Subzero Y-pipe, ZZP HO Waterpump, Howe PS Pump, Oil coolers + MORE Shiny Performance!
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by jamesepoop, May 27, 2025.
  1. May 27, 2025 at 9:25 PM
    jamesepoop
    jamesepoop [OP] Well-Known Member
    California
    2007 Fj Cruiser
    Parts are brand new and located in Anaheim, CA. Parts that are brand new are usually ready to ship. The other parts may be removed from vehicle as necessary. Will add additional pictures as I get to the garage but the current pictures are mine (unless it's obvious it's a stock photo, it'll be replaced soon)
    Subzero Y-Pipe. Brand New. The order is: cerakoted titanium, 3" midpipe (no longer an option), O2 Port included on midpipe. It's a 3" midpipe outlet that needs the a 3" bellmouth adapter welded to (assumed) 3" exhaust. This is a little different from what he's offering now. I think he changed it to a 2.5" midpipe that fits the smaller bell flange of the OEM exhaust donut. I ended up sourcing a true 3" bell mouth flange to use with a larger gasket for true 3" (no step down). Secondary O2 is in standard position and the wideband O2 set up is in the midpipe.
    Normally $1660 shipped +lead time. Asking $1600 shipped which saves on shipping and me sourcing the 3" adapter flange if it works for someone's setup already using something similar and looking for flow over all else.
    ZZP High Output Waterpump. Brand New in box. Flow: 35 liters per minute @ 12v/50w. Normally $137 shipped, asking $125 shipped.
    2.0” Smoothflow pulley with a custom hub for custom sized pulley. Normally $100, asking $90 shipped.
    GReddy/Grex Oil Adapter + all AN press fittings and reinforced hose to -10AN ports. $220 shipped
    All Star Performance Fluid Cooler, Oil Cooler, Dual Pass, 4.00 in. x 15.00 in. x 3.50 in., Deck Mount, -10 AN Inlet/Outlet, Each. Normal $265. Asking $220 shipped. Or combine Grex adapter for $400 shipped.
    Snow Performance Stage 3 water methanol kit part number 3210. Includes all the hardware as new in bag, larger 3qt tank, dual solenoids to control flow cutoff and updated controller that adapts a practical 2d map for your vehicle. This kit was $950+. Selling for $800 shipped
    **Used 85mm 22030-0S010 Throttle Body with new Toyota Metal Gasket. $110 shipped.
    **Used Howe PS Pump, PSC reservoir to Derale heat exchanger. Includes overflow breather for Reservoir, brand new fluid filter, and brand new fluid. Mine is custom routed and a bit more direct to the rack IMO as directed by Howe. JD fab sells their complete setup for about $2025 shipped. Asking $1700 shipped.
    **Used NST Pulleys: S/C pulley Normally $248 shipped, asking $160 shipped. Waterpump Normally $128, asking $80 shipped. **HOLDING
    ***SOLD Items***
    6x Denso Iridium Power Spark Plugs for supercharged 1GR-FE motors
    SUMOTNK, Billy182, PhoS and 1 other person like this.
  2. May 27, 2025 at 9:37 PM
    herecomesace
    herecomesace Well-Known Member
    2013 Tacoma TRD Offroad Access Cab MGM Supercharged
    I don't have the coin right now for any of these goodies, but do you care to let me know where you sourced the 3" bell mouth flange/gasket? I'm pretty much in the same boat with the 3" midpipe. Been sitting in my garage for a while now.
  3. May 27, 2025 at 9:50 PM
    jamesepoop
    California
    2007 Fj Cruiser
    I went thru 4 different sellers and they were all a little different. Just checked and the seller I found is sold out. Try ebay. As maybe more then one seller is having the item. I used key words 3" stainless steel ball flange. This particular one came with a gasket too.
    herecomesace[QUOTED] likes this.
  4. May 27, 2025 at 9:51 PM
    herecomesace
    Thanks!
