Suggested mods for every day comfort.
Discussion in '1st Gen. Tacomas (1995-2004)' started by _cjben, Feb 21, 2020.
  1. Feb 21, 2020 at 3:06 PM
    #61
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I know you did, and I responded there as well.
    My point is that more data isn't necessarily good, especially if that data is flawed or incomplete. I can prove to you the sky is green using incomplete/flawed data or methodology.
    But don't think I'm saying that your experiment was a failure. In science, the lack of a result is still a result. But you can't then make the leap that the lack of a result is the same thing as a negative result.
    Years ago, as a student I spent an entire week doing field surveys of an area near Mammoth Lakes mapping buried fault scarps. Turns out my data was complete crap. I had a lot of nifty looking numbers, but it was all garbage because the instrument I was using didn't have the capacity to measure deep enough in the ground. If left to my own devices I would have concluded there were no fault scarps in the area I surveyed.
    That's obviously NOT what I'm saying.
    But if you want to have some measure of confidence in your results, yeah, I think you should at LEAST consult with experts in that field, or at least do some reading and see what has been done in the past that has a similar goal to yours, and emulate that methodology.
    What you described here is precisely the scientific method. If you want to claim you're using science, that's the route you have to go.
    90% of what I do is try to break my results or prove myself wrong. Then I hand it over to other people and they do the same thing.
    We had a journalist a while back who was a really smart and well intentioned guy. He came to some colleagues about this groundwater analysis he was doing. He was trying to track the level of the water table through time by analyzing water level data from a bunch of wells. He wanted to group all the wells for this particular area together and show how the water table was changing. He was all excited about his results, but unfortunately he didn't account for the fact that the wells were drilled at different depths, and at different times, and are sometimes poorly monitored. He used our data (USGS), but all he did was plot all the water levels for all the wells. In the end, he was comparing, for example, water levels is shallow wells from the 1950's to deep wells that were drilled last year. While that seems obvious to me that's a bad way to go about it, to someone who doesn't do that type of work it's not obvious. It ended up being a great conversation because we learned more about him, and he learned why no one has really done that type of analysis before (the data to truly support it doesn't exist).
    Do you wear glasses? I noticed that I was getting really fatigued, even on my short 10 mile commute, especially at night. I finally went in and got some glasses (mostly I have astigmatism) and I was amazed what a difference that made.
    Abeyancer and Wulf like this.
  2. Feb 21, 2020 at 3:09 PM
    #62
    jbrandt
    Justin
    Says the guy who can't stand a little surface rust on his ROPE HOOKS
    :rofl:
    Kevins60 and Seagull233 like this.
  3. Feb 21, 2020 at 3:40 PM
    #63
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Good lawd this thread just became insanely boring and off topic.
  4. Feb 21, 2020 at 3:47 PM
    #64
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    These are the ones I've used for years from Costco. Only two colors but these things are so comfortable. My gal Rose actually finds my old Tacoma buckets with these skins on them MORE cozy and easier on her than the 18-way leather seats in my RX350 go figure.
    https://www.costco.com/CatalogSearc...10701&langId=-1&keyword=sheepskin seat covers
  5. Feb 21, 2020 at 4:21 PM
    #65
    jbrandt
    Justin
    Sorry you find slightly more detailed discussions about sound insulation boring.
  6. Feb 21, 2020 at 7:55 PM
    #66
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    JShawFSU, Hamer95USA, 970btu and 8 others like this.
  7. Feb 21, 2020 at 8:28 PM
    #67
    crazytacoman
    crazytacoman Well-Known Member
    Tacoman
    Taco World
    02 2.7 doublecab & 07 4.0 doublecab
    Color Wheels
    970btu and cruiserguy like this.
  8. Feb 21, 2020 at 8:30 PM
    #68
    thenodnarb
    thenodnarb Well-Known Member
    California
    2001 TRD 4x4 379k and counting
    so speaking of sound deadening... how much dynomat does one need to do the floor of an ext cab and maybe doors too? also where should one buy the stuff?
  9. Feb 21, 2020 at 8:32 PM
    #69
    1997tacomav6
    Denver
    Hamer95USA, jammer, BeLance89 and 2 others like this.
  10. Feb 21, 2020 at 8:44 PM
    #70
    jbrandt
    Justin
    I'd say go with this stuff, if it's not enough, wait a day and more will show up, lol...
    DIsclaimer: I haven't used this stuff myself, but the Amazon Collective seems to like it.
    https://www.amazon.com/Kilmat-Deade...sr_1_5?keywords=dynamat&qid=1582346409&sr=8-5
  11. Feb 21, 2020 at 10:35 PM
    #71
    mechanicjon
    Jon
    Scottsdale Arizona
    cruiserguy likes this.
  12. Feb 22, 2020 at 12:17 PM
    #72
    jonesbt
    jonesbt Well-Known Member
    Brett
    Monroe, La
    01 3.4L DC PreRunner—>4WD
    TRD Headers TRD Supercharger Custom Cavalry Blue Paint
    I’m interested in knowing more about the climate control stuff you’re talking about. Is there a thread or write up on this somewhere? This is the first time I’ve heard of it.
  13. Feb 22, 2020 at 1:51 PM
    #73
    Blue92
    Daniel
    North Carolina
    2018 Sport
    4runner climate control faceplate vs. Tacoma
    The knobs are the same way.
    jonesbt[QUOTED] and cruiserguy like this.
  14. Feb 22, 2020 at 5:46 PM
    #74
    SellyKlater
    SellyKlater Well-Known Member
    Ponce Inlet, Fl
    2004 Tacoma 3.4L Double Cab TRD
    3" ome lift 883. Fnfx pros.
  15. Feb 22, 2020 at 5:55 PM
    #75
    GQ7227
    GQ7227 mw survivor
    J A Y
    thats cool, i wish i could do that setup!
    curious if you have sprayed coating under the bottom of your truck?
    i have that and maybe why the road noise is tolerable for the most part, the exhaust and engine are about all i hear
    maybe its the type of pavement in other locations putting some bad road noise?
    there is one stretch in a certain county in my area that gets awful loud from the road noise that seems to just come in through the door and stops in the next county, luckily i don't have to drive that stretch much anymore
    i would recommend spraying underneath the cab and bed some good sound deadening stuff, see if it helps any?
    seems a much easier and less time consuming thing to do than ripping your cab apart, unless you don't mind gutting it :notsure:
    notasushifan likes this.
  16. Feb 22, 2020 at 6:06 PM
    #76
    thenodnarb
    California
    im going to do it when i swap the seats. plan to either steam clean the carpet or completely replace it. either way it will come out. currently on my road trip halfway across the country and i can barely hear the radio anymore. when i turn it up loud enough to hear it, then its too loud and hurts to listen. outs just road noise coming through the floor mostly. i think i started to notice it when i bought a landcruiser last year which is much quieter inside by comparison.
    what sound deadening can i spray on the bottom? is it a rust protectant too? i live in Cali so rust hasn't been an issue so don't really need it. but interested none the less.
    cruiserguy and GQ7227[QUOTED] like this.
  17. Feb 22, 2020 at 6:28 PM
    #77
    SellyKlater
    Ponce Inlet, Fl
  18. Feb 22, 2020 at 6:49 PM
    #78
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    That's really good spot to put stuff :thumbsup:
    970btu, jammer, cruiserguy and 4 others like this.
  19. Feb 22, 2020 at 6:52 PM
    #79
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Subbed.
  20. Feb 22, 2020 at 7:06 PM
    #80
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    That looks like a helicopter panel :D
