Suggestions on cleaning catalytic converter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pinktaco808, Jul 25, 2019.
  1. Jul 25, 2019 at 10:52 AM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    My friend truck throwing code. Peep saying for clean it. Suggestions on what too clean flush it clean it?
    It says dirty cat
  2. Jul 25, 2019 at 12:55 PM
    cromag27
    cromag27 THE insurance expert - licensed in all 50 states
    dexter morgan (matt)
    phx-ish
    2011 trd off road dcsb
    KY_Rob likes this.
  3. Jul 25, 2019 at 2:24 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    IDK if the V6 has one, but the I4 had a recall on the cats. I just had mine replaced last week fo free.
  4. Jul 25, 2019 at 3:14 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Replace cats. Quit being cheap
    pinktaco808[OP] likes this.
  5. Jul 25, 2019 at 3:18 PM
    Bigc2029
    Bigc2029 Well-Known Member
    Caleb
    2019 Midnight Black TRD Off Road 4x4
    RC 2' Level kit, TRD Pro Wheels, Bumper ends.
    OP is that English?
    Larzzzz, Lawfarin and Toywoodsguy82 like this.
  6. Jul 25, 2019 at 3:24 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
  7. Jul 25, 2019 at 3:53 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Clogged catalytic converters typically aren't cleaned, they're replaced. Once a cat gets clogged the exhaust is able to superheat the catalysts inside, melting/fusing them together and creating a more significant blockage. There is no saving it; it must be replaced.
    KY_Rob and pinktaco808[OP] like this.
  8. Jul 25, 2019 at 4:06 PM
    pinktaco808
    Nice price 515 for one cat
  9. Jul 25, 2019 at 4:26 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    As others said, there's no saving the cat.
    What's the actual code? "Catalyst efficiency below threshold"? You can get "spark plug anti-fouler" fittings at some auto parts stores. Use them to space out the rear O2 sensors away from the exhaust stream. This will buy your friend some time.
  10. Jul 25, 2019 at 4:27 PM
    eon_blue
    Azusa, CA
    If you live somewhere without smog testing you can get cheaper aftermarket cats, but they don't last nearly as long as OEM ones do.
  11. Jul 25, 2019 at 4:59 PM
    Bigc2029
    Caleb
  12. Jul 25, 2019 at 7:19 PM
    Taco'09
    Taco'09 Well-Known Member
    OP, providing the honeycomb is not broken or the cat otherwise damaged the cats can often be cleaned using common chemicals. But you got to use the RIGHT STUFF. This is one of the best DIY out there to save a bunch of $$$$ but is not well known. See this thread and also my Post #31 onward in that thread for the specific mix:
  13. Jul 25, 2019 at 8:07 PM
    pinktaco808
  14. Jan 15, 2020 at 9:45 AM
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    Nobody likes a dirty kitty
