Success!! I Think...
Discussion in 'Performance and Tuning' started by ETaco23, Mar 13, 2009.
  1. Mar 13, 2009 at 7:57 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    prob round 40 or 50 bucks at autozone.
  2. Mar 13, 2009 at 8:07 PM
    ETaco23
    ETaco23 [OP] Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I hope so! Im looking online and some are costing up to 100 bucks, for dif. car/truck. I havent found one for my truck yet.
    I'll be going to AZ soon and i'll ask them.
  3. Mar 13, 2009 at 8:19 PM
    ETaco23
    Evan
    PNW
    could I clean it some how?
  4. Mar 13, 2009 at 8:22 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i have never found a way........................all it really is is a vacuum. you can take it off and blow/suck thru it just a little and see if it moves on the inside.
  5. Mar 13, 2009 at 8:26 PM
    ETaco23
    Evan
    PNW
    k. I'll probably just end up replacing it if it isn't too exspensive.:(
  6. Mar 14, 2009 at 12:44 PM
    ETaco23
    Evan
    PNW
    So i jusy went out to see about an egr valve and gasket. And Autozone told me they have to order it, so did napa. So I decided to go to the dealer to see if they have it. But the guy says that my truck doesnt have one.:0 I dont get it! Im pretty sure I do. But he told me that they stopped making them around 96 and newer. Can someone explain this?
  7. Mar 14, 2009 at 3:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Som-O-Bitch....I guess it doesnt have one...neither does the new V6......Hmmmmmm
  8. Mar 14, 2009 at 3:58 PM
    ETaco23
    Evan
    PNW
    Yep! I know... i just changed my PCV valve and it was pretty dirty. So I hope that helps some. I guess if the ruff idle, bad mpgs persists, then its the wires next.
  9. Mar 14, 2009 at 4:11 PM
    ETaco23
    Evan
    PNW
    Hey chris! could I hurt anything by seafoaming through the PCV? Is it a good idea, or is the brake booster line better? The PCV line seams closer to the TB and will clean better, it seems.
  10. Mar 14, 2009 at 4:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I have never done it thru the PCV. Being as its closer to the throttle body, it may increase the chance of hydrolocking the engine if it gets sucked thru to fast..
  11. Mar 14, 2009 at 4:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You still havent changed your wires??? I would change them out. Being as one had a problem, others could be causeing your idle to be messed up.
  12. Mar 14, 2009 at 4:39 PM
    ETaco23
    Evan
    PNW
    Well, Im not sure if the wires are bad. I never said one had a problem... I had a problem getting one out!:) But I know that it would be a good idea to change them since there still factory. I will do it soon!
  13. Mar 14, 2009 at 4:55 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you can go thru the pcv for seafoaming, but do it extra slowly. that will give the whole intake a good cleaning too.
  14. Mar 14, 2009 at 5:02 PM
    ETaco23
    Evan
    PNW
    Cool! I will do it when I get my oil changed. Monday I'll get new wire's put in and see if that helps. this is really bugging me! I cant stand having something not right on my truck! irritates the shit out of me!
