suggestions for cover/cap/rack please
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RoyB, Oct 22, 2008.
  1. Oct 22, 2008 at 2:35 AM
    RoyB
    RoyB [OP] Well-Known Member
    Chicago burbs
    '09 TRD DC Sport
    My original plan was to get a cap and have a rack of sorts on top of that. However, the added weight, decreased visability, high prices, and less mpg is kind of turning me off from it. I am thinking about a hard tonneau cover now with a roof rack on the cab. What do ya'll think?
    I need to carry 10' conduit and maybe a 6, 10' ladder sometimes.
    would a cab rack be able to carry this stuff ok?
  2. Oct 22, 2008 at 4:30 AM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    :DI have almost the same setup that you have; I have a soft roll up cover, with a Thule roof rack set up.
    The ladder is not a problem, but when you talk about the 10ft conduit, it is depand on the size, if just 3/4 or 1" conduit, it will not be a problem, but if you talk about the 4" or extension ladder, you will have to get this thing, see link below, this can help you carry the conduit, and this is what my set up. http://www.thuleracks.com/product.asp?dept_id=10&sku=997
    I am a electrician, and I have to carry extension ladder to do my work sometimes, and the Thule rack system do help me out a lot.:D
    Hope this can help you out.
  3. Oct 22, 2008 at 5:09 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    Here is a pic of my cover, (old shot before lift etc) the cover is an Undercover. It is the hard type, as for the other options.......well can't help there, but I am sure someone here will have a great idea mod.
  4. Oct 22, 2008 at 5:36 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    I've got a BakFlip cover and it's garbage. Now, it is a first gen model and they've released their second gen which I've heard is better.
    It's nice because it's low profile, but the thing just fell apart on me within 1 year in Arizona. I've still got it on the truck, but just because I can throw my golf clubs in the back and lock the tailgate. If I didn't golf, I'd get rid of it and look for something else.
  5. Oct 22, 2008 at 6:09 AM
    Scooter
    Scooter Canadian Member
    Manitoba, Canada
    08 Double Cab TRD Sport Short Box
    Pop n Lock Power Tailgate Lock, Bak Flip Tonneau Cover, Factory DLR installed, Defrost with A/C Off, EZ Down Tailgate Damper, Code Alarm Security System with Remote Starter, Rear Spring TSB, Ming rust proofing & paint treatment, 3M fabric protector, Cargo Mat, Scanguage II, DYI Illuminated 4X4 Switch, Versa-Gate box extender & cargo divider, Toyota Roof Rails, Grom USB Audio adapter with bluetooth, LED Bed lights, OEM Backup Camera with LCD Display Mirror
    I have a Bak Flip G2 (for generation 2) tonneau cover. The first generation ones are garbage because the rubber hinges deteriorated and the thing fell apart. I called their 800 number and actually talked to Ivan, the owner of Bak Industries. He's very helpful. I heard that if you have a G1 cover, he'll send you replacement G2 hinges with instructions on how to replace them. It's worth a try.
    I really like my tonneau cover. It does not change the look of my truck, and is secure. You have to get a Pop-N-Lock for the tailgate. The tailgate must be opened to unlatch the cover from the underside. Some people like to be able to open the tonneau cover without opening the tailgate. I prefer this because I don't need an extra set of keys, and there is no lock on the cover, leaving it clean looking. That's just a matter of choice.
    What I really like about it is that it flips completely up against the back of the cab so you have access to the entire box. That is important to me, because I have a 5' box, and I want to carry bicycles in a bike rack in the box. The other thing I really like is that the entire cover removes by unscrewing two knobs.
    I originally wanted a hard roll up cover like a Pace Edwards, or Roll Bak, but the cansiter and the leading edge of those covers take up over 12" of the front of the box. Other hard flipping covers must be completely removed to get full box access. If I am travelling, and find a good buy on something that requres me to remove the cover to use the full length of my box, what am I going to do with my cover?
    I wanted a hard, secure cover that gives me full access to the box without removing it. Bak Flip met those requrements. The fact that it completely removes in about a minutes is a bonus. My two complaints are: The corners of the ends of the side rails are rough and could have been finished a little better, and you lose the use of the box rails because the tonneau cover rails cover them. The first complaint can be fixed with a file. For the second complaint, I am thinking of bolting some Unistruts on top of the cover rails so I can use the cleats that came with the truck.
  6. Oct 22, 2008 at 6:14 AM
    Delmarva
    Tucson, AZ
    12 Tundra TRDRW
    My cover is deteriorated beyond just the rubber hinges. The cover is warped -- imagine a King size mattress that a 600 pound guy has been sleeping on for the past 10 years. He gets up and there's a fancy little "V" groove in the middle. That's what mine looks like (please pardon the exaggeration). The latches have chipped and the the "pull cord" for releasing the latches has come out past the covers.
    I've given up on it -- lol :D
    I did try getting a new one from Bak, but they only offered a 5% discount, so I decided to save my money and eventually get a snugtop shell.
  7. Oct 22, 2008 at 6:41 AM
    Scooter
    Manitoba, Canada
    Too bad about your Bak Flip.:( I did get a good laugh imagining that 600 pound guy. Now I've got to get that picture out of my head! lol :)
    I hope my Bak Flip does not see the same "V" groove fate as yours. How long have you had yours?
  8. Oct 22, 2008 at 6:51 AM
    smokey28723
    smokey28723 Member
    Cullowhee
    08 TRD Offroad
    ARE Camper
    I have an ARE fiberglass cap with a Yakima rack on it. It isn't a problem to haul 10' ladders or lumber. It is nice to be able to carry your tools and not have to worry about rain or theft. I was thinking about a cover, but a couple of my tools (tablesaw, mitre saw) would not fit under the cover. The cap only weighs around 120lbs and have not noticed a significant decrease in mileage.
  9. Oct 22, 2008 at 6:58 AM
    lsocoee
    lsocoee My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I really doubt that you'll want to carry a 10' long piece of conduit supported with just the roof rack. If you are going to need to do that, you should look into getting one of these http://www.etrailer.com/pc-CCHE~TH997.htm It attaches to your trailer hitch and raises level with the rack on your cab.
  10. Oct 22, 2008 at 7:01 AM
    Delmarva
    Tucson, AZ
    12 Tundra TRDRW
    I've had mine for about 2.5 years now... I've heard the G2 is much better, so hopefully you'll be OK.
  11. Oct 22, 2008 at 7:54 AM
    SHunter080703
    SHunter080703 Well-Known Member
    Right now I have an Access Roll-up bed cover. In the next few years I plan on getting a Leer bed cover.
  12. Oct 22, 2008 at 2:28 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    Check out the Bakflip CS.
    http://www.bakliner.com/cs-tonneau-rack-cargo-system.htm
  13. Oct 22, 2008 at 3:08 PM
    RoyB
    Chicago burbs
    '09 TRD DC Sport
    holy crap, i didnt even know something like that existed- thats EXACTLY what i need!
    any pictures of said cover? I have an 09 so pop-lock is not available yet since we have the cameras there.
    any closer up pictures? how is visibility and security?
    just like wing posted! thanks.
  14. Oct 22, 2008 at 3:13 PM
    RoyB
    Chicago burbs
    '09 TRD DC Sport
    i didnt realize thats what the backflip was. are they lockable? only come in black? I like the sleek look of a single piece, but the versatility of the ones that fold.
  15. Oct 22, 2008 at 3:22 PM
    Delmarva
    Tucson, AZ
    12 Tundra TRDRW
    they don't lock, however the mechanism to open the cover is located underneath the rear panel, which means you have to open the tailgate to latch the cover open.
    You could lock the tailgate handle with a pop'n'lock, however I guess they don't make one to deal with the tailgate camera just yet.
  16. Oct 22, 2008 at 3:22 PM
    Evil Monkey
    Robert
    Escondido, CA
    They're lockable if you put a pop-n-lock latch on the tailgate (~$50 for the keyed or $99 for the electric). They only come in black.
  17. Oct 22, 2008 at 3:28 PM
    RoyB
    Chicago burbs
    '09 TRD DC Sport
    do the electric ones need any space that they keyed ones do? the camera on the 09s is where the key normally goes on these things.
  18. Oct 22, 2008 at 3:39 PM
    Evil Monkey
    Robert
    Escondido, CA
    I don't think so but I'm not certain. I have a keyed one and no backup camera. Is it possible to remove the camera lens and move it to another location?
  19. Oct 22, 2008 at 8:23 PM
    wing103
    Boston
    Hi, RoyB
    The pop & lock they do not have the lock for 09, but the Dynolock dose, I have it install on my 09 Tacoma.
    do a search in this forum, you will see my post, search for tailgate lock. you will see it. Also I post some photo when I do the installation.
    It will lock & unlock when you lock up your doors, it hook up to the factory wiring.
    http://www.dynolock.com/trtalo.html feel free to ask me the question of this lock, I install it, took me about total of 3 hours.
  20. Oct 22, 2008 at 8:33 PM
    RoyB
    Chicago burbs
    '09 TRD DC Sport
    awesome, thanks wing. i was hoping i could find something like that. i hate carrying around extra keys all the time.
