Subwoofers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeddie7811, Oct 1, 2020.
  1. Oct 1, 2020 at 8:42 PM
    jeddie7811
    jeddie7811 [OP] Active Member
    Jacob
    2009 Tacoma double cab
    new grille, headlights, wheels, tires, radio, leds
  2. Oct 1, 2020 at 9:09 PM
    TacomaTung
    TacomaTung Well-Known Member
    Tung
    Bay Area, CA
    O12 Tacoma Sport
    If those aren't shallow enough you may need to take all the plastic bins in the back and get a custom box. Not sure what the size difference is but jl w3's fit back there. They also make a steal box for 2 10's
  3. Oct 2, 2020 at 7:14 AM
    jeddie7811
    Jacob
    They are shallow enough it is just the magnet diameter is 6.3” and a box i was looking at was could fit a magnet diameter of 6” I just need a box that will fit those
  4. Oct 3, 2020 at 10:26 PM
    DJSpeed
    DJSpeed Well-Known Member
    I bought a 10in box of Amazon and used a jigsaw to make it 12in and run the low profile pioneers
  5. Oct 4, 2020 at 5:25 AM
    Fireball1
    Fireball1 New Member
    2014 tacoma sr5 4x4
    leval kit, pro comp shocks and 265 75 r16 toyo at3
    Did the same thing and bought a box off Amazon. But I just ran 10 in subs. Box fits super tight.
  6. Oct 4, 2020 at 5:33 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    This doesn't make sense to me. To me it reads that the box is deep enough fo the speaker, but it almost sounds like they routed the back wall for the magnet to recess into.
    Woofers NEED a specific volume to work properly and give you the rated frequency response.
    I've seen woofers tear the surrounds off cages because the enclosure was too small.
    Jacked Burton likes this.
  7. Oct 4, 2020 at 6:56 PM
    DJSpeed
    thats why low profile subs are designed to work in small spaces. the cubic feet required for my subs are slightly over the sealed box that takes up my entire back seat area
  8. Oct 5, 2020 at 2:48 AM
    Larzzzz
    Larry
    MA
    That still doesn't explain the 6", 6.3" magnet difference that's causing you issues. Is the back of the enclosure routed out with a 6" recess for a magnet?
    And have you thought of going with a ported enclosure?
  9. Oct 5, 2020 at 8:01 AM
    jeddie7811
    Jacob
    not enough room for 2 subs with a ported enclosure, not enough airspace
  10. Oct 5, 2020 at 9:29 AM
    Fireball1
    2014 tacoma sr5 4x4
    Just run a non ported box with 2 10in subs. I did and it sounds good and clean. Not going to "boom" but it will have bass
  11. Oct 5, 2020 at 1:06 PM
    Larzzzz
    Larry
    MA
    My bad, I had the 2 mixed up...Cranial flatus. Lol
  12. Oct 5, 2020 at 3:00 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    I built my own enclosure from MDF (and fiberglass) that sits behind the rear seats. I run one 10" sub, JL Audio 10TW3.
    I removed the plastic behind the seat and custom fit and cut things. As I was building it, my enclosure was turning out to be just borderline on the interior volume I needed, so I decided to just go ported and make it as large as it needed to be. My seat doesn't fold all the way up, but I keep my seats down 99% of the time and it's definitely out of the way for me. One of my favorite things I added for sure.
  13. Oct 5, 2020 at 3:05 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    I have a pair of 2x 10” JL Audio W3 and they hit hard for a sealed box.
  14. Oct 5, 2020 at 4:05 PM
    jeddie7811
    Jacob
