sudden loss of all electrical power?!?!?!?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bino9905, Oct 25, 2014.
  1. Oct 25, 2014 at 7:54 AM
    Bino9905
    Bino9905 [OP] Well-Known Member
    TX
    99 ExtCab 4X4 V-6 TRD
    basically i heard a click sound as I was trying to start truck and then lost ALL power....no lights no nothing......if i try and turn on the headlights with the key out of ignition all i hear is a fast clicking sound somewhere around battery.....i removed most of the relays and it still does it......what could it be? I had just started and moved the truck less than a minute before.....
    So i set out to change all the fluids in my 99 tacoma this morning. I moved my truck to inside garage then realized I needed to move again to give me more leg space when I lay down under the truck. I was not wearing my normal work boots so when I went to start it I did not have the clutch pushed all the way down like normal. so as the truck was trying to start and I tried to scoot up in the seat, the clutch moved in and out and then CLICK.....no more power...
    Please help....
  2. Oct 25, 2014 at 8:14 AM
    1993t100
    1993t100 I’m good looking and I drive a Jeep.
    Big Sexy
    Nebraska
    Jeep Wrangler Rubicon
    Check your battery terminals. On my old T100 I had the same thing happen, one time after I pulled out onto the highway. Lost all power completely. Thank God it was at 2am, no one was around. I replaced both terminals and cleaned up the wires, lots of corrosion can build up. Especially on an older vehicle
  3. Oct 25, 2014 at 8:35 AM
    Bino9905
    TX
    both terminals looked fairly good and tight....the power side had some corrosion and damage, so i replaced it I cleaned both post and put in all the fuses and relays back into the box. i went it put the key in and everything lit up like normal....
    pushed the clutch in, and turned the key like normal....then CLICK....all power gone again...i just disconnected battery again to see if things "reset" and then will try again....could it be the starter is jammed or stuck some how?.... but i dont know why that would kill all power....
  4. Oct 25, 2014 at 8:39 AM
    BamaToy1997
    Bill
    Navarre, FL
    Could be starter jammed up. Try rocking the truck a little while in gear just in case the armature got snagged on the flywheel. Also check the ground cable to the engine block, as well as the power cable to the starter for corrosion/poor connection. You may have a discharged battery, which could cause this, so if you have a volt meter, check the voltage.
  5. Oct 25, 2014 at 8:47 AM
    Bino9905
    TX
    well things did reset....after I hooked up the battery again i tried turning on head lights with key out of ignition...1st time nothing happened but 2nd try they turned on....i put key in ignition and all lights and radio come alive like normal....This time i pushed the "clutch cancel" button on the left side of steering wheel......then turned the key....CLICK.....all power gone again......could it be the battery some how???
  6. Oct 25, 2014 at 9:04 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Could be the clutch pedal ignition switch, about a $40.00 part.
  7. Oct 25, 2014 at 9:45 AM
    markmb45
    markmb45 Well-Known Member
    Mark
    Utah
    99 4x4 Reg Cab 3.4, auto, e-locker
    V6,Auto, e-locker 4runner dash, seats
    I had the exact symptoms on my 4Runner this AM. Had to replace the positive battery clamp. The original clamp was ever so slightly loose. New clamp and and all is good.
  8. Oct 25, 2014 at 10:19 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    it definitely could be the battery, seen them before show volts but not allow amps to flow. get another battery or vehicle to try with jumper cables and see if it works, if not look under the dash at the clutch kill switch and see if you knocked it loose.
    another thing to try is hook jumper cables like replacement wires from battery to ground and battery to starter solenoid side (not the starter side)
    then try, this will tell you if you have bad cables, often they can corrode away from the inside and not show it
  9. Oct 25, 2014 at 10:28 AM
    BamaToy1997
    Bill
    Navarre, FL
    Sorry, but no, it wouldn't be the clutch pedal switch. The cancel switch bypasses this, and if it was the clutch pedal switch, he wouldn't get a "click" and then lose all power.
  10. Oct 25, 2014 at 10:39 AM
    Bino9905
    TX
    well....got all my fluids replaced on drive train....hooked battery back up and it wont reset....no lights no anything.....bout to swap batteries from my corolla....hope its the battery....later...
  11. Oct 25, 2014 at 10:45 AM
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    Alternator?
    Sounds like the exact same thing that happened to me and it ended up being my alternator. Just a guess.
  12. Oct 25, 2014 at 11:08 AM
    Bino9905
    TX
    well i just swapped the batteries......i put the corolla battery into the truck and then turned on headlights....they worked and i got my hopes up......but maybe 3 seconds later before i even put key in ignition....i hear a small click right around fuse box and battery and all power is gone...... so what would kill all power from battery???? what ever it is seems to reset it self when battery is disconnected.....i put the corolla battery back in car and it started right up.....so since it did that with a good battery that i just proved works, it cant be the battery....any other thoughts?
  13. Oct 25, 2014 at 12:23 PM
    Bino9905
    TX
    well looks like its the starter.....i disconnected the power cable from the starter...but i lefet the smaller cable to the solenoid on........i hooked up the battery....my lights worked....put key in ignition and everything is normal....tried to start it and i could hear the solenoid clicking.....so i again disconnect battery....hook up power cable to the starter.....hook battery back up.....turn lights on they work....then i turn the key to start and CLICK....all power gone again.......How is the starter doing that??
    not to try and get my 6'2" & 250 lb frame in there to try and get the starter out.....chiltons said i need to remove tire and wheel well...... :( parts store has one in stock life time warranty for 90 bucks.....not how i planned on spending my 1st saturday off.......wish me luck.....anyone seen this before? could it be anything besides the starter???
  14. Oct 25, 2014 at 5:54 PM
    BamaToy1997
    Bill
    Navarre, FL
    Sounds like the starter from your description in detail, unless it is a bad ground or loose cable somewhere. Did you verify that the main connection at the underhood fuse block was tight?
  15. Nov 1, 2014 at 1:52 PM
    Bino9905
    TX
    all the wires to the main fuse box off the battery are tight......i disconnected both wires off the alternator and it still did the same thing.....I changed the starter and it still did the same thing.....i put jumper cables on it with the other vehicle on.....still would not start....the second i turn the key, all power is lost.....not even the dome lights will work...i have to disconnect the battery and wait a few minutes before I can try again.....
    Any other ideas.....its been out two weeks now.....i only have time to work on it on weekends because of work....
    Thanks
  16. Nov 1, 2014 at 2:00 PM
    Lost pilot
    Lost pilot Well-Known Member
    Reid
    Nashville, TN
    04 TRD 4x4
    Front window tint, some other stuff
    ADG handle pull
  17. Nov 1, 2014 at 4:01 PM
    Bino9905
    TX
    what is adg handle pull?
  18. Nov 1, 2014 at 4:31 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Sounds like you have a dead short. The clicking you are hearing just before all goes dead is a self-resetting circuit breaker. It resets over time (as it cools). You've diagnosed the problem goes away with the starter battery cable removed...bypass that cable, run a new battery cable straight to the starter from the battery and see what happens. Better yet, remove that section of wiring harness, it's not too difficult, and see what's up inside.
    Here is the link to when I replaced mine,
    http://www.tacomaworld.com/forum/1s...retts-average-build-thread-7.html#post8203782
    something comes to mind, maybe check the 4 pin plug... mine was gone and wired straight from the PO. something to check as it's starter related.
    Edit: 4 pin plug is alternator related, still wouldn't hurt to check it.
  19. Nov 1, 2014 at 7:03 PM
    markmb45
    Mark
    Utah
    When I had this problem. I verified the battery voltage 12.7 at the battery post. 4.56 volts at the bolt/nut for the line to the fusebox. I replaced the clamp and cleaned all the lugs going to the fusebox. No problems since then. One other thing my dome light has been very dim for several months, since the repair it's working great.
  20. Nov 2, 2014 at 7:32 PM
    Bino9905
    TX
    It was the cable from battery to the starter.......wish I would have figured that out first.....but now my truck has brand new starter and I got a set of air tool....all for a 13 dollar cable failed......no external damage to cable.....going to cut it and see how it looks......thanks for the help....still not sure how a bad cable was killing power to entire truck.......
    davidstacoma likes this.
