sudden MPG boost
Discussion in '2nd Gen. Tacomas (2005-2015)' started by boogie3478, Apr 13, 2015.
  1. Apr 13, 2015 at 12:25 PM
    boogie3478
    boogie3478 [OP] Well-Known Member
    14 TRD Off-Road V6
    All the mods
    2014 DCSB TRD Offroad V6 with 5500 miles on it.
    Maybe it's a combination of my engine breaking in and no more winter gas, but for this last tank of gas I got 40 more miles out of my tank that I have ever previously had driving the same way I always do for 90/10 city/hwy miles.
    Any other possible reasons?
  2. Apr 13, 2015 at 12:27 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    It is the switch from winter blend gas to summer blend gas. Also the Temperatures are warming up so your engine is not burning as much fuel.
  3. Apr 13, 2015 at 12:28 PM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Wow that's great. I didn't think I see a gain that high between summer/winter gas blends.
  4. Apr 13, 2015 at 12:43 PM
    fulleraj
    fulleraj Well-Known Member
    ^^This.
    I can always tell when the winter/summer gas blends come in when my scanguage II registers .5-1 gallon off during a fill-up. Matter of fact, it did this about two weeks ago to me here in GA so I guess we're getting the summer blend in as well.
  5. Apr 13, 2015 at 12:43 PM
    MadDaddy
    MadDaddy Pork Rind Extraordinaire
    53 Miles West of Venus
    Many & varied
    Yeah, I'm charting similar gains here. My mileage went down as my corner station was getting to the bottom of their winter gas supply. Fresh trck arrived with (I suppose) summer blend and my mileage is increasing around 40 miles per tank.
  6. Apr 13, 2015 at 2:43 PM
    MGtaco2.7
    MGtaco2.7 MEMBER
    NW Ohio
    18 DCSB 4X4 SR5 Silver Sky Metallic V6 AT
    Holly molly, i thought I screwed up my mileage calculations. Yes, for the 1st time since I bought her she registered 21.8 mpgs. I'll take that. Thanks summer gas!!!
  7. Apr 13, 2015 at 2:59 PM
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    Mine just jumped the last fill. Warmer weather and summer gas.
  8. Apr 13, 2015 at 3:16 PM
    stphnman20
    stphnman20 Well-Known Member
    SCV
    2016 T4R
    Same here. During winter I'd get around 290-300 miles per tank. Now I get 320-330.
  9. Apr 13, 2015 at 3:21 PM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    I first noticed the 10% change in winter/summer gas around November 1995 in my last Toyota pickup...enjoy the improved gas milage. Heavy snow tires, extra four wheel drive use and winter gas have caused me to refill at the 270 mark on the tripomenter, with 265/70-17 Firestone Winterforce UV studded snows...Now I am back at the 310-320 mark. This does not include a correction for a tire 3 sized bigger than the stock 245/75-16
  10. Apr 13, 2015 at 8:01 PM
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    Why would your mileage go UP with summer blend? Down in the south this simply means alcohol blend to reduce emissions. But that LOWERS fuel mileage since alcohol only has about 2/3 the energy of an equivalent volume of pure gasoline.
    Mine gets worse, but not hugely worse. 15% of gas by volume is alcohol. But it only gives you the equivalent power of 10%. So maybe a 5% drop. 1mpg at 20mpg total, maybe.
  11. Apr 13, 2015 at 8:03 PM
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    In the north summer blends are less ethanol, high ethanol is for the winter to keep the gass freezing
  12. Apr 13, 2015 at 8:17 PM
    Pigpen
    Dan
    Northwest Montana
    Another month or more of winter blend up here...
  13. Apr 14, 2015 at 3:33 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    Temps have more impact than gas blend. When we have a warm week in winter my mpgs go up. Same gas only diff is temps.
  14. Apr 14, 2015 at 5:42 AM
    Frobozz
    Frobozz Well-Known Member
    North of Ordinary
    15 TRD/OR Access Blue Ribbon Metallic
    Tonneau, Canoe Rack
    Interesting.
    I got 19.6 mpg on a recent trip to NH, from central Maine (about 225 miles). I filled up in NH, and drove home and got 23.4. The Temp on the trip to NH, was about 45F and on the way home it was near 70F. I suppose it's also possible the gas blends were also different.
