Successful Decryption of Toyota Tacoma ECU?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacomageek, Dec 4, 2021.
  1. Dec 4, 2021 at 5:20 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I remember when being able to tune a four barrel carburetor made you the smartest guy in the room. :)
  2. Dec 4, 2021 at 6:18 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I like to use "then a miracle occurs" box on the ol flowchart...
    BortisYeltzen[QUOTED] likes this.
  3. Dec 4, 2021 at 6:20 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    The ECU is unreadable. Doubtful it'll happen any time soon, if at all.
  4. Dec 4, 2021 at 6:27 PM
    BobbyTacoTRD
    BobbyTacoTRD Skewps Ahoy!
    2021 TRD Off Road
  5. Dec 4, 2021 at 6:38 PM
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
    Agree. Mat said 0% chance unless TSB released.
    hiPSI and ktbell444[QUOTED] like this.
  6. Dec 4, 2021 at 9:53 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It is only a monopoly because it took so long to reverse engineer and then tune to make it right. Being able to crack it is only part of the story.
    The number of maps loaded into this ECU boggles the mind, let alone the relationships between them.
    Beyond that, vF was the key for Magnuson to stop teasing the 3rd Gen S/C for over 3yrs. They had the excellent hardware that wasn't marketable without vF's work and software.
    Sincerely, good luck!
    Shellshock, hiPSI and ktbell444 like this.
  7. Feb 27, 2022 at 11:19 AM
    flat_tire
    flat_tire Well-Known Member
    Independence, KY 41051
    2016 Tacoma TRD Off-road ACLB blue, 2018 Tacoma TRD Sport DCSB white, 2020 supercharged Tacoma Limited DCSB magnetic grey metallic, 1993 AMGE HMMWV, 1993 Ford Mustang GT 5.0 supercharged
    2020 Tacoma: Icon stage 9, Magnuson supercharger, URD full exhaust, solar 2018 Tacoma; OME 2in suspension 2016 Tacoma: Falcon front and rear rate adjustable suspension, rear airbag lift
    Has no one ever heard of ECUTools.eu? They've had a program that reads and backs up Toyota ECU's for a long time.
    https://ecutools.eu/chip-tuning/pcmflash/
    PCMFlash
    "supports flashing both backup (vbf) and binary (bin) files. When flashing binary files checksum verification and correction is available for most of the modules. Conversion from VBF/GDS into BIN is supported if the ECU doesn’t support reading."
    My experience successfully reverse engineering many things has been to intercept the communication between the software and hardware. CANBus sniffing is where I would start. .CUE files have the at least a write-key built into them, otherwise they would not be capable of flashing the ECU.
    ECU sniffing looks like this
    message ID: 620
    data: 10 80 FF FF 80 20 00 80
    As fun as this stuff can be, I personally still support small-fry companies like VFTune because their hard work won't continue unless they can make money to justify the effort. Another reason to use VFTune's kit is to compare with your results from the above Russian toolsets.
    bobsuruncle likes this.
  8. Feb 27, 2022 at 11:27 AM
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    Heard of it, but there's a lot more to it than just opening up a binary file and having access to all the maps and knowing their functions/purpose. You'll need things like a definition file for example (which doesn't exist for the 3GT). I also believe that each ECU ID is actually set up different. Register 5 may be the start of one array for 04B04, and register 30 may the the same array but in 04B33. Overly simplified, of course, to make it easier to understand for anyone who isn't familiar with processor architecture. In my opinion, the tools already exist, therefore it's not worth going through the hassle again. Especially because it has taken about 6 years to get where we are currently.
  9. Sep 6, 2022 at 11:49 PM
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
  10. Sep 7, 2022 at 4:53 AM
    grandpawmoses
    grandpawmoses Dirty Old Man
    David
    2021 Tacoma Limited Nightshade
    No money
    Boy, all this decoding talk went over my head like a Blue Angles jet at an airshow.
  11. Sep 7, 2022 at 6:55 AM
    flat_tire
    "matt" from ovtune is a child. I bought his tool and ran into problems and it ended in him crying like a baby and I eventually had to dispute the charge with my card. His "company" is nothing more than customer service that relays data between another company in Russia that did all the reverse engineering and provides him with each and every tune you purchase from him.
    I moved on to ecutools.eu, bought pcmflash and have both read and written tune parameters in the ECU. I own 3 Tacomas and a TRD Pro tundra. I do ALL work myself and have installed a Magnuson SC on my 2020 Tacoma and an Eaton supercharger I bought from Harrop on my Tundra.
    If you're serious about this stuff as I am, I suggest using tuningtools.com as their software does most of the heavy lifting for you with a few clicks. Pcmflash is a high-skill tool that requires you use hex editors, memory mapping tools, and can understand the layers and interdependent procedures implemented in the ECU/TCU.
    There is only one package that is able to do a read (VR) and write and also has modification options via the editor. Bitsoftware Bitbox with Denso Petrol or Diesel module (depending on ECU and engine) that can do virtual read over OBD (original has to be located for editing)
    After the original is located you can use their BitEDIT software with the corresponding Denso module for editing.
    Big problem is that this is a Russian tool and due to international sanctions it is hard to obtain USB dongles.
    You would also need a USB to OBD interface like Tactrix.
    USB dongle and BitBOX modules.
    https://www.tuningtools.com/bitsoftware-usb-dongleEditing BitEDIT modules (can be installed on the same dongle) https://www.tuningtools.com/bitedit-modules
    pyankura and shotgunbilly420 like this.
  12. Sep 7, 2022 at 6:56 AM
    flat_tire
    Contact Sasha Biskup directly at Sedox in Norway
    SEDOX Sales & MarketingTel. +47 90916585SEDOX Performance ASKnud Holms gate 1, 4005 Stavanger, Norway
    SEDOX Performance - more Performance in your carwww.sedox-performance.comwww.tuningfiles.com
    shotgunbilly420 likes this.
  13. Sep 15, 2022 at 10:15 AM
    flat_tire
    Meant to put a link to this site Send hash, get decryption key
    https://www.hexprog.ru/
    This program is designed to find passwords for programming Toyota and Lexus Gen2 ECUs (1.28/1.5/2.0Mb). The full version has many more features, but here we are talking about brute-force passwords. The purpose for getting the passwords is to be able to flash the "unreadable" ECU with a compatible BIN.
  14. Sep 15, 2022 at 11:52 AM
    Kel Varnsen
    Kel Varnsen Active Member
    PO HO
    2005 DC TRD ...Sold 425k Now 2016DC TRD
    10 TUNE "My Tacoma"
    20 GOTO 10
    C:/ RUN
  15. Sep 15, 2022 at 1:36 PM
    #35
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    That's an infinite loop. You sure you want to do that? ;)
  16. Sep 15, 2022 at 1:48 PM
    #36
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    MEGA TUNE!
    ktbell444[QUOTED] likes this.
