Sudden bump when I come to a stop
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ricky B, Jun 23, 2011.
  1. Jun 23, 2011 at 8:08 AM
    Ricky B
    Ricky B [OP] Well-Known Member
    Maumelle, Arkansas
    2007 V6 Auto
    I thought I posted this last week but I have been gone visiting my parents and I guess my computer didn't post it.
    I have a 2001 tacoma double cab and here lately when I come up to a stop light and stop I can feel something stop like a second later toward the rear end. Now when I say stop it feels more like a bump and I can feel it in the gear selector. When I coming to a stop and I can keep the veh barely moving (like rolling through a stop sign) I feel this when I take off. I know this isn't much info but its about all I know. The truck has 170,000 miles on it. Rick
  2. Jun 23, 2011 at 8:10 AM
    woodygg
    woodygg Well-Known Member
    So Cal
    04 DC Tacoma 4x4
    Both my 1st gen's do/did that... the Toyota people told me it's normal and something to do with the drive train/mounts/etc... can't exactly remember.
  3. Jun 23, 2011 at 8:12 AM
    Ricky B
    Maumelle, Arkansas
    2007 V6 Auto
    Woodygg I just starting noticing this about a month ago. I have driven this truck for 75,000 miles and never felt it like now?
  4. Jun 23, 2011 at 8:19 AM
    JaSkynyrd
    JaSkynyrd Ron F. Swanson
    Chattanooga, TN
    2001 XtraCab 4x4 V6 SR5
    Probably axle wrap...search it and you'll find more than you wanted to know.
  5. Jun 30, 2011 at 11:25 AM
    BBJ285
    BBJ285 Well-Known Member
    Scurry, TX
    03 Pre-Runner
    SnugTop cap, "SuperSpring" helperspring, flowmaster muff,K&N CAI, CB, small amp & 2 6x9s in the bed on a toggles switch for nights at the drive-in...
    axle wrap
  6. Jun 30, 2011 at 12:02 PM
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    axle wrap. Mine is just starting to do the same thing @ 50k.
  7. Jun 30, 2011 at 12:05 PM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    x546, axle wrap, plus probably a dry and binding slip yoke on the rear drive shaft making it more noticeable. Grease the slip yoke, and see if that makes it less obnoxious. After that, you are into helper springs or replacing leaf packs to make it go away. The stock leafs are weak.
  8. Jun 30, 2011 at 5:13 PM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    Toyota TRD Pro Grille, Skid Plate, ARE Series II Lid,
    Mine did that try pruging the universal joints with grease, that stopped mine. spoke to one of the Toy techs and he told me that's what they try first.
    your best bet is to lube the entire drive shaft, I have been doing that every oil change and have not had that problem again.
  9. Jan 22, 2013 at 7:31 AM
    SUPERNICK
    SUPERNICK Active Member
    Nick
    Northern California
    01 XTRA CAB TRD 4X4
    STOCK for now
    I have 96K on 01 taco and it does the same thing. Has ever since Ive started driving it after inheriting it less than a year ago. Thought it was my trans or drive line so maybe Ill try the lube tech first see if that helps.
  10. Jan 22, 2013 at 6:29 PM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    -Axle wrap. Mine started after I installed my lift. NEVER did it before. I've owned the truck since new (well, 2,900 miles...new enough) and I put the lift on at 190,000 miles and then it immediately started.
  11. Jan 27, 2013 at 4:19 PM
    SunDevilTacoma
    SunDevilTacoma Well-Known Member
    Doug
    Gilbert, AZ
    04 Wht Double Cab PreRunner
    Turn signal relocation, built in fog light conversion, 4" deck plate
    x3452764649 axle wrap
  12. Jan 27, 2013 at 5:48 PM
    jaunty
    jaunty Well-Known Member
    99 V6 TRD Automatic 4x4
