Suggestion on lift. '13 DCSB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by northfloridabogge, Feb 26, 2014.
  1. Feb 26, 2014 at 4:45 PM
    northfloridabogge
    northfloridabogge [OP] Member
    Grand Ridge
    I have a 2013 double cab 4x4 and I am wanting to lift it. Ive been looking at the pro lift on ebay for $399. 3" suspension. anyone have any suggestions? Also what tire size would y'all recommend? I was wanting 18" rims with nitto mud grapplers. Any help would be appreciated?
  2. Feb 26, 2014 at 5:39 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    if your going to lift... do it right.
    at least bilstine 5100's in all 4 corners and an add a leaf. (but really a proper leaf pack would be better in the rear)
    Also note that your max on the stock upper control arm is going to be about 2-2.5in of lift before you get to where you cant adjust the alignment properly.
    Do some searching around the forums... there are like... thousands of these threads.
