Sudden, no symptongs before- clutch stuck engaged?
Discussion in '1st Gen. Tacomas (1995-2004)' started by mermalady, Jul 9, 2019.
  1. Jul 9, 2019 at 10:47 AM
    mermalady
    mermalady [OP] Well-Known Member
    2001 v6 4x4 with the trimmings.
    I just finished a 1k road trip through the mountains. No symptoms at all. New clutch about 15-20k miles ago.
    Parked it at night in a garage (i'm travelling for work).
    I got up in the morning started the engine, and truck wouldn't shift into gear at all. I have done various things:
    -rolled back and forth (no dice)
    -checked fluids (plenty, no foam/bubbles that I can see)
    -truck will (usually) shift in and out of gears when off. When I do that, it feels smooth.
    -no fluids under truck at any point.
    -from neutral, if I try to push it into gear, it does roll a tiny bit.
    What could be going on here? It seems so all of a sudden.
  2. Jul 9, 2019 at 10:50 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Automatic or 5 speed?
    Is the shifter stuck and can't move, or does it flop around without going into gear?
  3. Jul 9, 2019 at 10:53 AM
    mermalady
    It's a manual 5 speed. Once in gear, it won't shift into or out of gears or neutral. When it's off, it shifts smoothly. It's not floppy.
  4. Jul 9, 2019 at 10:57 AM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    When you depress the clutch pedal, do you hear/feel the throw out bearing come in contact with the pressure plate?
    I'm just asking, so don't take offense because I have seen it done on a clutch R&R, you did do a complete replacement right?
  5. Jul 9, 2019 at 11:53 AM
    MagtechPA
    MagtechPA Thor
    Pittsburgh, PA
    It does sound like the clutch might not be disengaging, or perhaps there is an issue with the master or slave cylinder. If you push in the clutch while in neutral with the engine running, can you hear the input shaft stop spinning? I know it would be tough to hear it anyway, but figured I would ask.
    Is this with the engine running and the clutch pedal depressed?
  6. Jul 9, 2019 at 1:59 PM
    mermalady
    I'll check this, thanks!
  7. Jul 9, 2019 at 1:59 PM
    mermalady
    yes.
  8. Jul 9, 2019 at 1:59 PM
    mermalady
    yes- clutch, pressure plate, bearing, flush (IIRC)
    ColoradoTJ[QUOTED] likes this.
  9. Jul 9, 2019 at 2:49 PM
    Russianman92
    Russianman92 Well-Known Member
    Dunwoody GA
    1995 White Tacoma 3RZ 4x4 5 speed
    bilstein shocks/struts Add-a-leaf Mostly stock. Running 31x10.5 r15
    Bleed your master/slave and see if it fixes it. Could have had a pinhole leak introducing air in the line and it's not disengaging all the way.
    Could be a cracked clutch fork. But you would usually feel it in the pedal since it will feel a lot lighter.
    Also, just throwing this out there but could be the clutch disk was installed backwards. This is possible that it works fine for a bit and then just fails. I will find the thread for you. Not trying to scare you but an idea as this is possible to do on these trucks.
    ColoradoTJ likes this.
  10. Jul 9, 2019 at 2:54 PM
    eon_blue
    Azusa, CA
    Happened to me, incompetent shop installed the clutch plate backward. My symptoms were basically that of a failing clutch, except instead of it happening over the course of 150k miles it happened over the course of maybe 800 miles and a couple of weeks. Difficulty getting into gear mostly, but I didn't have the trouble the OP is describing (getting out of gear)
    Not to say it can't happen though, if there's something wrong with the install who knows what kind of trouble that could cause. I would try bleeding the clutch first since that's relatively easy and rule that out
  11. Jul 9, 2019 at 3:35 PM
    mermalady
    sure, but i'd think something would have shown before 15k was put on it, wouldn't you?
  12. Jul 9, 2019 at 4:26 PM
    ColoradoTJ
    Colorado
    I would try bleeding the system.
    This is frustrating when your away from home, coveralls and most tools at home, and likely nowhere near the shop that did the work.
    Have you called the shop that did the work? Any local help? TW does have 225k members and almost never misses a chance to help a member.
  13. Jul 9, 2019 at 7:52 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 410K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    This happened to me about 3 weeks ago. Pedal would stick to the floor, couldn't get it out of gear. It came on rather sudden. Turned out my 20-year old clutch master cylinder was bad. I ended up replacing the master and slave cylinder myself (Aisin brand) for quite cheap.
    The way I diagnosed the problem is I pushed in and held the clutch pedal while observing the slave cylinder push rod and clutch fork on the transmission (you might need a helper for this, I just have a long reach). I could see the push rod extend and then a few seconds later it would retract halfway. If your clutch hydraulics are too far gone you might not even get enough push rod movement to shift into gear.
    Hamer95USA and Dalandser like this.
  14. Jul 9, 2019 at 9:23 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Sounds like a hydraulic issue - slipping clutches aren't usually going to do that at all and if it didn't go "boom" it would weird for it to fail when parked.
  15. Jul 10, 2019 at 8:09 AM
    mermalady
    Ya,
    I called the shop. They also think cylinder which I now agree with. What do you mean by local help? Shops in the area I broke down? Is there a ‘trusted list’ somewhere?
  16. Jul 10, 2019 at 9:24 AM
    jbrandt
    Justin
    "Local help" just means enlisting the TW community.
    We're a fairly friendly bunch when we aren't arguing about which ball joints to get.
    I've seen plenty of threads where people have gone out of their way (literally) to help a fellow Taco enthusiast. People often will even go out and pull you out of a ditch. Some guys have "build days" at their homes where people come by and all work on each other's trucks.
    Russianman92 and ColoradoTJ like this.
  17. Jul 10, 2019 at 10:45 AM
    mermalady
    that's rad. So where should I look for LA folks/shops? My time/money graph is just *slightly* skewed towards going to a shop :/
  18. Jul 10, 2019 at 10:47 AM
    jbrandt
    Justin
    LA Like Los Angeles, or LA like Louisiana? ;)
    Regional forums maybe. There are a bunch of so cal people around. Most of them are okay...:D
  19. Jul 13, 2019 at 10:23 AM
    mermalady
    Welp. Two days later, works fine. Bizarre.
  20. Jul 13, 2019 at 10:35 AM
    Kiloyard
    Phoenix, AZ
    This reprieve will give you time to buy a new master cylinder "just in case," Or a rebuild kit, if you like fiddling with things. I had about 5 days of intermittent, but progressively worse clutch action until it basically became undrivable. If the problem really has gone away permanently, you could return the part for a refund or keep it as a spare for when the 18-year-old master cylinder does finally go. Mine lasted 20 years.
    Rachelsdaddy and Hamer95USA like this.
