Sudden Poor Gas Mileage...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PacoPreRunner, Jan 3, 2018.
  1. Jan 3, 2018 at 10:12 AM
    njfantastico
    njfantastico Well-Known Member
    NJ
    2015 Prerunner TRD Access cab full size bed in Silver
    I have been getting 18.5 mpg and that is also low for me.
    ChadsPride likes this.
  2. Jan 3, 2018 at 10:18 AM
    2004TacoBill
    2004TacoBill Well-Known Member
    I'm afraid to!.....
    wilcam47 and ChadsPride[QUOTED] like this.
  3. Jan 3, 2018 at 10:19 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    :laugh:
    2004TacoBill[QUOTED] likes this.
  4. Jan 3, 2018 at 10:24 AM
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
    Not even sure we get "winter gas" here in Texas but mine has dropped a couple mpg in the last month (2 tanks). I did change out my K&N drop in to an oem style about the same time so i just chalked it up to that.
  5. Jan 3, 2018 at 3:37 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    I agree that it is likely a combo of winter gas and lower tire pressure. When is the last time you replaced the spark plugs? Might be time for fresh plugs and a new air filter.
  6. Jan 3, 2018 at 4:42 PM
    Tacosail
    Tacosail Well-Known Member
    Jerry
    Hermanville Heights, Ohio
    '13 white ACLB
    '17 wheels,int. Wipers , bed mat , relocate trailer plug , husky floor liners , Lund nerf bars, wet Okole seat covers- heat & lumbar.
    Might not hurt to go for a little drive and check all four brakes for excessive heat. Maybe something is dragging down your mileage. Be careful when checking rotors and drums, could be very hot.
  7. Jan 3, 2018 at 4:58 PM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    15 mpgs road tripping in the winter is very typical in a Tacoma. Mileage will tank when you go over 65mph.
    I get 20-21mpgs day to day but when I road trip 15-16.
  8. Jan 3, 2018 at 7:24 PM
    PacoPreRunner
    PacoPreRunner [OP] Well-Known Member
    Dalton
    OC, CA
    06 V6 AC PostRunner
    4x4 swap, scented mirror ornament
    Wow thanks for the support you guys. Here's my plan:
    I'm going to drive till the fuel light comes on, put some Lucas Oil (sponsor me) fuel system cleaner in the tank, fill up, disconnect and reconnect my battery, rotate my tires and check pressure, and go from there. If not I'll look into doing a CAI as a means of "replacing my air filter", spark plugs, and explore other options. No CEL for me, just me worried about my truck! I'm optimistic, but i don't think that it's anything major!
  9. Jan 3, 2018 at 7:57 PM
    Pigpen
    Dan
    Northwest Montana
    Just in case you don't know, your truck came stock with a true cold air intake and the engine isn't capable of doing anything with more airflow - unless you install a high flow exhaust (or supercharger)
  10. Jan 4, 2018 at 3:35 PM
    PacoPreRunner
    Dalton
    OC, CA
    06 V6 AC PostRunner
    Well aware, I like the sound of an aftermarket intake and the way it looks under the hood. I know in terms of cost-benefit analysis it doesn't yield much/any power or efficiency but it's just something I want to do :)
    TreyStewart likes this.
  11. Jan 4, 2018 at 7:30 PM
    SixSpeedTaco
    SixSpeedTaco Active Member
    07 Tacoma TRD OR DCSB
    Nothin But Dust
    15? Im lucky if I can get 13 anywhere in-town or highway. :anonymous: Am I doing something wrong?
    njfantastico likes this.
  12. Jan 4, 2018 at 11:18 PM
    PacoPreRunner
    Dalton
    OC, CA
    06 V6 AC PostRunner
    I don't know what to tell you man. I usually get 20 on the regular, but I'm in a stock prerunner with 265/75 R16 Cooper ATP's. Where you drive, how you drive, and what you carry on your drive makes a difference. Take a look at checking tire pressure and oil condition, putting in an injector cleaner, and other stuff we've been discussing on this thread if you haven't already and you might be able to gain a few MPG's :)
  13. Jan 5, 2018 at 3:25 PM
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    So if I use straight gas (non winter mix / no ethanol ) during the winter , will my mpg go up ?
  14. Jan 5, 2018 at 3:27 PM
    njfantastico
    NJ
    That would be the common thought process, minus aliens and world peace
    PacoPreRunner[OP] likes this.
  15. Jan 5, 2018 at 3:31 PM
    #35
    igno1tus
    You got alien gas ?
  16. Jan 5, 2018 at 4:59 PM
    #36
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    Only slightly, there’s a lot of other factors than just the different blended gas.
  17. Jan 6, 2018 at 5:39 AM
    #37
    ajpagosa
    ajpagosa Well-Known Member
    SW Colorado
    2005 Access Cab TRD Off Road 6-speed manual
    This happens every winter to my 05 (and other vehicles). Consider that in addition to the winter blend gas, you have diffs, transfer case, tranny and engine oil all consistency of thick syrup until it all warms up. Grease in u-joints, hubs etc. also. Lot of snow here so 4wd vs 2wd etc. If your outside temps are cold enough and trips are shorter maybe none of that ever warms up to true operating temps.
    Once I start driving longer vs shorter distances (like driving up to the ski area regularly as opposed to just around town) mileage goes back towards normal summer levels, not completely because I'm in 4wd more often but close.
  18. Jan 6, 2018 at 6:13 AM
    #38
    DanoDavis
    DanoDavis Alright meow
    Daniel
    Allen Tx
    09 Double Cab 4x4 6-Speed V6
    1 1/2" lift with 5100's, custom exhaust, LT Headers, URD CAI, URD MAF Calibrator, Electric fan, Camper shell, retrofit projectors, and other goodies..
    Winter Gas.
    I’m in DFW, too. My MPGs dropped by about 2 once they switched to winter blend.
  19. Jan 6, 2018 at 7:41 AM
    #39
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    This guy gets it. I laugh everytime I hear oh it’s winter gas. People don’t realize it’s not the gas alone that’s causing poor gas mileage. But either way it’s the cold temps that are making your gas mileage plummet.
    ajpagosa[QUOTED] and NAAC3TACO like this.
  20. Jan 6, 2018 at 7:59 AM
    #40
    Pigpen
    Dan
    Northwest Montana
    Truth, but OP was on a road trip. Not living in a cold area.
    DanoDavis likes this.
