Suggestions for bed liner?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by toyo8696, May 26, 2013.
  1. May 26, 2013 at 5:24 AM
    toyo8696
    toyo8696 [OP] Well-Known Member
    Cumming,GA
    4X4 Sport DCSB, 2008 4R V8 AWD
    I have to get something on the bottom of my bed to stop stuff from sliding around. Any recommendations?
  2. May 26, 2013 at 5:28 AM
    Jeremy M.
    Jeremy M. Well-Known Member
    Fort Drum, NY
    13 DCSB TRD Off Road
  3. May 26, 2013 at 5:31 AM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    X2 just get a bed mat. I got one from tractor supply for like $43 and just cut it to fit.
    Also from a few posts i have read roll on/ spray on bed liners don’t stick very well to the 2nd gen beds.
  4. May 26, 2013 at 5:39 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    I did the same with the tractor supply one. It is a stall mat, very think and durable. I layed an OEM mat on top marked it and cut it in prob 10 minutes
  5. May 26, 2013 at 5:43 AM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    yeah get the 4’x 6’ stall mat.
    Sadly i did not have an OEM to trace out. i had to measure it and mark it and then cut it.
  6. May 26, 2013 at 6:23 AM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    Bed mat works great! It's been a while since I've read about it but there are issues trying to get spray in bed liners to work on our composite beds. Just get the mat.
  7. May 26, 2013 at 8:03 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    I love the bed mat... a must for our beds....
  8. May 26, 2013 at 8:51 AM
    obscurotron
    obscurotron Well-Known Member
    N. Nevada
    '14 DCSB 4x4
    Too many to list, and I've probably forgotten a bunch.
    I went with non-slip tape, like the stuff you see on edges of outdoor stairs. It's like 200 grit sandpaper strips (black) with an adhesive backing. Put that on the raised ridges of the bed and stuff no longer slides around.
  9. May 26, 2013 at 8:54 AM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Another vote for a bed mat. I got the dee zee brand.
    Plus it's removable if you need something to slide in the bed.
  10. May 26, 2013 at 12:47 PM
    andyzx6r
    andyzx6r Well-Known Member
    Atlanta
    Super White TRD Sport
    Definitely bed mat. Got mine from Toyota for 100 dollars. Well worth it.
  11. May 27, 2013 at 5:23 AM
    toyo8696
    Cumming,GA
    I will check with my dealer in the morning. I also have a Tractor Supply store up the road from me, I'll see what they have today.
    Thanks guys!
  12. May 27, 2013 at 5:48 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    Thats a great idea... I would probably opt for the rubberized non slip tape but I am sure this works very well, and a cheap mod to boot! :cool:
  13. May 27, 2013 at 6:26 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    I use a super heavy duty outdoor carpet. I got it from a flooring distribution
    warehouse.
    It's super thick with a rubber back (the black you see in the picture is the bottom of the tailgate section) & a checkerboard texture on top. It was cut to fit the bed liner in my old '95 PreTaco so it doesn't quite cover everything, but it works great.
