Subwoofer Performance Question
Discussion in 'Audio & Video' started by DavidS, Mar 24, 2012.
  1. Mar 24, 2012 at 8:57 PM
    DavidS
    DavidS [OP] Well-Known Member
    Dave
    Pacific Northwest
    2012 Tacoma TRD Sport
    I'm planning on installing a small powered subwoofer (Sound Ordnance™ B-8PT) behind the passenger seat on the driver side. In most cases, I expect I will not have the seat folded down while driving.
    Is the performance of the sub impacted by not having the seat folded down? I may be out of my mind, but intuitively, it seems like having the seat up would be blocking the sub. If there is some performance drop, roughly how much of a difference would it be?
  2. Mar 24, 2012 at 11:33 PM
    AJ4X4
    AJ4X4 Well-Known Member
    White 2010 TRD Off Road Double Cab
    I dont know much about this but I've read on here that bass is a non directional sound therefore something can be in between you and the sub and sound the same as if there was nothing between you and the sub.
  3. Mar 24, 2012 at 11:35 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    True bass is felt, not heard.
  4. Mar 25, 2012 at 12:52 AM
    Norton
    Norton Senior Member
    Monument, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C, OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; aFe POWER Magnum FLOW Pro DRY S Air Filter; NSB-AGM27F Battery w/Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Cooper Discoverer A/T3s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; MetalMiller TRD Skid; jsi's Locker Anytime & ramonortiz55's Always on Power Outlet Relay Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades (RallyLights Harnesses, Osram 85/80W H4 & Flösser 90W H11 Bulbs); mattgecko's Underhood Lighting; ND4's Fog Light Anytime Mod; Interior & Reverse LEDs; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; 4Runner 4X4 & FJ Fog Light Switches; Husky Floor Liners; UltraGauge EM; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Toyota Bed Extender; Pop & Lock Power Tailgate Lock; ARE Z-Series Cap, SolarGard Tint; BlendMounted BEL Vector 995; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    This ^^.
    FWIW, I installed my B-8PT under the driver's seat of my truck and am very pleased with the result.
  5. Mar 25, 2012 at 12:55 AM
    FoundOffRoadDead
    FoundOffRoadDead whiptastic handling
    Shamus
    Walnut
    Ford
    Seat up of down does matter. What you hear is compressed air it also depends on the box you have and or using. Get a ported box.
  6. Mar 25, 2012 at 1:01 AM
    Norton
    Monument, CO
    The B-8PT is a self-contained unit. No box is required.
  7. Mar 25, 2012 at 8:37 AM
    DavidS
    Dave
    Pacific Northwest
    I've been thinking about this all night... If the seat is folded up, there isnt a free path for the compressed air of the subwoofer to follow. The seatback equates to putting your hand on the sub when it is playing. By my logic, the seatback MUST be muffling the sub.
    In almost every build I've seen, the plastic storage bins are removed. I haven't seen it discussed, but one of the reasons must be to create an opening up by the headrest.
    This might all be obvious to many of the veterans to this forum, but I'm pretty new to all this. I'd love to hear what you all think.
  8. Mar 25, 2012 at 10:12 AM
    t4daddy
    North Alabama
    The plastic bins are removed in order to have a box with enough volume for the woofers. If your mind was already made up, and not willing to take peoples advice or thoughts, why ask the question in the first place?
  9. Mar 25, 2012 at 11:52 AM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    I can't comment on this exact situation dealing with your truck, but I had a 10'' pioneer in my old saturn and it sounded a hell of a lot better when I had the back seat folded down. So I think you would notice a difference in sound with the seat folded up. If the sub was really powerful it wouldn't make a difference, but mine was only 150w rms so it didn't have the power to get through the back seat...:notsure:
  10. Mar 25, 2012 at 11:55 AM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    If you keep the high pass of the sub around 90Hz you won't be able to locate the sub in the cabin and I don't notice any difference in performance when my seat backs are up or down.
    Edit: I should add that I have 2 8'' Polk Audio MM840's behind the rear seat of my '01 double cab.
  11. Mar 25, 2012 at 12:11 PM
    t4daddy
    North Alabama
    Zackly, one should not even be able to tell from which direction bass is "coming" from.
  12. Mar 25, 2012 at 2:01 PM
    DavidS
    Dave
    Pacific Northwest
    My mind isn't made up. I'm also considering installing the sub under the driver seat. However, this isn't my first choice because the fit looks pretty tight and I expect passengers would kick it from time to time.
    My preference is to simply install it behind the drive side passager seat without removing the plastic bin. There is actually plenty of room inside the bin, which brings me back to my original question. I'm wondering if the subs performance will be compromised if the seat is folded up. Based on some comments, there may be a problem, while others don't see an issue. The verdict is still out and I'm grateful for all the comments.
  13. Mar 25, 2012 at 2:12 PM
    udy2554
    udy2554 NORTHERN RED-NECK
    Naples, NY
    '06 Tacoma TRD Sport
    Toytec ULK, Light Racing UCA's, OME Dakar rear leaves, ARB Bumper with XRC8 winch, Good Year Duratracs 285/70/17's on 17x9" Level 8 Strike 6's. Leer cap in the winter. Pioneer Double Din with BT, iPod, etc. Boston Acoustic components in all 4 doors with a Sony amp, powered 8" sub. Ultra gauge, Tom Tom...
    How did you get that under the seat? I have an amp under the driver's side, so I was going to install my B-8PT under the pass. side, but I think the bars under the seat hit it.
    Pics would be awesome if you can do it.
    Sorry for the hi-jack!
  14. Mar 25, 2012 at 2:55 PM
    DavidS
    Dave
    Pacific Northwest
    Yeah, what is the deal with that bar? Why only on the passenger side? I've read somewhere about people taking it out or flipping it upside down so it doesn't get in the way.
  15. Mar 25, 2012 at 3:14 PM
    udy2554
    Naples, NY
    Good idea...I think. I'll have to go investigate. I thought I searched pretty well, but maybe I'm slacking!:eek:
    Right now mine is just wedged in behind the drivers rear jump seat.
  16. Mar 25, 2012 at 4:19 PM
    Norton
    Monument, CO
    Been doing yard work all day, so just seeing your request for pics now. (Sorry.) Will try to take some in the next couple of days. In the meantime, I note that you're in a 2nd Gen. The seat configuration MAY be different than my 1st Gen, because the B-8PT fit under my driver's seat like it was made to go there.
  17. Mar 25, 2012 at 4:39 PM
    udy2554
    Naples, NY
    Oops, didn't notice you're a 1st gen. On my 2nd gen., there is a bar across the bottom of the seat that prohibits the sub. from fitting there. I actually concidered install some 1" square tube under the seat mounts. I just didn't know if a side impact might tear them free with the added leverage. An actual box might need to be built to do what I'm thinking.:notsure:.
    Sorry again for the hi-jack, I'll check these thoughts in other threads.:thumbsup:
  18. Mar 25, 2012 at 7:16 PM
    DavidS
    Dave
    Pacific Northwest
    Proceed with caution if you mess with the bar under the passenger seat. From what I've read, it serves some function in enabling the passenger airbag.
  19. Mar 26, 2012 at 4:28 AM
    udy2554
    Naples, NY
    Noted!:thumbsup: I try to do my research before messing with stuff I know nothing about! :eek:
    Hanes book and TW to the rescue!:D
  20. Mar 26, 2012 at 7:44 AM
    Warhorseforever
    Will
    Sand Lapper
    Haynes repair manual-worth their weight in gold.
