subwoofer (POWERED) 10"
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TAC1, Jan 21, 2012.
  1. Jan 21, 2012 at 11:09 AM
    TAC1
    TAC1 [OP] Well-Known Member
    Petros "Peter" AGE: 44
    Miami, Florida
    DCSB 4.0 Auto PreRunn
    FRONT: OEM PreRunner coils, 5100's @ .85, MaxTrac Spindles, 1/4" Taco lean spacer. ground to fender base: LF & RF: 40"'s hub to fender base::::: LF & RF: 25"'s REAR: 2012 OEM 3/1 leafs, Wheelers 3 leaf AAL, 2" Tapered steel block. Bilstein F4-BE5-B110-T5 ground to fender base: LR & RR: 41"'s hub to fender base::::: LR & RR: 26"'s All mud flaps trimmed 4"'s shorter.
    Hello Forum,
    I have an '08 Tacoma Double Cab with the OEM (non-JBL) HU. I had new speakers installed, 6x9 x 6.5 Pioneers (front/rear) & I have a GROM IPOD kit which works great! I decided to leave the stock HU and I am very satisfied with the mids and highs but I want to add some bass. I am looking to add this: KICKER BASS STATION PT10. I would like to install this behind the rear passenger seat and I will remove the plastic panel. I would like to know if it will fit, even with the plastic removed. Also, anybody running this or do have your own suggestions? I haven't removed my panel so I am hoping some knows what the available space is without it. The box measures 12.8"H, 19.3"W, 7.7"BD, 4.8"TD. I appreciate any help and advice you may provide. I also posted a similiar thread on TN. I really want to do my homework before dropping the cash. Thanks again!
