Suggestions: Shocks to Pair with TSB Springs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brandob9, Sep 4, 2009.
  1. Sep 4, 2009 at 3:22 PM
    brandob9
    brandob9 [OP] Well-Known Member
    Brandon
    Portland, OR
    09 DC Long Bed
    Soundproofed cab, beeps purged, bed lights, extra bed tie-downs and TSB springs.
    Hi -
    My dealer, Beaverton, is in the process of installing the TSB spec rear springs on my SR5 DC LB as I write. However, because I'm not under the TSB, they won't do the shocks as well.
    Do you have any suggestions on what to put in the rear?
  2. Sep 4, 2009 at 3:25 PM
    imsikotic
    imsikotic If u cant stand behind our troops. Stand in front
    Randy
    Temecula, Ca
    06 TRD Sport DesertRunner
    4" Camburg Race Spindles and Icon 2.5" ext travel Coilovers in the front for about 5"of lift and for the rear All-Pro 3" leaf pack and Fox 2.0 Resi's converted to piggyback and custom valved by DownSouth Motorsports. 17x9" KMC XD Addicts w/ 4.5 inch Backspacing and -12 Offset. Wrangler Duratracs 285/70/17. K&N CAI, Exhaust, Carriage Works Billet Grill, Custom Bed bar with ProComp fog lights,DirtKing Fabrication front bumper w/ 3 HID converted Hellas, Demello rear PreRunner bumper, Tinted windows, Full System w/ 2 10s, Garmin 265WT, ClearHLM. Theres more I just cant think of it right now.
    Fox, Bilstein 5100s, Sway-a-Way, Icon
  3. Sep 4, 2009 at 4:26 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    What's wrong with the original shocks?
  4. Sep 4, 2009 at 4:28 PM
    brandob9
    Brandon
    Portland, OR
    09 DC Long Bed
    I was making the assumption that the new spring rate and the old shock rates weren't going to be very compatible. Am I wrong?
  5. Sep 4, 2009 at 4:31 PM
    r12rex
    r12rex Well-Known Member
    Cleared headlights, Black emblems, Painted black valence on front bumper, 2.5" 5100 Billys front, 1.5" AAL rear, Satin black TRD O/F wheels with 265/75 16 Definity M/T, Spidertrax spacers
    You could keep the stock ones on now. I would suggest OME (Old man emu) shocks for all four corners. :)
    Kind Regards,
  6. Sep 4, 2009 at 4:39 PM
    Janster
    Jandy
    Lancaster, PA
    There's really no such thing as pairing shocks with springs for a daily driver, daily usage pickup truck. You can put whatever shock on that you wish. It's not that critical.
    I have a TRD Sport and I got the TSB springs. They never changed my shocks.
    The fact that you're getting the TSB springs will make a world of a difference in how it handles regardless of changing shocks or not. Don't waste your money on new shocks unless you want new shocks. If Toyota pays for them....then YES! But otherwise, keep your money for other mods!
  7. Sep 4, 2009 at 4:44 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    How much you paying for the pair b.t.w. Brandob9? I'm considering the 4pack setup.
  8. Sep 4, 2009 at 4:46 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    the springs are the biggest difference. the bilsteins shocks are more for off road applications but not needed. the springs will probably raise the back end a inch to inch and a half. i went with the bilstein adjustable 5100's up front to level the truck back up.
