Suggestions for All season Tires
Discussion in '3rd Gen. Tacomas (2016-2023)' started by timkins42, Jan 25, 2019.
  1. Jan 25, 2019 at 4:47 AM
    timkins42
    timkins42 [OP] Well-Known Member
    Tim
    Fishers, NY
    2021 Black Tacoma 4X4 TRD Sport Access cab
    None so far
    I have a 2017 Tacoma TRD Sport with 17000+ miles and live in western NY. With this mileage on the truck my original equipment tires are useless in the snow or slush covered roads. Looking for an All Season Radial that is not real noisy but will provide the traction needed in the snow. Any suggestions other than moving to a warmer climate.
  2. Jan 25, 2019 at 5:07 AM
    gw204
    gw204 Well-Known Member
    I've been VERY happy with the General Grabber AT2s that are on my Cherokee. I have zero complaints about them in snow (what little we get) or rain and they are remarkably quiet given how aggressive they are.
    They are a heavy tire though and my mpg was negatively impacted though.
    cfayne and mdub like this.
  3. Jan 25, 2019 at 5:25 AM
    Detn8r-Red2
    Detn8r-Red2 Well-Known Member
    NH
    2016 Tacoma SR5 DCSB
    265/75/16 Wildpeak AT3Ws, Softopper, TRD Pro Grille, Prinsu Cab Rack, bed rack, RC 2" front struts and N3 rear shocks, Supreme Suspension AAL
    Cooper Discoverer AT3 4s. I've had great luck with mine in all kinds of weather.
    Taco1.1 likes this.
  4. Jan 25, 2019 at 5:31 AM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
  5. Jan 25, 2019 at 5:40 AM
    Markc1024
    Markc1024 Well-Known Member
    I second this suggestion. Just put a set on and traction is greatly improved.
  6. Jan 25, 2019 at 5:43 AM
    Slideeslide
    Slideeslide Member
    Goodyear Duratrac! First winter here with them. Great in snow, great in rain, no louder than your stock tires.
    Flash1034 likes this.
  7. Jan 25, 2019 at 5:56 AM
    Labbi85
    Labbi85 Well-Known Member
    So when you would ask for a car which you will keep longer I would suggest the best all season tire is a summer tire for the summer and a winter tire for winter. Then you would get the best for all conditions. And because you don't wear out the tire which is not installed, you would have ideally both tires twice as long which comes to, that having two sets doesn't cost you more in the long run.
    But I am not sure if this also applies to an truck as well. Are you doing any offroading? When not than this would probably apply to you as well...
  8. Jan 25, 2019 at 6:43 AM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    One of these are going to be next on mine. Great reviews and some great threads on here
  9. Jan 25, 2019 at 7:16 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    I've enjoyed my Falken Wildpeaks A/T3Ws
  10. Jan 25, 2019 at 7:21 AM
    cfayne
    cfayne Well-Known Member
    Santa Clarita
    2012 Tacoma V6 six speed FUN
    Pro Comp wheels General Grabber AT tires
    I have these as well, and LOVE them. Good on and off road.
  11. Jan 25, 2019 at 7:25 AM
    navin r
    navin r Well-Known Member
    2017 double cab short bed trd off road 4wd w/ premium pkg.
    2nd on the general grabber at2's; 245/75-16, same height as stock, I think about 5 lbs heavier than stock but about 4 lbs lighter than KO2's. (IIRC)
  12. Jan 25, 2019 at 7:25 AM
    mdub
    mdub Well-Known Member
    Missouri
    2016 Black DBLC TRD Off-Road
    ARE CX
    I as well have been happy with the General Grabber ATX (265/75/r16 54lbs) on my 3rd gen. I had General Grabber AT2s on my 1stGen and was happy with them as well. Compared with the Firestone Destination AT's (265/70/r16 40lbs) my truck came with, i've added 56lbs of weight in tires. I'm not sure if i've taken a hit (probably have) in mpg as when I got the tires, fall/winter had set in, so gas changed and mpg takes a hit when its cold as well.
    All in all though, really happy with the way they tackled the 9 inches of snow we got a few weeks ago. They feel really solid and predictable in my OR. When I turn off TRAC/LSD in my 3rd gen AT, they perform the same as my 1st Gen MT in snow, and are hella fun but regain control right when you want them too. I don't find them to be loud for how aggressive they are either, keep them rotated and I never found cupping to be an issue, which causes a lot of road noise.
    I should note, the ATX is the replacement for the AT2's which have been retired. Not all sizes are available in the ATX at this time which is why I had to go a bit taller to a 75, but this gave me an automatic .5" lift.
