Suggestions for 2012 repairs and preventive work
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Imageoguy, Oct 28, 2022.
  1. Oct 28, 2022 at 9:23 PM
    Imageoguy
    Imageoguy [OP] Well-Known Member
    Gatineau, Qc, Canada
    2012 DCLB SR5
    Full OME suspension (885 front springs, Dakar leaf pack + OME shocks) + D29XL extra leaf + 3 deg. shim + RideRite airbags
    It's now been 10 yrs and 210k km (130K miles) since I bought my taco and it's time for some reno's but I would appreciate recommendations.
    When she was two months old, I got her an ome suspension, spc ucas, duratracs, aibags and built her a sled deck. Haven't done much afterwords, changed ac clutch twice, ac hose once, battery once, new rear axel seal (should of done air valve relocate sooner) belt wheel bearings, new antenna assembly (darn salted roads) and treated her with some BP-51's in the rear a few yrs ago. Changed spc bushings and balljoints twice under warrenty (got the greassables the second time), changed stabilizer bar link to moog greassables. Otherwise, regular maintenance at the dealership including airpump recall.
    I probably logged over 30k km on forestry roads, usually high speed, which explains my severely cracked radiator core and driver's side sheet metal. Off-roading with an atv on my deck and a few hundred pounds of rock samples in the bed (I'm a geologist) probably doesn't help either.
    My lca seized about 8 yrs ago and tire wear is now showing signs of misalignment. Thinking of keeping my truck for a few more years and getting new oem lca's with whiteline bushings, oem radiator bushings as well as welding and strengthening that front end sheet metal (got a mig). Anything else I should do while I'm at it? New cv axels? Install Ecgs bushing? New front shocks? Sensors? Just looking to keep on cruising with peace of mind when I'm 100 miles down a forestry road in the middle of nowhere :)
  2. Nov 3, 2022 at 9:21 AM
    Imageoguy
    2012 DCLB SR5
    Anyone :notsure:
  3. Nov 3, 2022 at 9:49 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    All fluids, belt.
    TnShooter likes this.
  4. Nov 3, 2022 at 10:00 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Have you checked and / or Fluid Filmed your Intermediate Steering Shaft?
  5. Nov 3, 2022 at 10:57 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Outside of the recommended maintenance schedule, do brake and PS flush, and replace pulleys/bearings. The oem LCA will come with bushings and BJ’s; I would keep it as is if you’re only having the truck a few more years, or if you can afford the downtime, refurbish what you have now.
  6. Nov 3, 2022 at 11:19 AM
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Take out and grease your cam bolts/sleeves! Just found out the hard way that over time they rust and essentially weld themselves to the LCAs making alignments impossible. My tuck is at the shop as we speak getting them cut off and replaced.
  7. Nov 3, 2022 at 3:24 PM
    zul
    zul Professional Goofball
    PNW
    2012 Pyrite Mica DCSB SR5 4WD V6 AT
    HAVE: Bed mat, Tailgate Lock, Color-matched Grille, Weathertech Floor Liners, Avid Step Rails, RokBlokz mud flaps WANT: Rear Plate Bumper, Steel bed cage
    You've replaced your battery once? Probably time for another one. I have a 2012 and my first battery change was in 2017, and my second this last summer in 2022. So for me, they last about 5 years - when was your first battery change? It may be time for a new one. And as anyone who has had a battery die on them before knows, it's far easier to change it before it dies than wait for it to die at the worst possible time.
  8. Nov 3, 2022 at 3:50 PM
    Scorchedtaco
    Scorchedtaco Well-Known Member
    AZ
    2012 ac trd 4x4 sc , 2012 sequoia 4x4
    Pcv valve , serpentine belt , coolant & thermostat , radiator cap .I’d say alternator too since they seem to last either 140k or 300k miles ,maybe drive shaft u-joints if you are bored & looking for things to do.
  9. Nov 3, 2022 at 4:08 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    This is what I’d do.
    I wouldn’t touch the Alternator or anything else until I have a problem.
    With the quality of parts these days, you might go from no problem, to a problem.
    “Fix it until it’s broke”
    Been there, done that, lesson learned.
  10. Nov 3, 2022 at 4:10 PM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Time to trade it for a 3rd gen.
