Sudden Poor Gas Mileage...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PacoPreRunner, Jan 3, 2018.
  1. Jan 3, 2018 at 9:39 AM
    PacoPreRunner
    PacoPreRunner [OP] Well-Known Member
    Dalton
    OC, CA
    06 V6 AC PostRunner
    4x4 swap, scented mirror ornament
    Hello good people of TacomaWorld. On a drive home for the Holidays, I drove from Grand Junction, CO to Boulder, CO to Dallas, TX, and I couldn't help but notice that my gas mileage very suddenly got worse. I'm the guy who sets his trip meter every fill up and scrutinizes his gas mileage (although I don't drive like a grandma). I usually get 21mpg in CO, and about 19.5mpg in TX, but recently I've been getting like 15mpg. I was a little overdue for an oil change, so I changed my oil with Castrol Edge 5W-30 and an STP filter and I haven't noticed a change yet
    ChadsPride likes this.
  2. Jan 3, 2018 at 9:40 AM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Elevation change :notsure:
    TacoCat and ChadsPride like this.
  3. Jan 3, 2018 at 9:40 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    air filter clean? throttle body clean? tire pressures not too low? were you carrying a lot of extra weight for the trip?
  4. Jan 3, 2018 at 9:45 AM
    TacomaUSA
    TacomaUSA Cross Country Tacoma
    PA
    2007 Tacoma TRD Sport 4x4 Access Cab- 6 speed
    Payload and tire pressure? Warm up the truck because its cold outside?
  5. Jan 3, 2018 at 9:45 AM
    bucktales
    bucktales *Retired* curmudgeon
    Litchfield County Ct.
    2012 TRD Sport AC / 2014 FJC/ 1972 Rally Nova
    Winter gas?
    Cold weather?:notsure:
    Mine drops a couple MPG's during Winter months.
    Pella, DanoDavis, gunn_runner and 2 others like this.
  6. Jan 3, 2018 at 9:46 AM
    PacoPreRunner
    Dalton
    OC, CA
    06 V6 AC PostRunner
    First of all @ChadsPride thanks for your unwavering support.
    There was a fair amount of additional weight on the trip (myself and my friend, our luggage, two bicycles) but not enough to warrant that dramatic of a change in MPG. I've contemplated it being the air filter. Maybe i can disconnect the battery and let the ECU reset?
    TreyStewart and ChadsPride like this.
  7. Jan 3, 2018 at 9:51 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    No problem at all :thumbsup: :hattip:
  8. Jan 3, 2018 at 9:54 AM
    PacoPreRunner
    Dalton
    OC, CA
    06 V6 AC PostRunner
    I can check the tires but I don't think they're the issue. I'm due for a rotation anyway. What's strange is that I don't notice a power loss to complement the poor MPG, which I know is purely off my judgement of how the truck feels, but it leads me to believe that I'm running rich and not bearing a bunch of extra friction, which is a good sign. It's also been 20 degree temps in Dallas the last few days, and I still get steam out of my exhaust when my truck is warm under acceleration. I don't know if that's a sign of running rich or not
  9. Jan 3, 2018 at 9:56 AM
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
    Your truck is telling you it doesnt like Dallas. Hell, i live in Ft Worth and cant stand going to Dallas! :D
    TacoMan1207 and ChadsPride like this.
  10. Jan 3, 2018 at 9:58 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    weight is HUGE.
    Lower temps, winter gas..... 15 sounds rightish..... i have been gettin 16.5 lately and it sucks.
    Norton and ChadsPride like this.
  11. Jan 3, 2018 at 9:58 AM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    Probably the winter blend gas and the extra weight
    DanoDavis, Norton and ChadsPride like this.
  12. Jan 3, 2018 at 9:59 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    usually thats just the temperature difference. If its actually steam from the engine you have problems...ie head gasket. I forget what year they quit using a replaceable fuel filter but if its one you can replace I'd check that.
  13. Jan 3, 2018 at 9:59 AM
    wilcam47
    Will
    Bourbon state
    also no CEL?
  14. Jan 3, 2018 at 10:00 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    Mine has been down ever since the winter gas came out. I bet in the spring your mileage will go back to normal, but it’s not a bad idea to check some of the above mentioned items. Engines also run richer in the cold.
    outlawtacoma and ChadsPride like this.
  15. Jan 3, 2018 at 10:02 AM
    Pigpen
    Dan
    Northwest Montana
    I'd guess you picked up some bad gas somewhere (not from Mexican food) and the ECU is confused. Let it be. Drive the tank nearly empty. The problem will likely solve itself over the course of the next tank.
  16. Jan 3, 2018 at 10:03 AM
    Pigpen
    Dan
    Northwest Montana
    As mentioned by others above, I always lose 2 mpg with the switch to winter blend fuel.
  17. Jan 3, 2018 at 10:04 AM
    ChadsPride
    I have yet to calculate my gas mileage :oops:
    EDIT: ever :bananadead:
  18. Jan 3, 2018 at 10:05 AM
    Pigpen
    Dan
    Northwest Montana
    Not the worst policy. If you go looking for problems, you'll find them.
  19. Jan 3, 2018 at 10:08 AM
    Mitch76
    Mitch
    San Angelo, TX
    He means he cant operate a calculator. :rofl:
  20. Jan 3, 2018 at 10:11 AM
    Pigpen
    Dan
    Northwest Montana
    He's newly married. His hands are busy
