Suggestion for product: Plug-n-Play Harness for Hyperflash Resistors
Discussion in 'FBC Harness Solutions' started by Schmoogle, Mar 20, 2024.
  1. Mar 20, 2024 at 9:04 PM
    Schmoogle
    Schmoogle [OP] Member
    Durk
    2020 TRD OR 6-speed
    Softopper, Datin Fab Rack, Inspired Overland Carbon RTT, VLED lighting, 255/85/16 AT4W
    Hello! I installed the license plate light disable in reverse mod a little while back and I was very happy with the quality of the mod. I recently decided to upgrade my tail lights to LEDs and now suffer from the dreaded hyperflash issue.
    The solution for this has been well known for a long time: just splice in some 50W resistors for each turn signal and you're good to go. Problem is this always involves using Scotchlok quick splice connectors, which are just plain terrible. The other option involves cutting up the factory harness and doing a tradtitional splice; doable, but I don't really want to cut up the factory harness.
    I want to create a harness that would allow you to drop in between the tail light turn signal and the factory wiring harness and have spare conductors coming off the two wires needed, then those can be connected to the resistor in whatever way the user sees fit.
    I spent some time digging around to find the correct Toyota connectors to do this, though I am unsure about finding the right pins/sockets and I worry that my crimp tool may not be good enough for the job. Is this something FBC might consider developing?
    P.S. I am local to you, if the ship-from address was correct anyway. Happy to collaborate and make a solution that would help all 3rd gen owners!
  2. Mar 20, 2024 at 9:08 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Schmoogle[OP] likes this.
  3. Mar 20, 2024 at 9:10 PM
    daveeasa
    David
    PNW
  4. Mar 21, 2024 at 8:15 AM
    Schmoogle
    Durk
    2020 TRD OR 6-speed
    Well shoot, somehow I missed that on the website. Thank you! That is exactly what I was thinking.
    I also appreciate the link to the VLED conversion, that seems like a good option... I just spent $220 on Diode Dynamics LEDs and I find it a little absurd that their parts don't include a resistor built in. I still have time to return those so I may go the VLED route.
    Have a great day!
  5. Mar 21, 2024 at 8:59 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    Resistors built in are no good, bulbs with those get too hot and end up having to use safety cutoffs when the bulb gets hot beyond a certain level. Happens when you leave them on for 5 or so minutes, like using the hazards. Ends up to where you no longer have a useful hazard function on the vehicle because of using those bulbs. So, be glad the DDs and other brands aren't the type with resistors built in. But VLEDS is a better option than DD for sure, since DD offers free returns I'd do that and get the VLEDS conversion.
    Schmoogle[QUOTED][OP] likes this.
  6. Mar 21, 2024 at 9:00 AM
    daveeasa
    David
    PNW
    @BLtheP and I really like the VLED stage 1 kit I linked. I’m actually currently running the triton stage 2 brake bulbs but someday plan to swap back to halogen like @BLtheP runs. I just need to build the harness. Maybe today is the day.
    Schmoogle[OP] and BLtheP like this.
  7. Mar 21, 2024 at 9:18 AM
    Schmoogle
    Durk
    2020 TRD OR 6-speed
    Awesome, thanks! I checked specs on the Triton setup versus the DD setup, seems that the VLED conversion will be roughly the same price all in but offers better output for reverse. I have requested an RMA for DD and I ordered the VLED kit.
  8. Mar 21, 2024 at 9:21 AM
    BLtheP
    Plano, TX
    I wouldn't recommend the Triton version...not that the reds are bad, they're super bright but the switchback they provide in the Triton kit (in my opinion) is not good. The amber while advertised as the same, is worse than the normal switchback in the normal kit. The white may be better, I didn't really test that but the amber in the Triton was bad enough that I didn't want to run that one. Just my opinion and observations.
  9. Mar 21, 2024 at 9:37 AM
    daveeasa
    David
    PNW
    And I'm going off @BLtheP 's analysis since it's more extensive than my own. I care a bit less, just happy to have amber turns. I'm currently running old MESO switchbacks from @Puppypunter (thanks Johnny) or perhaps they are vled made but unbranded/rebranded? I forget. Anyway, they are pretty similar to my MESO tails only no delay with turns (I should probably double-check that).
    To me, the big gain is amber switchback turn / reverse making use of the clear bucket and a nice big C for brake, not necessarily the switch from halogen to led. The halogen bulbs seem like a perfectly fine option, are cheap and easy to replace, and make use of the reflector bucket to give a nice uniform light distribution which may be more important for brake than peak intensity. There's no getting around the need for LED's in a switchback bulb. I'm a bit on the fence about the parking light signal, on the one hand it's nice to have LED for that since it can stay on for extended periods and efficiency is good on the parking light circuit, on the other hand it's a delicate balance of intensity with parking lights, too much is annoying, too little is a safety concern. Also the larger LED bulb or the triton bulb doesn't employ the reflector properly like a halogen filament does, putting it at a disadvantage and sort of ruining whatever R&D went into designing that reflector bucket in the first place.
  10. Mar 21, 2024 at 10:10 AM
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
    Don't discount the LED illuminating faster than an incandescent can. at Highway speeds, that fraction of a second equates to about 20 ft or so. I am in camp LED myself, but I do agree on the parking lights. Even the stock bulbs don't offer enough contrast in my opinion, especially when only half the "C" lights up for brakes. I also don't like the LEDs with resistors built in. Makes it harder to do absurd things with them :rofl:
  11. Mar 21, 2024 at 11:07 AM
    BLtheP
    Plano, TX
    I do wish the incandescents were faster at illuminating, but I think the incandescents are more visible behind the red lens. The LEDs are such a darker tone that with the sun shining on the lamp, it's hard to see the LEDs when they're lit up (to me anyways). So I settled on incandescents. At least the light that alerts people the most (the 3rd brake), is LED and instant. Unless access cab.
  12. Mar 21, 2024 at 12:38 PM
    daveeasa
    David
    PNW
    Johnny and I run LEER shells so we're stuck with that crappy option unless/until Johnny gets off his ass and makes us replacement chmsl w the mini spots for chase, reverse, brake (morimoto? vled? I forget who makes those ones).
    He has like 352 prototypes of the metal, just can't make it to approved, standards too high :)
    BLtheP[QUOTED] likes this.
  13. Mar 30, 2024 at 6:31 AM
    Schmoogle
    Durk
    2020 TRD OR 6-speed
    I installed the VLED kit and I am much happier now, thank you all for the suggestions and thank you to FBC for pointing me to the ideal solution rather than just pushing a sale.
    Overall I would say the kit delivers what I wanted, which is a MUCH better reverse light and LEDs that help match my OEM LED front headlights. I always thought it was really strange that Toyota built the truck with LEDs in the front but not in the rear.
    Also the interior lights good lord don't even get me started... I found myself trying to read some mail in the truck and I was pulling out my flashlight so I could see it properly, and I realized the interior lights were on but they are just so pathetic. Highly recommend upgrading those if you haven't already.
  14. Mar 30, 2024 at 9:25 AM
    daveeasa
    David
    PNW
    Toyota actually did partial LED taillights on 2.5 gen Tacomas and I think a fair number had emitters fail. I run them in my ‘05. They aren’t super bright.
    So, it’s not all that crazy that they didn’t do an LED taillight in 2020. It could have been a nice option, for sure. But Halogen bulbs are cheap and reliable so I get it.
