Suggestions for tracing water related slow battery drain?
Discussion in '1st Gen. Tacomas (1995-2004)' started by travelfeet, Jul 29, 2014.
  1. Jul 29, 2014 at 5:35 AM
    travelfeet
    travelfeet [OP] Well-Known Member
    Andrew
    Troy, NY
    02 xtra 4x4 v6
    We have had 2 days of Monsoon weather, several inches of rain, and 50 mph winds at times. Having not driven my truck for those days I went to start it this morning and only got click click click....
    The battery still had some juice, but not enough to start (bat looks in very good shape, came with truck though so I don't know how old it is)
    The truck jump started OK and after a 15 min drive to work it restarted. I'll see if I am stuck here at lunch though...
    I surmise some connection got wet with the crazy weather and drained the battery. I have no idea how to trace this though.
    Any known weak points for a water related short in a first gen?
    Thanks.
  2. Jul 29, 2014 at 5:39 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    How old is the battery?
  3. Jul 29, 2014 at 5:53 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    your battery just gave you a warning....drop by an autozone, advance or O'reilly's and have a load test done on the battery...
    my bet is you need a new one...
  4. Jul 29, 2014 at 6:08 AM
    welterbf123
    welterbf123 Well-Known Member
    Columbus, OH
    2017 TRD Off Road
    12voltsolutions.com plug-n-play remote start system. OVTuned OEM Bed lights Underhood and footwell lights Garmin dash-cam Weathertech side vents, bug shield, mud flaps and floor mats Extang Encore tonnau cover OME BP51 Suspension Front & Back / Dakar Leaf Springs Light Racing UCA's XD Holeshot 17" x 9" Wheels Nitto Trail Grapplers 265/70/R17 TRD Pro Grille Raptor Lights iJDMToy 30" LED Hidden Bar Light Toyota Bed Step
    I replaced the battery in my 1st gen twice in the ten years that I owned it and I never got any warning at all! It just died! That being said, if it is a short somewhere, it is a very difficult problem to troubleshoot. You have to start from the battery and work your way back until you find it, and even then, how do you know that you've found it? Good luck!....
  5. Jul 29, 2014 at 6:30 AM
    Tinmann
    Tinmann Well-Known Member
    NorCal
    ^^^ What he said.
  6. Jul 29, 2014 at 8:17 AM
    travelfeet
    Andrew
    Troy, NY
    02 xtra 4x4 v6
    My gut says its not a bad battery, but I don't know how old it is, just that it has worked great for the past year, and doesn't look old.
    I appreciate your input.
  7. Jul 29, 2014 at 10:22 PM
    Aught2TaCO
    Aught2TaCO Well-Known Member
    Troy
    Wheat Ridge, CO
    '02 Taco TRD, aka Pearly
    Billie 5100's, new leafs, Falken WILDPEAK A/T 3W, 265/75/16E
    Have you cleaned your battery connections? Make sure the battery posts and cable leads show shiny lead. And then get a load test done just to be sure. Hope this helps.
  8. Jul 30, 2014 at 3:39 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
  9. Jul 30, 2014 at 3:42 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    X3
    Batteries these days don't give us much warning.
  10. Jul 31, 2014 at 6:46 AM
    travelfeet
    Andrew
    Troy, NY
    02 xtra 4x4 v6
    Interestingly I had just cleaned the terminals and coated with dialectic grease last weekend.
    I had to leave town for 2 days, and didn't have the time to test the battery. I just bought a new one and swapped it out. Fired right up after sitting 2 days, so it was the battery. Best case scenario I supposed, but it sure was sudden. The last 2 batteries that dies on my (one massive AGM in my diesel Mercedes and a standard one in the Honda I wrecked before buying my taco), both gave me lots of warning (months) when they started crapping out.
    Thanks again.
  11. Aug 2, 2014 at 11:53 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    Even with a new battery and a healthy charging system, I would check the parasitic (key off) load on the battery. Please see Section 10 in the Car and Deep Cycle Battery FAQ on www.batteryfaq.org for more information and troubleshooting.
    Brie likes this.
