Subwoofers and amp in Delaware
Discussion in 'Buy / Sell / Trade' started by Triangleacre1, Jul 6, 2011.
  1. Jul 6, 2011 at 5:40 AM
    Triangleacre1
    Triangleacre1 [OP] Well-Known Member
    Dustin
    Delaware
    01 Tacoma SR5
    I have 2 12" subwoofers with a amp for sale for $175. The amp is mounted on the top back of the box. I had them in Cavalier before I had my Tacoma. The box will most likely be too large to stay in a Tacoma full time. They will be best in a car because of the size of the box. I am in Harrington, Delaware and would prefer not to ship.
    Here are the details:
    Magna Bass MB212P mono amplifier
    250 watts x 1 at 4 ohms
    1,000 watts peak
    variable high- and low-pass filters (50-250 Hz, 12 dB/octave)
    variable bass boost (0-18 dB boost at 40 Hz)
    preamp- and speaker-level inputs
    preamp-level outputs
    thermal, overload, and short protection
    fuse rating20Ax1
    10-gauge power and ground leads recommended
    Magnum sealed dual 12" enclosure
    5/8" particle-board construction with aviation-grade carpet
    two Magnum 12" 8-ohm subwoofers
    poly coated pulp cone with large-roll foam surround
    frequency response: 20-300 Hz
    power range (each): 50-250 watts RMS
    [​IMG][​IMG]
