Subwoofer help needed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Jan 26, 2017.
  1. Jan 27, 2017 at 7:14 AM
    AngryOscar
    AngryOscar Well-Known Member
    Ben
    Sumter SC
    2016 Silver Tacoma TRD OR Manual
    nevadabugle[OP] likes this.
  2. Jan 27, 2017 at 7:33 AM
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    Yes it can be used for adding rca and mirroring.
    I posted the link on the first page
  3. Jan 27, 2017 at 8:44 AM
    nevadabugle
    nevadabugle [OP] Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    OK. I looked around a bit and see how to install the crux Harness and hook my phone up for screen mirroring with the A/v outputs and adapter. But how exactly do I connect a sub to the crux adapter?
  4. Jan 27, 2017 at 9:04 AM
    Broccoli
    Airdrie Alberta
    You will need to splice into the crux harness with some sort of line output converter this will take signal from left & right side of the truck into a rca male plug. From there you will run rca to a amp and from the amp to the sub. I am not a stereo guru but i am quite electrically inclined.
    If the speaker outputs are on the main plug on the headunit this will be the way to go, if the speakers are connected on a different plug i do not think the crux harness will work for you. I would need a picture of the back of the headunit and the wireing info.
  5. Jan 27, 2017 at 10:23 AM
    Broccoli
    Airdrie Alberta
    a quick google showed me that the speaker wires are infact on a different plug. So the crux will not work. And you will have to splice to factory wire.
    nevadabugle[OP] and goose443 like this.
  6. Jan 27, 2017 at 12:29 PM
    goose443
    goose443 Well-Known Member
    Austin
    Texas
    2016 Tacoma TRD Off Road 4x4
    Thank you for all of your help! I think the most feasible option for me is the OEMaudio plus system even tho it is kind of pricey...
  7. Jan 27, 2017 at 12:43 PM
    Broccoli
    Airdrie Alberta
    Honestly from reading and talking With other forum members this seems to be the way to go, great reveiws and install is pretty self explanatory.
  8. Jan 28, 2017 at 11:35 PM
    Oldman808
    Oldman808 Well-Known Member
    Planet Earth
    2023 Taco TRD Sport
    Worth the price big time!
    goose443[QUOTED] likes this.
