Suggestions for an aftermarket skid plate
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sirptrk, Jul 26, 2019.
  1. Jul 26, 2019 at 3:01 PM
    Sirptrk
    Sirptrk [OP] Member
    09 Tacoma SR5
    Hi, I have a 2016 Tacoma Limited. I am looking for recommendations for a after market skid plate with the access panel for the oil filter. I detest having to remove the original skid plate to change my oil. The TRD skid plate is an option but I’m wondering if there is a better choice. I don’t go off road much but do live in the country on gravel roads. Thanks for any recommendations.
  2. Jul 26, 2019 at 3:08 PM
    hoch
    hoch Well-Known Member
    Desert
    18 DCSB OR 6MT
    Do you really need a skid plate?
    If you must have one, RCI seems to be a good option.
  3. Jul 26, 2019 at 6:03 PM
    Sirptrk
    Sirptrk [OP] Member
    09 Tacoma SR5
    I think I would prefer a skid plate due to the gravel roads and tall grass that I drive thru. Granted I could probably do without but it was put there for a purpose. I just wish that Toyota had thought thru the skid plate issue and the fact that it has to be removed to change the oil. I appreciate the suggestion about RCI though.
  4. Jul 26, 2019 at 6:08 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    You could :sawzall: your OEM plate and make an access port if you don’t want a heavy plate one. Otherwise, if you want a heavier gauge plate, I went with Mobtown and really like it.
  5. Jul 26, 2019 at 6:18 PM
    Sirptrk
    Sirptrk [OP] Member
    09 Tacoma SR5
    I have thought of just cutting my own access hole and welding nuts on it. I’m a machinist so that is definitely an option. I have material readily available for a cover
    hoch and OnHartung'sRoad like this.
  6. Jul 26, 2019 at 6:22 PM
    OnePuttBlunder
    OnePuttBlunder Well-Known Member
    AZ
    2018 TRD Offroad DCSB Premium +GFC
  7. Jul 26, 2019 at 6:26 PM
    OnHartung'sRoad
    It’s a good way to go, especially if you’re just hitting light stuff.
