Summit Expedition Trucks Ltd. - NA Produced Trays for Midsize Trucks
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ralf, Dec 13, 2020.
  1. Dec 20, 2020 at 12:41 PM
    #41
    Ralf
    Ralf [OP] Summit Expedition Trucks Ltd.
    Ralf
    Fort McMurray, AB
    '17 TRD Off-Road
    ARB Summit Bar Safari Snorkel
    For those that were curious, I've added the approximate weights to the main post, as seen here;
    APPROXIMATE WEIGHTS:
    5ft Trucks
    - 295lbs Base Configuration
    - Side Gates 30lbs
    - Tool Boxes 35lbs
    - Drawer 80lbs
    - Water Tank (empty) 10lbs
    Complete configuration - 450lbs~
    6ft Trucks
    - 330lbs Base Configuration
    - Side Gates 40lbs
    - Tool Boxes (rear) 35lbs
    - Tool Boxes (front) 30lbs
    - Drawer 80lbs
    - Water (empty) 10lbs
    Complete configuration - 525lbs
    Gunshot-6A, Fleischwagen and Shveet like this.
  2. Dec 21, 2020 at 10:25 AM
    #42
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    In case it doesn't include it, taking off the factory bed and bumper saves you about 250 pounds.
    NukedTaco and Ralf[QUOTED][OP] like this.
  3. Dec 21, 2020 at 10:30 AM
    #43
    Ralf
    Ralf
    Fort McMurray, AB
    '17 TRD Off-Road
    Correct, that did not include the weight of the factory box removed.
    I'd still like to weigh the factory 5ft box, but that number sounds very accurate for the factory 5ft, and my guess is 275-280lbs for the 6ft version.
    With that being said, the decks will add 200lbs~ for these trucks which is very reasonable.
    Gunshot-6A[QUOTED] likes this.
  4. Dec 22, 2020 at 8:58 AM
    #44
    amag413
    amag413 Well-Known Member
    Aaron
    Philly
    2014 Black Tacoma TRD Sport | Double Cab SB
    JD Fab 2.25 kit, Homemade flatbed, Four Wheel Camper
    @Ralf Do you have a picture of the actual product?
    Looks like this is a ute tray with some dress up added.
    Would love to actually see a US built product like this!
    Also, did I read that correctly that the base tray, without the under tray boxes or drawer will be $7000? or does that include those items?
    What would the benefit be of purchasing your tray over the ute ltd? I believe they retail for around $2617 for a similarly optioned tray.
    Would love to hear your thoughts on this!
    Ralf[OP] likes this.
  5. Dec 22, 2020 at 9:00 AM
    #45
    Gunshot-6A
    Conner
    Everett, WA
    Well its gonna be built in Canada per OP so...
    NukedTaco and Shveet like this.
  6. Dec 22, 2020 at 9:03 AM
    #46
    amag413
    Aaron
    Philly
    @Gunshot-6A works for me! Thats a lot closer than Australia!
    Thanks for picking up on that minutia, super helpful...
    Gunshot-6A likes this.
  7. Dec 22, 2020 at 9:04 AM
    #47
    Gunshot-6A
    Conner
    Everett, WA
    I'm an accountant. Minutia is my whole career field :rofl:
    NukedTaco likes this.
  8. Dec 22, 2020 at 9:10 AM
    #48
    amag413
    Aaron
    Philly
    @Gunshot-6A Well then maybe you can comment on my questions regarding the large price difference between this and a similar product instead of trolling?
  9. Dec 22, 2020 at 9:12 AM
    #49
    Ralf
    Ralf
    Fort McMurray, AB
    '17 TRD Off-Road
    Working on the explanation right now, one moment :)
    Shveet likes this.
  10. Dec 22, 2020 at 9:15 AM
    #50
    amag413
    Aaron
    Philly
    @Ralf Thank you sir, looking forward to it. love the idea just want to know a little more about it!
  11. Dec 22, 2020 at 9:43 AM
    #51
    Ralf
    Ralf
    Fort McMurray, AB
    '17 TRD Off-Road
    Correct, what you're seeing was an existing product with finishing touches. This was going to be the initial route, but it's proven to be more difficult than anticipated to do so. So instead, we will be producing our own ground up product.
    When comparing pricing for the base tray; the trays you see for $2617 do not include lighting, do not include a finished bumper, do not feature one-piece fenders, uses plastic hinges and latches, and require quite a bit of DIY. Those trays also don't allow for a tool boxes or a drawer to be added, without serious modification. The other note is, as you can see in my pictures, is that type of tray sits extremely low and reduces off-road articulation. Additionally, their mounting brackets don't allow for a drawer either, which I did not like. We started with the Ute tray to see if it would work, and simply put, it's cheap for a reason.
    The benefits of our tray will be the following;
    - Designed and manufactured in Canada, short lead times and immediate customer service
    - Full aluminum construction, no rust, and can be painted however you like.
    - Easy bolt on installation, all hardware included
    - LED lighting, with plug and play connection
    - Stainless steel latches, hinges, and tie downs
    - Finished bumper
    - Excellent tire clearance
    - Single piece fenders with mud flaps, and options for larger fenders for this with bigger tires
    - Exterior tie down rails, either side
    - 10 interior, flush mount tie down rings (12 for the longer wheel base trucks)
    - Fuel filler relocation kit
    - Dual tire carry head board
    - Modularity; optional tool boxes, drawer, and water tank can be added at any point, whether at point of purchase or a year later. There's no required up front commitment.
    - Tray sides are optional, since some customers won't require them, so we left them out.
    - Shipping throughout Canada and the USA is reasonable, and right to your door.
    - Won't require a shop to install this unless you choose to. Can be easily installed in your driveway. Basic tools required only.
    These are all features that really set us above the other brands. So for $7,000 USD you get a whole lot more, and there's always the option to add the additional without having to buy the complete kit unlike other brands. We took out all the headaches; one product, no additional hardware or runs to the automotive store required.
    Now we are working on a sub $7,000 option, so less features, but can still accomplish a similar end result. Still modular, but without the interior tie downs, a blank headboard, things like that.
    Expected finish product to be ready for end of January.
    That being said, this one you see here, with the tool boxes and bumper will be for sale soon too.
    I hope this helps clarify things :)
    Shveet and Gunshot-6A like this.
  12. Dec 22, 2020 at 11:11 AM
    #52
    amag413
    Aaron
    Philly
    @Ralf thats exactly the kind of info I was looking for! Thanks for taking the time to answer those questions. Seems like a very cool idea and I cannot wait to see the final product.
    I assume since the shipping is reasonable, that these units will be bolt together and flatpacked? Maybe a fully welded tray with a bolt on headboard?
    look forward to seeing your company progress and for the pictures of the completed project!
  13. Dec 22, 2020 at 11:30 AM
    #53
    Ralf
    Ralf
    Fort McMurray, AB
    '17 TRD Off-Road
    Absolutely, any further questions, feel free to ask! You are correct, fully welded, with a bolt on head board. This has proven to work well, and can always be welded at delivery, but isn't necessary. I definitely appreciate any feedback or things folks would like to see as far as features go! Going to accommodate what we can!
  14. Dec 31, 2020 at 11:00 AM
    #54
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    watching 4wd Action's newest video on Shauno's build.
    interesting way to hide the gas cap without it hanging out, figured to share some ideas for the gas cap location.
    does a quick tour here; https://youtu.be/jlNCzS04P6M?t=158
  15. Dec 31, 2020 at 12:03 PM
    #55
    Ralf
    Ralf
    Fort McMurray, AB
    '17 TRD Off-Road
    This is a nice way to tuck it away :thumbsup: We're looking at offering a base model flatbed that doesn't have a headboard, for those guys that want to run a fulltime canopy or camper. So the fuel filler has been a topic of focus to ensure a clean mounting either way. I do like this one, so thank you for giving me something to take into consideration :muscleflexing:
  16. Jan 16, 2021 at 10:23 PM
    #56
    Ralf
    Ralf
    Fort McMurray, AB
    '17 TRD Off-Road
    jameskhana, Gunshot-6A and Shveet like this.
  17. Jan 17, 2021 at 6:26 AM
    #57
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    Ralf[QUOTED][OP] likes this.
  18. Jan 18, 2021 at 11:10 AM
    #58
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Silhouette shows the tray on an Access Cab? :notsure:
    Shveet[QUOTED] and Ralf[OP] like this.
  19. Jan 18, 2021 at 11:16 AM
    #59
    Ralf
    Ralf
    Fort McMurray, AB
    '17 TRD Off-Road
    Everyone’s seen that we can do our products with short chassis, 5ft box trucks. We’ve been working hard on the production model, and here’s our first glimpse of what it will look like! Presented to you, the 6ft box variant for Access Cab Long Box and Double Cab Long Box trucks! We are also show casing just how modular our product is!
    From first to last.
    • Base Deck, ideal for full time canopies or full time camper units
    • Base Simple, includes a standard head board
    • Base Plus, includes head board, interior tie downs and side gates
    • Tourer, includes head board, tie downs, side gates and rear under tray boxes
    • Expedition, includes head board, tie downs, side gates, front and rear under tray boxes, center rear drawer and center front water tank
    These are designed to be utilized with Toyota Tacoma’s, Ford Ranger’s, Chevy Colorado’s, GMC Canyon’s and Nissan Frontier’s! They measure in at 86" overall length (2" for the headboard and 84" for the deck length), and 72" wide. Every flatbed will come with plug and play wiring, one piece fenders with mud flaps (standard option for 33” tires, with options to upgrade to accommodate up to 40” tires), back-up camera relocation, bed plug relocation, back-up sensor relocation and trailer connector relocation.
    Any questions? Send us a DM and we’ll be happy to answer! Pricing will be live shortly!
  20. Jan 18, 2021 at 11:36 AM
    #60
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Sweet Jesus hold my beer
