Suggestion on Wheels and Tires!
Discussion in 'Wheels & Tires' started by mkuenzli, Aug 3, 2012.
  1. Aug 3, 2012 at 11:13 PM
    mkuenzli
    mkuenzli [OP] Well-Known Member
    Max Kuenzli
    Chattanooga
    11 4x4 2dr. 5-speed manual
    6' pro comp stage 1 with 35' km2s. stereo, 30% tint, 5% tint bar, 8" sub woofer, plasti dip on fenders and bottom of truck. Monroe struts, moogue tie rods, best top soft top camper top.
    i just recently installed a 3" Rough Country lift, and my 265's look to small, anyone have any suggestions on a good size tire with some rims that would be a little on the cheaper side, im a 16 year old with no job, so anything will help!:):):):):):):):):):)
  2. Aug 3, 2012 at 11:14 PM
    808TacoMan
    808TacoMan HAWAIIAN
    Lawson
    Honolulu, HI
    2018 TRD OR
    Toytec Ultimate lift Coilovers Toytec AAL No diff Drop 5% Tint all around Morimoto 2Stroke LEDS High and Low Morimoto Fog Lights MESO Key FOBs
    255/75/17 trail grapplers:D
  3. Aug 3, 2012 at 11:16 PM
    Goflight2
    Goflight2 Well-Known Member
    Southern Cal
    Supercharged 2011 4x4 LB
    TRD Supercharger Snug top SL Window Tint 5% rear, 35% front, 40% windshield Avid Off Road bolt on sliders Andres Toyota Horns Hard-wired Garmin Nav Weather Techs 5100's in front Rear TSB Bed Extender OEM Roofrack TRD Exhaust Ultra gauge 18" Monster XD's on Nitto Terra Grapplers
    275/65/18's and terra grapplers
  4. Aug 3, 2012 at 11:19 PM
    mkuenzli
    Max Kuenzli
    Chattanooga
    id like some 33's that stick out a little what size would those be
  5. Aug 3, 2012 at 11:20 PM
    808TacoMan
    808TacoMan HAWAIIAN
    Lawson
    Honolulu, HI
    2018 TRD OR
    don't get 33s just 32s. 33 will rub like a bitch on and off road
  6. Aug 3, 2012 at 11:27 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Save your money and go LT.
  7. Aug 3, 2012 at 11:32 PM
    DevL
    DevL Well-Known Member
    Do you weld? At 16 how will you pay for $2000 in gear, welding your cab mount chop, installing lift and tires, etc?
  8. Aug 3, 2012 at 11:38 PM
    808TacoMan
    808TacoMan HAWAIIAN
    Lawson
    Honolulu, HI
    2018 TRD OR
  9. Aug 5, 2012 at 8:11 AM
    mkuenzli
    Max Kuenzli
    Chattanooga
    no i don weld but i have the lift and everything installed but the 31's look wayyy to smal for it, its got a lot of clearence between the fender and tire, i can stick my head in all four fenders between the tires, the only reason i would consider not getting 285 is because i have the 2.7 so it woould be like a turtle on wheels, ya know?
