subwoofer wont stop need help.
Discussion in 'Audio & Video' started by RDAY, Jan 6, 2010.
  1. Jan 6, 2010 at 5:52 PM
    RDAY
    RDAY [OP] Well-Known Member
    NY
    07 Tacoma SR5 4x4
    Ok i have a kenwwod 5120 a acr sub and amp just got it hooked up. But when I turn my volume down the subwoofer doesnt stop pounding to the song still just as loud and when i turn it up doesnt get any louder what could this be?
  2. Jan 6, 2010 at 6:38 PM
    tacomarock
    tacomarock Well-Known Member
    I have a setting on my stereo that has two sub settings. I think one turns up sub while driving or something. Anyhow I have not changed it. Maybe that will help.
  3. Jan 6, 2010 at 6:42 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    you must be listening to luda
  4. Jan 6, 2010 at 7:04 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    How did you hook it up?
  5. Jan 7, 2010 at 8:43 AM
    RDAY
    NY
    07 Tacoma SR5 4x4
    i believe i hooked it up neg to pos neg to pos then back to my amp cause its dual voice coil. And in component cables would not work unless it was on the front or rear settings it wouldnt work on the sub settings for some reason.
    but on my deck i cant even touch the sub settings for some reason
  6. Jan 7, 2010 at 3:02 PM
    Kevin20
    Kevin20 Active Member
    Kevin
    Pueblo, Colorado
    96 Tacoma
    Complete Stereo Upgrade, Python 991 remote start, security, and aftermarket door locks, K&N cold air intake, cherry bomb dual out muffler, sway away 2.0 coilovers and skyjacker 3 inch leaf springs
    It might not have worked because you don't have the RCA subwoofer channel on. Most decks allow you to turn the sub off and on so it may be set to off.
  7. Feb 8, 2010 at 11:44 PM
    Colinwoods84
    Colinwoods84 Well-Known Member
    Virginia Beach
    2008 Sport Double Black
    That model is limited on sound rca's. If your running a 4 channel amp with RCA the the sub can not be ran. There is a switch in the setup audio menu that allows you to turn the "rear" RCA to sub. You don't get front rear and sub on that unit! That's the reason I went from 5140-8120. I know this is kinda late on the reply but I'm bored at work and going through the pages.
