Summit Racing rims help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sage, Mar 4, 2012.
  1. Mar 4, 2012 at 1:36 PM
    Sage
    Sage [OP] Well-Known Member
    SoCal
    07 TRD Sport
    So i just got some summit racing rims that are 16" please tell me that these will fit my 2nd gen .. I was going to run maxtrac 4" and was told that 16" would work..
    http://www.summitracing.com/parts/SUM-185-6884P/
    I was told these would fit by summit as well does anyone know if these will work
    :confused:
  2. Mar 4, 2012 at 2:04 PM
    Sage
    SoCal
    07 TRD Sport
    bump
  3. Mar 4, 2012 at 2:06 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Summit is a good company. I doubt they would lie to you. post up the bolt patern and back spacing numbers
  4. Mar 4, 2012 at 2:09 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    they are in his first post
    OP they should fit on a stock tacoma.....
    WTF is maxtrrack?
  5. Mar 4, 2012 at 2:15 PM
    Sage
    SoCal
    07 TRD Sport
    6 x 5.5 in. Bolt Circle, 4.875 in. Backspace
  6. Mar 4, 2012 at 2:16 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Like im going to open the link? please
  7. Mar 4, 2012 at 2:17 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    New spindals? How much lift do they give?
  8. Mar 4, 2012 at 2:22 PM
    Sage
    SoCal
    07 TRD Sport
  9. Mar 4, 2012 at 2:22 PM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    4 inches. I have them on mine now...
    Also if I understand correctly that backspacing should be 4.75 at minimum... Most run 4.5 bs.
  10. Mar 4, 2012 at 2:23 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
  11. Mar 4, 2012 at 2:29 PM
    XXXX
    sKiP
    05 Prius
    your kidding I hope
  12. Mar 4, 2012 at 2:33 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Sarcasism for me not opening it:rolleyes:
  13. Mar 4, 2012 at 2:40 PM
    Sage
    SoCal
    07 TRD Sport
    Soooo. my orignal question is this going to fit or am i going to have a problem
  14. Mar 4, 2012 at 2:46 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    I haven't opened the link yet, but, are they hubcentric or lug centric wheels? I think you also need new lugs. Not sure hopefully one of the wheel gurus will chime in.
    looks like they will fit tho.
  15. Mar 4, 2012 at 3:17 PM
    Sage
    SoCal
    07 TRD Sport
    lug centric i guess not to familar with that...
    it says hub centric= no
  16. Mar 4, 2012 at 3:24 PM
    Sage
    SoCal
    07 TRD Sport
    what does that mean
  17. Mar 4, 2012 at 3:27 PM
    nfs257
    DFW
    She gone
    Our rims are hub centric meaning the rims centers on the hub and the hub takes the weight. Lug centric means the hub and rim dont touch usually and the lugs take all the weight.
  18. Mar 4, 2012 at 3:33 PM
    Sage
    SoCal
    07 TRD Sport
    shit so does that mean that these rims will not work......
  19. Mar 4, 2012 at 3:34 PM
    nfs257
    DFW
    She gone
    They might with the conical lug nuts that center the tire. Buy I am NOT sure on the Backspacing as I posted above...
  20. Mar 4, 2012 at 4:01 PM
    Fiveology
    Fiveology Well-Known Member
    MD
    11 DC TX PRO 4X4
    3" Lift OME 885's with a top plate spacer in front, Toytec AAL in rear, OME Nitrochargers, DWreck/FamousFab bolt on sliders, 255/85R16' KM2's
    Won't work, center bore is too small. Need a wheel with a center bore of 106.1mm or 4.177 inches.
