Subwoofer help needed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Jan 26, 2017.
  1. Jan 26, 2017 at 9:43 PM
    nevadabugle
    nevadabugle [OP] Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    Disclaimer: I am not an audio geek. Nor do I want to be one.
    All I want is more bass on my non JBL entune radio.
    Can you all help me achieve that with a limited budget and no stereo knowledge. Can I simply add a sub woofer to the stock system? And please do not refer me to some $500+ system. I simply want more bass and to keep the stock speakers I have.
  2. Jan 26, 2017 at 10:57 PM
    Oldman808
    Oldman808 Well-Known Member
    Planet Earth
    2023 Taco TRD Sport
  3. Jan 26, 2017 at 11:31 PM
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    You will need some sort of line converter to splice into the stereo harness to get rca outputs To the amp for a sub, if you dont feel comfortable splicing into the stock wireing harness for the headunit you will want to get a plug and play t harness similar to the crux one for around 100$, splice in the line converter to the t harness so it is 100% reversible if needed for warranty etc. At this point you can also add the backup cam anytime mod. For the t harness check the latest bcam thread.
  4. Jan 26, 2017 at 11:32 PM
    COskimtb
    COskimtb Well-Known Member
    2016 Tacoma OR 4X4 DCSB 6MT MGM
  5. Jan 26, 2017 at 11:34 PM
    Broccoli
    Airdrie Alberta
  6. Jan 27, 2017 at 12:10 AM
    Shadowray
    Shadowray 3rd Gen back to 2nd Gen...
    Arkansas
    2012 Tacoma TRD Sport
  7. Jan 27, 2017 at 3:10 AM
    Mr-Paul
    Mr-Paul Well-Known Member
    Paul
    2017 Qucksand Tacoma SR5 4x4 V6 Access-Cab
    I installed a Rockford-Fosgate PS-8 under the seat in my non-Entune Access Cab last weekend. It sounds great and filled the low-end in the stereo system. 8 inch driver with 150 watt RMS amp.
  8. Jan 27, 2017 at 4:47 AM
    OverIt
    OverIt Well-Known Member
    Brandon
    NOVA
    2017 DCSB TRDOR 6MT
    Did you put it under the driver's side or passenger? Did you lose any seat movement?
  9. Jan 27, 2017 at 5:29 AM
    Mr-Paul
    Paul
    I installed it under the driver's seat. There was no loss of seat movement at all.
    It gives a nice rumble on the driver's side. I have also sat in the passenger seat, and you do notice less felt bass. It is a small subwoofer and feels directional in the small access cab cabin. I have a large sub system in the back of my Grand Cherokee and it gives non-directional bass since it is in such a large cabin space and it is far away from you in the driver's seat. There is no way to get around the directional felt bass in the access cab, unless you install a second unit under the passenger seat (which is something that I am considering).
    ANY 8-inch sub is NOT going to rattle your teeth by an stretch of the imagination since it is small travel driver; but is does give a nice well-rounded, full sound to the factory stereo !!!
    The PS-8 cost me $300 and I installed it myself. Since the factory head unit does not have RCA outputs, it took 3 hours to trace & tap the wiring, and I know what I am doing when installing radio systems. I estimate it would cost $200 for professional installation.
    OverIt[QUOTED] likes this.
  10. Jan 27, 2017 at 5:40 AM
    OverIt
    Brandon
    NOVA
    2017 DCSB TRDOR 6MT
    Thanks, I appreciate the feedback! I've already got an Alpine PWE-S8 from my last car that's almost the exact dimensions of the PS-8 you put in, and when doing my stereo install, I tried putting it under the passenger seat with no luck. Granted, it was at the end of the day, and I was exhausted from installing everything else, so I didn't put a whole lot of effort into it. I would run out and test fit myself, but I don't have a garage (or a driveway for that matter), so I have to install everything at a buddy's house. Looks like I'll need to find some time to get back over there and give it another go.
  11. Jan 27, 2017 at 5:48 AM
    nevadabugle
    Elko, NV
  12. Jan 27, 2017 at 5:49 AM
    Mr-Paul
    Paul
    The PS-8 design has an arched top, so the front and back are lower in height than the center, so it fit with no problem. If the entire case was 3 1/8 inches tall, I would think there would be fitment problems under the Tacoma seats!
  13. Jan 27, 2017 at 5:50 AM
    Mr-Paul
    Paul
    The non-Entune radio does NOT have RCA outputs, so you need to splice into the factory wiring harness.
  14. Jan 27, 2017 at 5:54 AM
    nevadabugle
    Elko, NV
    So how does the crux harness mentioned above help splicing into the head unit?
  15. Jan 27, 2017 at 6:01 AM
    Mr-Paul
    Paul
    I did not know about the Crux harness adapter when I did my installation. I wish I knew about it before I did my install. It looks like it is an extension that plugs in between your head unit and the wiring harness. It should work fine, but I can't personally verify it. I would buy it, if I would have to do it again!
  16. Jan 27, 2017 at 6:09 AM
    minium
    minium Well-Known Member
    2017 Inferno Tacoma TRD Off Road
    Do you mean non-JBL or non-Entune?
  17. Jan 27, 2017 at 6:10 AM
    Expl_eng
    Expl_eng Well-Known Member
    Anthony
    NC
    Black 2016 4x4 DCLB Sport
    Black Pro clone/Kicker Audio/wet okole covers
    I have this installed behind the rear passenger seat. I'm out of town or I'd add a pic. It's a powered sub that does have rca input. I added an LC6i and kicker amp.
    I'm not a big audio guy and this adds plenty of bass. I've actually turned the bass down, since install.
  18. Jan 27, 2017 at 6:13 AM
    Normagene
    Normagene MUTANT TACO
    New England
    Just read about these tho I'm not sure how good they work for bass. You'd probably have to look into the butt implant ones for a better base sound.
  19. Jan 27, 2017 at 7:09 AM
    nevadabugle
    Elko, NV
    I wonder if I installed the crux harness can I hook up a sub with it and still use it as a phone mirroring set up? I've been wanting to get it for phone mirroring anyway so this might be a good option.
  20. Jan 27, 2017 at 7:13 AM
    goose443
    goose443 Well-Known Member
    Austin
    Texas
    2016 Tacoma TRD Off Road 4x4
    Does anyone have a link to the Crux adapter? I checked their website but I'm not sure which one it is. Also, will the adapter allow you to simply plug in an added amplifier without having to splice anything? Thank you
