Suggestions?
Discussion in 'Suspension' started by dunkhi, Jan 5, 2009.
  1. Jan 5, 2009 at 8:31 PM
    Neubs
    Neubs Sold my Tacoma. Goodbye TW.
    Maryland
    06 TRD Offroad DC 4X4
    ToyTec 5100 Bilstein Adjustable Coilovers w/ Eibach Springs | OME Darkar Leaf Springs | 5150 10" Bilstein Rear Shocks| Light Racing UCAs | All Pro U-Bolt Flip Kit | Timbren Rear Bumps | Extended Stainless Steel Rear Brake Lines | ARB CKMA12 On-Board Air Compressor | Method 16" Race Wheels | Goodyear 285/70/16 MTR | 48" Hi-Lift Jack | ToyTec Diff Drop | Warn Hitch Shackle | TRD Cold Air Intake | PIAA Intense White Bulbs | PIAA Silicone Wipers | Toyota Bed Mat |Sockmonkey Graphics | 20% Tint | Sport Hood | Scan Gauge II & Blend Mount | Shrockworks Sliders | ARB Bumper | Warn M8000 Winch | Viking Synthetic Winch line | 12-Volt Guy In-Dash Winch Controller | Viking Delrin Rollers | Daystar Winch Isolator| ARB/IPF 900XS Lights | Weather Tech Liners | Rock Lights | Diff Breather Mod | Extra Bed D-Rings | Misc. LED bulbs throughout
    Hmmmm, I would go with the AAL in the rear opposed to a block and a set of adjustable coil-overs in the front. If you can't afford the adjustable coil-overs then I would go with longer springs like the OME 885s or Eibachs, or a sets of Bilstein 5100s. :)
  2. Jan 5, 2009 at 8:33 PM
    Neubs
    Maryland
    +3 Looks good. :)
  3. Jan 5, 2009 at 8:38 PM
    dunkhi
    dunkhi [OP] CSULB socal
    Craig Sirois
    Southern California. Fountain Valley
    09 Ivan Stewart
    Toytec Coilover kit. Bilstein's 5100. Alcoa Wheels. General Tires. Magnaflow Cat-back. BLHM. Yellow fogs. 13TW5 jl sub. Stewart Decals.
    hmm or do u think the light will be okay
    cause these are the mediums.
    but i dont have any after market addons yet cept for exhaust.
    but i plan to be getting some addons in the future.
    do u think the 2nd link would be okay even tho theres not much extra weight?
  4. Jan 5, 2009 at 8:44 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah...i would go with the second link. the med. coils help with added weight of the double cab itself. i think this one will be better for you than the kitwith the light coils...but its ultimately your call.
  5. Jan 5, 2009 at 8:49 PM
    dunkhi
    Craig Sirois
    09 Ivan Stewart
    well thanks for the help guys i decided on the medium.
    just in case i do add a bull bar or hella lights int he front someday.
  6. Jan 5, 2009 at 8:51 PM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    FWIW, the bull bar and lights won't add enough weight to make a difference. The medium springs are necessary just for the weight of the cab itself.
  7. Jan 5, 2009 at 9:01 PM
    dunkhi
    Craig Sirois
    09 Ivan Stewart
    sounds good
  8. Jan 5, 2009 at 9:04 PM
    dunkhi
    Craig Sirois
    09 Ivan Stewart
    oh ya one more question will it work on a 6-lug? ive read some stuff saying it only works on 5 lug?
  9. Jan 5, 2009 at 9:07 PM
    LonghornTaco
    Minnesota
    Yeah, it will. But, you have it backwards - most things won't work on the 5-lug, but WILL on the 6 lug.
  10. Jan 5, 2009 at 9:12 PM
    dunkhi
    Craig Sirois
    09 Ivan Stewart
    ohhh silly me
  11. Jan 6, 2009 at 8:24 PM
    Neubs
    Maryland
    +1 This is good advice. + What LongHornTaco Said.
  12. Jan 6, 2009 at 8:44 PM
    Downsouth Motorsports
    Downsouth Motorsports Downsouth Motorsport Vendor
    Lakeside, Ca. 92040
    2017 4-Runner Dirt King Long Travel King 2.5 Coil-Over / 2.5 Bypass Front and Rear ICON Rear Upper and Lower Arms ICON Rear 2" Springs 34" x 10.50" x 17 Toyo Tires on 17" x 9" RaceLine Wheels
    The best bet as far as price wise and performance are the Bilstein front Pre-Load adjustable struts and the Deaver mini pack for the rear followed up with the Bilstein 5100's!
    The Deaver Mini pack gives you the lift but replaces the O.E. dense springs that are made for towing , loads, ect - they add a few progressive rated springs that increase wheel travel and ride quality. Basicly the mini pack keeps the main spring which is a light rated spring, then adds the progressive secondary spring - so you are only riding on as much spring as you need at that time. As the spring flexes it cycles thru the pack- unlike the factory springs that are very dense and end with a stout overload spring used for towing.
    Better yet is there replacement set of springs that are not too expensive but incredable ride and 12 to 13" of true useable wheel travel!
  13. Jan 6, 2009 at 8:51 PM
    Lakeside, Ca. 92040
    The front replacement springs have a heaver load rating- so they lift the vehicle by adding spring weight, which intern decreases ride quality. The Replacement Bilstiens have height adjustments that utilize the factory progressive rate spring. So instead of adding a dense big spring with a factory shock- Bilstiens R&D dept. developed a nitrogen replacement front strut that not only gives you increased ride height, but also gives you a nitrogen filled monotube shock. Night and day difference in ride quality!
    And they are inexpensive!!!
  14. Jan 11, 2009 at 11:22 AM
    dunkhi
    Craig Sirois
    09 Ivan Stewart
    oic i'll have to look at that but for now on med front coils and AAls in the back.
    i have bilsteins 5100's already btw.
  15. Jan 11, 2009 at 6:15 PM
    #35
    PaulVthe3
    PaulVthe3 Well-Known Member
    I was looking at the medium toytec med. with AAL lift myself for my 09 dc v6 4wd non trd, but will I need the diff drop kit and UCA's?
  16. Jan 11, 2009 at 6:17 PM
    #36
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    uca's arent absolutely necessary, but definitely help..........but diff drop definitely. cheap insurance!
