Suggestions for a 3 inch lift
Discussion in 'Suspension' started by Dockhead, Dec 5, 2008.
  1. Dec 5, 2008 at 12:08 PM
    Dockhead
    Dockhead [OP] Formarly 08TRD4X4RadientRed
    Chico, CA
    08 ACC 4X4 TRD OR
    TRD Seat covers, K&N Series 77 intake, TRD plate frames, iPod interface
    First lift and do not really know enough about them to make a decision. I would like to find a kit or site that provides all need items, or tells you what you need. Any suggestions would help.
    Thanks,
  2. Dec 5, 2008 at 2:27 PM
    dabighi
    dabighi Well-Known Member
  3. Dec 5, 2008 at 3:02 PM
    Dockhead
    Chico, CA
    08 ACC 4X4 TRD OR
    Thanks for the links. I have done some research on lifting my truck and have found spacers for the front, a diff drop kit, and aal for the rear. Is there anything else I'll need to lift my truck (shocks, ect.). Also what companies are suggested? I like the procomp aal but haven't been able to find them for my 08.
    Thanks again
  4. Dec 5, 2008 at 3:07 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    PM Neubs- He works with TOYTEC and can point you in the right direction for what parts you need based on what you want to do with the lift.
    Are you trying to lift for looks or for off road performance??
  5. Dec 5, 2008 at 3:15 PM
    Dockhead
    Chico, CA
    08 ACC 4X4 TRD OR
    mainly for looks, and drivability. I put about 50-60 miles on it a day driving to and from school and work. I like the ready lift sst package but it doesn't have an aal option. I am pretty mechanically incline and will do the install myself, and some friends. After the install I will just need to get it realigned and thats it right?
  6. Dec 5, 2008 at 3:20 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I think so...but I am in no way shape or form a suspension guy- There will be all sorts of folks along with better answers for you!!
  7. Dec 5, 2008 at 3:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Yep.
  8. Dec 5, 2008 at 3:24 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    a great kit for you would be one of toytec's 3 inch kits, one that comes with front coils and rear aal's. you can use your stock shocks with them, or get a different set of shocks that will ride comfortably. ome and bilstein both have some great shocks. and after you are done with the lift............an alignment will be needed. also.......it isnt necessary, but for total alignment, an aftermarket set of uca's is a good idea...although they are a bit pricey. you can always get those later on down the road and install them then.:)
  9. Dec 5, 2008 at 3:25 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    See...An answer SOO much better than mine!!
  10. Dec 5, 2008 at 3:35 PM
    Dockhead
    Chico, CA
    08 ACC 4X4 TRD OR
    I think I'm going to go with the TOYTEC 3 inch lift with the AAL's. I think I'll also get the Bilstein 5100. Good combo? and some UCA, hopefully for Christmas:D. What about rear shocks? (needed/not needed?)
  11. Dec 5, 2008 at 3:42 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep....to me,thats a good combo, and the 5100's ride awesomely!! the 5100's in the rear will be ok for you too, especially since you will be on the road alot with it. and the uca's are an excellent idea also.
  12. Dec 5, 2008 at 3:46 PM
    dabighi
    ya alot of guys on here are running the ome 885 front coils with the bilstein 5100 adjustable shocks and loving it. i would definately go with something along that line instead of using the coil spacers. the spacers will put too much pressure on you joints and bushings and such. especially since you have the 4x4. definately dont forget to get the diff drop kit. and alignment after you get the kit installed and after you throw larger wheel/tire combos as well.
  13. Dec 5, 2008 at 3:53 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep.......and when using the 5100's with some aftermarket coils.....keep them on the stock setting. dont preload the springs.......not needed.
  14. Dec 5, 2008 at 4:14 PM
    Dockhead
    Chico, CA
    08 ACC 4X4 TRD OR
    Do I need after market coils with the 5100 or will the stock one's be alright for now? I think it is only another 60 for the coils though from TOYTEC.
    So spacers are not the way to go with 4 wheel drive?
  15. Dec 5, 2008 at 4:33 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    the 5100's will work with the stock coils just fine man.
  16. Dec 6, 2008 at 1:03 PM
    dabighi
    ya definately stay away from the spacers. if you can afford it i would go with the ome 885 front springs from toytec. they are designed with a higher load rate that will help keep your dbl cabs front end up off the ground and level with the rest of the truck.
  17. Dec 6, 2008 at 1:14 PM
    RedTaco2134
    RedTaco2134 Well-Known Member
    Scott
    Portland, Or
    08 Long Bed TRD Sport
    295/70/17 Cooper STT Pro, Revtek 3" lift. TSB rear and Blistein 5100's http://www.cardomain.com/ride/3097063
    Handsdown- Toytech I would spend the coin and buy the UCA's at the same time. Save yourself the trouble.
  18. Dec 6, 2008 at 2:41 PM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    Doing them at the same time helps because it's easier to remove and replace the coilovers with the UCA off.
    And based on the amount you drive, I don't think you'd like spacers.
    Also, if you're looking at the OME coils and are thinking about replacing the shocks at the same time, look at the OME shocks. They are valved for those springs so they will ride a little better, but the 5100s will work with them too.
  19. Dec 6, 2008 at 4:06 PM
    RedTaco2134
    Scott
    Portland, Or
    ^^ good info.
  20. Dec 6, 2008 at 5:43 PM
    Dockhead
    Chico, CA
    08 ACC 4X4 TRD OR
    Thanks everyone for the info. Can't wait to lift my truck.
