suggestions on my 96 reg cab
Discussion in '1st Gen. Tacomas (1995-2004)' started by gold96taco, Jun 18, 2011.
  1. Jun 18, 2011 at 6:20 PM
    gold96taco
    gold96taco [OP] Well-Known Member
    Dillon
    NC
    96 regular cab 4x4 tacoma
    k&n air filter, tinted windows and tail lights, 3" toytec springs, 2" toytec AAL, AEM intake and 6000k HIDs
    about to get a 2.5" spacer lift for the front to level it out, any suggestions on tires and sizes. want to go as big as possible of course and as cheap as possible :) would like to get new rims but cant afford it right now so just got the stock 15x7s i think is the size. and if anybody has any tires they want to get rid of with good tread left let me know!!
  2. Jun 19, 2011 at 2:12 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Southern New Mexico
    2018 Tacoma TRD Off Road 4x4
    Probably your biggest size would be to run 33/12.50/15's. But that depends on the offset of your rims.
    I have 265/75/16's and I only have enough room for my hand to fit between the tire and a-arm, and my tires fit under the wheel well. But when i switch back to my 15 inch rims with only a 9.5 inch wide tire the tires stick out at least an inch from under the wheel well because of the negative offset.
    As for pricing on tires, if you're wanting to find some locally you're just going to have to look around. I was about to get BF Goodrich A/T's for a little over $800. But I just recently found a place that sells GT Radial MT's for the same price.
  3. Jun 19, 2011 at 4:32 PM
    gold96taco
    Dillon
    NC
    do u know what kind of offset i would need to fit 33's? i was thinking about going with 265/75 cuz i wasnt com[pletely sure i could fit 33's
  4. Jun 19, 2011 at 4:36 PM
    PcBuilder14
    Brent
    Southern New Mexico
    I honestly couldn't tell you, because the 15 inch rims I have came with the truck so I don't know the exact amount of offset they have, but I'm sure some of the more experienced members might know the answer to your question.
    As for the 265/75's, they will fit without a doubt, because I had mine on without any lift and only had minor rubbing when fully turned
  5. Jun 19, 2011 at 4:38 PM
    gold96taco
    Dillon
    NC
    ok cool i might go with the 265's just to play it safe or if i can find some 285's i could test out to see if they'll work
  6. Jun 19, 2011 at 4:41 PM
    PcBuilder14
    Brent
    Southern New Mexico
    Yeah, if you have any buddy's with an 6 lug chevy running large tires you could set them up on yours to see how they fit.
  7. Jun 19, 2011 at 7:36 PM
    gold96taco
    Dillon
    NC
    ok thanks, ride too stiff? why didnt u like it?
  8. Jun 19, 2011 at 7:37 PM
    gold96taco
    Dillon
    NC
    and what did u use to get all the chrome on the front blacked out?
