Suggestions on Progressive front shocks needed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jboudreaux1965, Jan 14, 2025.
  1. Jun 4, 2025 at 3:46 PM
    #61
    TomHGZ
    TomHGZ Well-Known Member
    2014 TRD Frankensport 4x4 AC AT
    Partial list: Vagabond Drifter 3rd Gen OR rear axle 4.30 gears Bilstein 6112s and Tundra 5160s.
    In the rear, even 2” of lift with aftermarket leaf packs and longer shocks can necessitate longer brake lines.
  2. Jun 4, 2025 at 5:14 PM
    #62
    jboudreaux1965
    jboudreaux1965 [OP] Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    No for sure not me. I wanted to concentrate on more travel without sacrificing down travel and run over little washboards smoothly. I was always pro higher spring rate when you add weight and want lift. My 2nd gen has 810lb springs on Dobinsons Digressives, then before that IronMan Digressives.
    For comparison I put some Bilstein digressives in the rear. The difference is obvious. Speed bumps are good test. If you hit one at speed and there is a more sudden jolt then feels like the front wheels drop off the backside then your running Digressive shocks and your down travel is being limited because your spring rate is too high.
    Offroad I have found no benefit to Digressive shocks, I do not see why most manufacturers go that way.
  3. Jun 4, 2025 at 5:20 PM
    #63
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
