Sumo springs and off road flexing test
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Jun 25, 2016.
  1. Aug 22, 2016 at 1:29 PM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    TRDPro75 likes this.
  2. Aug 22, 2016 at 1:30 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Thats why he didn't want to lift his truck too high.
    Fat girls can't jump.
  3. Aug 22, 2016 at 1:31 PM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    :rofl:
    AR15xAR10 likes this.
  4. Aug 22, 2016 at 3:04 PM
    sabercoug
    sabercoug Well-Known Member
    San Antonio, Texas
    2016 Tacoma TRD OR DBSB 4x4 tech pack w/jbl Quicksand
    I just installed these today. As mentioned, install is pretty easy.
    FYI, you need a 19mm deep socket to loosen/remove the nuts on the u-bolts.
    I did a quick test drive and it seemed to ride a little better. I'll know more when I tow a trailer tomorrow.
    2016_dbag likes this.
  5. Aug 22, 2016 at 3:09 PM
    BaconPower
    BaconPower Well-Known Member
    Portland, OR, USA
    2013 Double Cab 4x4 TRD Offroad
    I'm concerned that the top surface of the polyurethane will get chewed up pretty quickly by rubbing on the metal brace above which is not flat.
  6. Aug 22, 2016 at 4:14 PM
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    Sumos vs Timbrens vs Wheelers superbumps vs airbags vs AAL vs Hellwig helpers vs Supersprings, the debate rages on. Which is a good thing.
    IronPeak likes this.
  7. Sep 26, 2016 at 8:54 AM
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    So if these are extended bump stops, how does it give you that much static lift? It doesn't look like it rests on the frame when unloaded.
  8. Sep 26, 2016 at 9:27 AM
    AR15xAR10
    Mine rest on thw frame
    scottalot likes this.
  9. Sep 26, 2016 at 5:53 PM
    Swiftks
    Swiftks Well-Known Member
    Spring, TX
    2016 TRD OR
    Bilstein 6112 (front) Bilstein 5160 (rear) Headstrong Progressive AAL ShiftSense Pro SumoSprings BakFlip F1 Tonneau Cover BAMF Grille aFe intake w/ scoop Custom Exhaust - URD Y-Pipe, Vibrant Ultra Quite Resonator & MagnaFlow Muffler 4Runner TRD Pro 17" Wheels Wrangler DuraTracs - 265/70R-17 Redline Hood Struts OPT7 LED Headlights (Highs & Lows) Baja Designs Squadron Pro Fog Lights LED Interior Lights Total Chaos Bed Stiffeners TRD Pro Skid Plate TRD Pro Tail Lights TRD Pro Shift Knob @CBoy808 Custom Bedside Decals FormulaOne Pinnacle Window Tint OEM Tacoma Bed Mat OEM Tacoma All Weather Floor Mats Fumoto Valve Amsoil Fluids
    The frame does rest on them and they add 5/8" to the rear without load.
  10. Sep 26, 2016 at 7:23 PM
    GPsevinSixx
    Ros Angerus
    I see, a progressive elastomer spring. Thanks guys.
  11. Nov 30, 2016 at 4:05 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Should help quite a lot
    Byb127 likes this.
  12. Nov 30, 2016 at 4:21 PM
    nevadabugle
    nevadabugle [OP] Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    I agree.
    Byb127 likes this.
  13. Jun 21, 2017 at 10:24 AM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    I'm going with the -40 product code. Thanks for the info
  14. Jun 21, 2017 at 12:43 PM
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    Interesting. Does it still add a mild lift even with a add a leaf installed already? Might be a good way to get a 1/2" more?
  15. Jun 21, 2017 at 1:11 PM
    #35
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    No. It only adds lift for stock height springs. If you have an AAL you will have a gap between the Sumo Springs and the frame. It will, however, still keep you from sagging when you add weight to the rear or if you tow.
  16. Jun 21, 2017 at 3:37 PM
    #36
    Swiftks
    Spring, TX
    2016 TRD OR
    ^^^This^^^ have about a 1/2" - 1" gap between SumoSprings and frame with a progressive 3 leaf.
  17. Jun 21, 2017 at 10:03 PM
    #37
    nevadabugle
    Elko, NV
    Not me. Mine still contacts with a three leaf. But I have a steel rear bumper and R TT on bed bars.
  18. Jul 7, 2017 at 7:12 AM
    #38
    ryan89p
    ryan89p Member
    CO
    '10 2.7 5sp 4x4
  19. Oct 8, 2020 at 9:38 AM
    #39
    JoBroTACO
    JoBroTACO Jobrotaco IG
    Joey
    Yuma AZ
    2013 TACO 4x4 4 cyl 5spd
    All pro Bumper and Armor SPC Control Arms King stock OEM RR X 4 Ironman 4X4 leafs Superbumps front #1500 sumosprings rear Sway bar delete Larger than average balls Lower than average intelligence
  20. Oct 8, 2020 at 10:18 AM
    #40
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    Myself will go with Timbren-Industries bump stops. Got Timbren on our Honda Pilot (rear only) and a front and rear set on our E350 Motorhome.
