sudden bad gas mileage help!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by abnranger80, Jul 15, 2012.
  1. Jul 15, 2012 at 9:10 PM
    abnranger80
    abnranger80 [OP] Member
    Nick
    Waynesville NC
    TRD
    ARB Bumper, M8000 Warn, 6" Procomp lift, 17" procomp wheels, 37" Mickey Thompson MTZ, King Coilovers.
    ok so i 80000 miles on my trd 4 door. i changed spark plugs (denso), throttle body spacer and cleaned throttle body and MAF sensor, sea foam in gas tank, royal purple in t-case and diffs, royal purple oil change, water wetter in radiator, and complete ome suspension with 285/70/r17 mickey thompson mtz. Now im getting 240 miles on a tank of 93 octane. anyone else ever had this problem. i doubled checked everything and its all perfect so im stumped.
  2. Jul 15, 2012 at 9:12 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    It's your 285 tires. The increase in radius and weight eats MPG's. Most guys with 285 tires are around 15-16 mpgs so it sounds like you're in that range.
  3. Jul 15, 2012 at 9:16 PM
    abnranger80
    Nick
    Waynesville NC
    TRD
    i guess i can live with that. i almost had a heart attack thinking something mechanical was wrong. thanks brother.
  4. Jul 15, 2012 at 10:32 PM
    Bishop2Queens6
    SoCal
    2009 DCSB SR5 4x4
    You don't really think tire size will drop your mpgs but it does.
    When I had a 245 tire: 21 mpgs
    Upgraded to a 265 tire: 18 mpgs
    A 285 tire will drop me down to a 16 mpgs. Even though they do look awesome and perform off road, I don't wheel enough to justify mpgs that low. haha.
    Np. You can drop 3 grand and get re-geared so you can gain some performance and MPG's back sometime down the road.
  5. Jul 16, 2012 at 7:19 AM
    tacoma07pre
    tacoma07pre Well-Known Member
    kansas city
    Also keep in mind that with the new tires your odometer is off and you are traveling more that 240 miles on the tank. Check your old tire size vs. new size on a tire calculator and see what the difference is.
