Suggestions anyone?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GLOCKAMOLE, Jan 27, 2011.
  1. Jan 27, 2011 at 11:01 AM
    GLOCKAMOLE
    GLOCKAMOLE [OP] Member
    Trip McNeely
    Acworth, GA
    09 TRD Off-Road
    Window tint, XM, Tri-fold Tonneau cover, side steps.
    Alright, so I can't take it anymore... I was planning on leaving my truck unmolested. However, I look on here often and see all of these nice trucks. It's time to get off my ass and do something. I don't want to go too crazy. Probably just a conservative lift and some wheels and tires. As far as the lift goes, I would like to maintain some sort of factory ride (not going to take it off road anytime soon), accommodate 285's, and something relatively easy to install myself. I'm looking at a budget of $2000- $2500 for both the lift and wheel/tires. Any suggestions would be much appreciated for my prospective "small penis" truck, as my friend calls it.[​IMG]
  2. Jan 27, 2011 at 11:08 AM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    bilstien 5100s and new coil springs if your interested then get a new leaf pack for the rear like some dakars from wheelers then use the rest of your money on some nice rims and badass 33x12.5 tires of your choice. problem solved with money left over for other cool stuff.
  3. Jan 27, 2011 at 11:21 AM
    GLOCKAMOLE
    Trip McNeely
    Acworth, GA
    09 TRD Off-Road
    How much would you estimate all of this to cost? Is the lift easy to install?
  4. Jan 27, 2011 at 11:27 AM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    bilstiens are cake to install or you can take the front strut assembly to a local shop and have them swap the shops for you if your uncomfortable using spring compressors, you can get all 4 shocks for a decent price.. io got mine from downsouth motorsports for less than 400 and you can get an AAL for the rear but youll have a better ride quality if you get a whole new leaf pack roughly 4 to 500 for a new pack and like 80 for an aal. if your gunna haul alot of heavy stuff id go with an AAL cause a replacement pack would be softer and not able to handle a heavy load as well etc just do some research and you can see the process for lifting the front and rear there are plenty of write ups on all that here
  5. Jan 27, 2011 at 11:36 AM
    GLOCKAMOLE
    Trip McNeely
    Acworth, GA
    09 TRD Off-Road
    Thanks for the help man. Are the leaf springs easy to swap out? I like the idea of having a softer ride, as I don't haul anything heavy.
  6. Jan 27, 2011 at 11:41 AM
    xGManx
    xGManx Well-Known Member
    Garrett
    South
    06 DC LB
    black rims, blacked out grille, blacked out exhaust tip, 5100's 1.75" with 2" rear block, pioneer head unit
    just a tip, 285's kill gas mileage, you could get 265/75/16's and still have like a 32 inch tire without destroying your acceleration and mpg, the 265's will also give like an inch more height than stock 245/70/16's...just my .02 cents, the 5100's and new coils is a good way to lift like they said
  7. Jan 27, 2011 at 11:41 AM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    not particularly, youll need a good jack and jack stands and stuff there is a write up in here somewhere about that as well and since your truck is fairly new it should be pretty easy cause you shouldnt have any seized bolts or anything but i dont think youll have a problem if your handy with a wrench. if not theres no harm asking for help, its better than paying for a shop to do something like this
  8. Jan 27, 2011 at 11:42 AM
    xGManx
    Garrett
    South
    06 DC LB
    and to install the lift with 5100's and coils you need a spring compressor, something i didnt have so i had my 5100's put on and adjusted at a garage
  9. Jan 27, 2011 at 11:42 AM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    yeah the bigger tire will kick your mpg in the ass but damn do they look good. do you plan on do any offroading?
  10. Jan 27, 2011 at 11:44 AM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    you can rent spring compressors from autozone for free i would check out your auto parts stores if you wanna go that route but coil compressors are a pain in the ass and potentially dangerous so if nyour not comfortable go to a garage for them to swap the shocks out
  11. Jan 27, 2011 at 11:45 AM
    Nick54
    Nick54 Well-Known Member
    Nick
    Mentor Ohio
    2010 Tacoma TRD Sport
    ARB Rear Locker & Compressor, Bakflip F1, Antennex 13" flexable antenna, WeatherTech Floor Liners, WeatherTech Side Window Visors, Tacoma Bed Mat, Demello Rock Crushers, Dynamax Ultraflow SS Muffler, TSB 4-Pak Leaf Springs, AFE Pro Dry Filter, Redline Hood Struts, Color Matched Angry Eyelids, Combo Lock Bed Compartments, Bed Mat, Pop-N-Lock, Wet Okoles, Goodyear Duratracs on ProComp 7033's, M101A2 Trailer, Grillcraft Mesh Grill, Light Racing UCA's, King OEM Performance Remote Reservoir Adjustable Front & Rear Shocks, JVC NT3HDT, Blue Sea Aux Fuse Panel, BAMF Behind Grill Light Bracket, Kragen 55W 7" HID's, CBI Front Receiver, Home Link Garage Door Opener, FlyEyez Light Unit, Bud Built Front to Back Skids...
    I have a question that may benifit me and the OP as well. What is the up side of replacing the coils? I have a 6mth old 2010 TRD Sport and will be installing billies to level after the rear leaf TSB and stop the rub on my new Duratracs. It's not like the tension is out of my coils.
  12. Jan 27, 2011 at 11:47 AM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    stock coils arent bad but eventally will sag, also stock coils are made just to be as good as... stock, if you get an aftermarket coil you can get stiffer springs if you want but if you get the one recommended for your truck it just improves ride quality. i ordered a set of eibach coils from toytec cause my stock coils are sagging really bad
  13. Jan 27, 2011 at 11:56 AM
    GLOCKAMOLE
    Trip McNeely
    Acworth, GA
    09 TRD Off-Road
    Thanks for the advise. The mpg IS a huge consideration, as I am only getting 16-18 as it is. Do the shocks themselves determine the height of the lift? Or do they just supplement the new spring? I see the spacer lift is probably the cheapest and easiest route, but I don't want it to ride like shit. As far as off-roading, prob not anytime soon.
  14. Jan 27, 2011 at 12:11 PM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    dont even bother with a spacer, they are cheap for a reason. get the bilstien 5100s and you wont regret it and the spring wont effect the ride height unless you get one that specifically does. i had a spacer lift cause i was broke and i needed an extra bit of lift to stop the rubbing issues i had and i regret it. it was hard as hell to install too and it rode like crap
  15. Jan 27, 2011 at 12:17 PM
    memario1214
    memario1214 Vivid Illumination Vendor
    Colton
    Gillette, WY
    05 Dub Cab TRD Sport 4x4
    Yeah, I gots boost
    Just for the sake of argument... Don't all 05+ TRD packaged trucks come with 265/70/R16 or else 265/70/R17 stock? I believe they do...
  16. Jan 27, 2011 at 1:06 PM
    GLOCKAMOLE
    Trip McNeely
    Acworth, GA
    09 TRD Off-Road
    For some reason, I was thinking the same thing. I guess that's why I was thinking 285's would be a little beefier. But all the same, if the 285's are going to kill my gas mileage, I guess I may have to stick with stock size.
  17. Jan 27, 2011 at 1:11 PM
    DOT
    DOT Well-Known Member
    Jobin
    Littleton CO
    2007 FJ
    3'' toytec lift
    you could go with 265/75 and get a little more agressive tire it would look good too
  18. Jan 27, 2011 at 1:20 PM
    cc350
    cc350 Retired Member
    265/75's will add 1/2" in height over the 265/70's what's a 1/2" worth :D
  19. Jan 27, 2011 at 1:28 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    Free - TSB
    Free - Cut mudflaps
    10.00 - Paint Rims & Grill
    150.00 - 5100 adjustable shocks
    350.00 - Bull bar / Nerf bars
    650.00 - 265/75R16 Goodyear Duratracs
    all this for under 1200 bucks, about 1 inch of lift
    no vibrations or rubbing issues, great on the highway
    awsome in the snow or mud
    and looks outstanding
  20. Jan 27, 2011 at 2:09 PM
    memario1214
    Colton
    Gillette, WY
    Yeah, I gots boost
    It will not DESTROY your mileage... Marginal loss. For me anyway, the benefits are worth the loss of like 1 mpg
