    garyinok
    garyinok Well-Known Member
    Gary
    Yeah I just read that again and I think you are right. No it was the replacement cost of those two plastic bins. Anyway yes those two things on the back wall are just vents. They have little rubber flaps that act kinda like a check valve. The fan is the main AC/Heating fan. When you set the AC or heat to draw air from the outside the little rubber flaps go wide open and push air out the back of the cab. If you push the button on the dash to recirculate the air the vent flaps go closed. When I taped them off to see what would happen and ran the defrost what I figured out was I got almost no air flow. The cabin is now pressurized by the fan and it can't push in any air from the outside. Then the fan starts to get hot. Not good. So I ended up opening them back up.
    Here is the link to the build. I just started posting some stuff since I just finished it yesterday.
    https://www.tacomaworld.com/threads/2016-tacoma-double-cab-audio-install-build.402547/
  3. Nov 23, 2015 at 1:45 PM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    thx man
    yikes!!!!!!!!
