Subwoofer Set up on Amazon, Good deal or not?
Discussion in 'Audio & Video' started by NotoriousSix, Dec 30, 2014.
  1. Dec 30, 2014 at 3:38 PM
    NotoriousSix
    NotoriousSix [OP] Well-Known Member
    Smyrna, GA
    Mid-Travel w/ accessories.
    So I've been wanting subwoofers for a while now. Just the prices I've seen were 500$ -$1000 for peoples used set ups. I have a good friend that will help set them up for me so I won't be using money at a shop for installation. I was just looking at sub boxes on ebay and Amazon when this popped up.
    http://www.amazon.com/Package-Toyot...82384&sr=8-1&keywords=toyota+tacoma+subwoofer
    http://www.amazon.com/BOSS-R1100M-1100-watts-Monoblock-Amplifier/dp/B004S4XNEO/ref=pd_bxgy_e_img_y
    Its roughly 240$ for the amp and subwoofers. I think this is an amazing deal. However, there is only 1 review made(though its 5 stars). My questions are:
    -Anyone currently running this set up?
    -Do I need a specific amp to run two 10" subs?
    -If this amp is good enough, will it fit in that little space between the subwoofers and still fit behind the back seat?
    If anyone can provide some good info that would be greatly appreciated.
    -K
  2. Dec 30, 2014 at 4:38 PM
    shaneckc
    shaneckc Fyntünd Designs Vendor
    Shane
    Thousand Oaks, CA
    2014 SR Package DCLB 4x4
    The sub box looks okay for a drop in. Kicker subs are not the greatest, though.
    And I wouldn't touch that Boss amp with a stolen dick.
  3. Dec 30, 2014 at 4:42 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Sub box is okay, the rest is garbage. Certain things you just can't go cheap on. Lifts, wheels ans tires, and tunes. You get what you pay for though, good luck.
  4. Dec 31, 2014 at 8:39 AM
    Doc Jr 8156
    Doc Jr 8156 Well-Known Member
    Rancho Cucamonga
    2013 DCLB Pyrite Mica 4X4 TRD Sport
    King 2.5 Shocks w/ resi front and rears Total Chaos UCA Icon AALeafs SCS SR8 Wheels BF Goodrich TA KO2 tires All Pro Apex Sliders K&N Air Filter TRD Seatbelt Straps TRD Hubs DeZee Bed mat Extang Trifecta Viper 5904 Alarm Antenna X Ultra Gauge AFE Stage 2 Intake TRD Exhaust OEM Roof Rack HID Headlights and Fogs Weather tech laser mats Alpine CDE 149BT Headunit HAT Clarus 6.5 components front and JL Audio C2 650x for rear 2 Alpine SWP T-10 shallow 10-inch subwoofers Alpine PDX V9 main amp, Alpine PDX M-6 mono sub amp Dual 10 inch sub box Pop-Lock Anytime fog mod Differential breather mod KB Vodoo Bed Brackets KB Vodoo Tailgate protector Midland Portable CB Firestick CB Antenna Osram Headlight Bulbs and Rallyelights harness
    Hello,
    The sub box is the same my brother got for his ride. The problem with this box is that the back of the box directly behind the subwoofers are hollowed out and covered by 1/4 plywood to increase the mounting depth. Eventually, the epoxy used to glue the ply will give out. I repaired my brother's box using 5/8 mdf for the back panel 2 weeks after install.
    If you are not in a hurry, there are better boxes out there than this one costing not much more. Supercrewsound's box is way better than this (no hollowed out panel if you choose the standard mounting depth).
    On another note, those Kickers are a disappointment. Powered by a decent JL audio amp, we gave up on these woofers because no point of EQ can be done for them to sound decent. I have an Alpine SWR T10 single sub that bumps way better than these two, no contest.
    Just my experience. Godspeed.
