Successful Install of Block Heater
Discussion in '2nd Gen. Tacomas (2005-2015)' started by VTDave, Nov 14, 2008.
  1. Nov 14, 2008 at 1:13 PM
    VTDave
    VTDave [OP] Well-Known Member
    Vermont, USA
    05 Access Cab 4x4 Base 5sp Man, 16 DCSB 4x4 Sport 6sp Man
    I'm reporting on my successful installation of an engine block heater on a 4 cylinder 2005 Tacoma - for the benefit of future searchers of the archives.
    Part Used:
    Toyota of Canada Part #00213-02141, available in the USA from trdparts4u.com for $60.
    Installation method used:
    1. Put front of truck up on jackstands and drained coolant.
    2. Removed front passenger wheel to get a little wiggle room and a better view of workspace.
    3. Got underneath truck (making sure it's well-supported first!).
    4. Located oil filter on passenger side.
    5. Looked directly behind the oil filter at the engine block. There's a freeze plug right there. (There's another freeze plug about 6" further towards the firewall, rearward from the filter. Don't use that one, tempting as it may be. There isn't enough room inside the coolant passage for the heater to fit there.)
    6. Removed the freeze plug using my preferred method. I used a punch and 2lb hammer. Just hit the plug off-center a few times and it budged. Then I pulled it out with a set of pliers. Cleaned up the hole with 1000 grit sandpaper.
    7. Retrieved block heater. Lubed the o-ring with the provided silicone. Pressed the heater firmly and evenly into the freeze plug hole. Made sure the o-ring was seated properly.
    8. Tightened the screw on the outside of the heater to 19 inch-lbs per instructions. The heater felt nice and snug.
    9. I routed the power cord to the lower air dam.
    10. Then added coolant back to the system, ran the engine, and checked the heater for leaks (visual inspection). No leaks!
    11. Put the wheel back on, lowered the truck and drove around for a week. Still no leaks.
    Other important stuff: The instructions that come with the heater were last revised in 1995. They're helpful for a '94-'95 Tacoma, but not so useful for us. Nonetheless this part is still recommended for Gen2 trucks by Toyota Canada. Also, make sure you pick the correct freeze plug hole. If not, you'll be special-ordering a replacement freeze plug from Toyota! Also, V6 guys: your block heater is a totally different design that plugs into the rear of the block. And, luckily for you, installation does not involve draining coolant.
  2. Nov 14, 2008 at 4:06 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Good write up, should be helpful.:thumbsup:
  3. Dec 11, 2008 at 6:33 PM
    brohloff
    brohloff '18 DCSB 4x4 Sport Cement
    MN
    '18 DCSB 4x4 AT Cement
    VTDave, Good info. I also bought the same block heater from Toyota for my '07 2.7ci access cab and was planning on doing the install myself as well.
    Had trouble trying to determine where the correct location should be. No help from the local Toyota dealers. They just want the $400 plus $$ to install it.
    Your instructions are pretty clear but just wanted to verify - Is the correct freeze plug just forward (toward radiator) of the oil filter or sl back. Have not gotten under to look yet so might be apparent but thought I'd get additional info before I do..
    Again good post. Thanks......... bob...
  4. Dec 11, 2008 at 8:55 PM
    Okkine
    Okkine Well-Known Member
    Alberta
    1998 Tacoma, V6, Manual Transmission, 4x4
    Thanks for that info. I didn't realize you had to drain the coolant in the 4 banger.
  5. Dec 12, 2008 at 4:17 AM
    VTDave
    Vermont, USA
    The correct plug is to the rear (towards the firewall) from the oil filter. I'd take a pic, but my truck is outside in the middle of an ice storm at the moment.
  6. Dec 12, 2008 at 6:06 AM
    harshest
    harshest I am the Sofa King
    Michigan
    05 PreRunner SR5
    Fog Light On, Hidden Garage Door Opener, Scanguage II, Weathertech Liners, Cig lighter always on, Door buzzer removed from dash- Upcoming: 5100s for front and rear, set fronts to 2.5" and Toytec AALs.
    This may be a stupid question but why would you want a block heater on a gas powered engine? Is it so your vehicle will warm up faster? I thought those were mainly for diesel engines.
  7. Dec 12, 2008 at 7:51 AM
    VTDave
    Vermont, USA
    That's not a stupid question at all. You're right that gas engines have a much easier time than diesels getting started in cold weather. But, there comes a temperature when even gas engines need help. Just ask someone who lives in northern Canada, and they'll tell you all about their block heater, battery blanket, transmission heater and diff heaters. At -40 degrees, they really help.
    Although I occasionally travel to northern Quebec, I primarily use the block heater at home when temperatures are in the -20 to +10F temperature range. It reduces engine wear and fuel consumption during warm-up. And, for those of us who make a lot of short trips when it's cold, it's extra good. Plus you get almost instantaneous heat when you start the truck.
  8. Dec 12, 2008 at 8:05 AM
    Stu
    Stu Well-Known Member
    G'Ville, NV
    Taco TRD OR
    Not much yet, got a pretty good sound system w/ my custom sub box. Plan on adding more lights & a tool box.
    The folks where I used to live (central MT) didn't like the block heaters, as they tended to leak. We used a heater that went inline with the coolant hose. a Whole lot easier to install also. Not sure if they make them anymore.
  9. Dec 12, 2008 at 8:12 AM
    e-rok
    e-rok Well-Known Member
    Gunnison, Colorado
    2009 Timberland Mica Double Cab Tacoma 4x4
    I just ordered the Toyota block heater for my 4.0L, looks even easier than the 4cyl. I live where it hits 40 below and have always had block heaters on my cars/trucks. We are already going below zero, hope it is as easy to install as it looks/sounds. Any one have any words of wisdom for installing on the V6?
  10. Dec 12, 2008 at 8:19 AM
    VTDave
    Vermont, USA
    I'm pretty sure there's a write-up for the V6 either on here, tundrasolutions or yotatech. I remember thinking that it looked pretty easy when I read the write-up. No draining of coolant involved. You plug the heater into a port on the block and run the wire - that's it.
  11. Dec 12, 2008 at 8:26 AM
    e-rok
    Gunnison, Colorado
    Your write up made it sound pretty easy, then I read that the heater for my truck just plugged in, I thought, hell, even I can do that, and even better I do not have to make the 2 hour drive to get worked over by the dealer. I found this write up for the 2nd gen v6's: Thanks for the motivation to take this on myself.
  12. Dec 12, 2008 at 8:36 PM
    Okkine
    Alberta
    Not a stupid question. I grew up in southern Alberta where -30c to -40c (-22f to -40f) is not uncommon. There were several mornings where I had to call in sick to work because I didn't plug in the car, and the temperature dropped unexpectedly over night and the engine simply wouldn't turn over fast enough to start. I'm honestly surprised that a block heater isn't standard in the Canadian trucks... or perhaps it is, except her in Vancouver (the only place in Canada where you don't "need" one).
  13. Dec 11, 2012 at 5:05 PM
    TheTourist
    TheTourist Member
    Central Alberta
    01 xcab 2.7L 4x4
    Hi guys, I realize this thread has been dead for a while, however I'm installing a block heater. First Dave says: "Looked directly behind the oil filter at the engine block. There's a freeze plug right there. (There's another freeze plug about 6" further towards the firewall, rearward from the filter. Don't use that one, tempting as it may be. There isn't enough room inside the coolant passage for the heater to fit there.)" From this, I understand to use the freeze plug towards the front of the truck. Then in a later post, Dave says: "The correct plug is to the rear (towards the firewall) from the oil filter." From this, I understand to use the freeze plug to the front of the truck. Does anyone know the proper one to use here? Thanks
  14. Aug 17, 2014 at 7:19 AM
    burhead
    burhead Member
    Craig
    Thunder Bay
    2009 Tacoma 2.7 - 4x4
    Timbrens added to suspension Custom made boat racks
    Dealer told me first frost plug from radiator that protrudes out. Put block heater in yesterday, no issues!!!
  15. Aug 17, 2014 at 7:27 AM
    burhead
    burhead Member
    Craig
    Thunder Bay
    More pics
  16. Aug 17, 2014 at 9:51 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    What block heater did you use ? Link ? Thanks for the pics and pardon my stupidity but everything looks stock old and slightly dirty in the pics - where is the block heater - thanks for any reply.
    pas-chill likes this.
  17. Aug 18, 2014 at 11:57 AM
    burhead
    burhead Member
    Craig
    Thunder Bay
    I bought the block heater from the local dealer for $53 plus tax.
    It's the gold coloured plug in my first photo. I don't have the wire plugged into it. But you can see where the 110v wire plugs in.
    If you compare to the second photo it is just the frost plug.
    The job is very simple to do by following the previous instructions. Take both the wheel and skid plate off to make life easy.
  18. Aug 18, 2014 at 2:40 PM
    george3
    New Jersey
    Great information - Thanks for the reply.
  19. Nov 8, 2014 at 4:42 AM
    lionsm13
    lionsm13 Well-Known Member
    Black Hills SD
    07 Tacoma SR5
    I hate this time of year.
    Winter sposed to start bearing down on our ass here in good ol' South Dakota.
    Last nice weekend!!
