Sumosprings for stock and lifted 2nd gens
Discussion in '2nd Gen. Tacomas (2005-2015)' started by IronPeak, Sep 7, 2016.
  1. Sep 7, 2016 at 8:27 PM
    IronPeak
    IronPeak [OP] PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    I am in the market for taller rear bumpstops. I have been considering using sumosprings as my rear bumpstop, they look to be about 6 inches tall (not sure), and compress 50%-80% ? of the blue foam part, not the total height. Some people without lifts use these in place of airbags. But what if you are lifted?
    <<<<Please add pictures to this thread if you have sumos installed, with or without a lift.>>>>
    From supersprings website:
    Available in both front and rear applications for most trucks, vans, buses and motor homes the SumoSprings Solo is a more comfortable, progressively-engaging suspension bump stop. They are typically larger than the original equipment to initiate earlier contact. The cushioned effect inherent in the urethane material promotes smooth engagement. This combination creates a more comfortable ride.
    Low range sells a flip kit with a sumospring as well . You can buy the spring alone as well, and the shorter one, and perhaps attach it to the frame bumpstop landing pad above the axle, .
    This is the tacoma specific kit.
    It is an alternative to airbags and raises the rear of unlifted tacomas by 5/8". It makes constant contact with the axle and frame on unlifted trucks. .
    http://autoplicity.com/8069740-super-springs-ssr-610-40-sumosprings
    Here is just the foam part from the tacoma specific model
    https://www.amazon.com/SuperSprings...&qid=1473711140&sr=1-69&keywords=Supersprings
    And these ones, for the tundra, but they fit a tacoma. rated for 1500#, the ones above are 1000# they are black and I'm assuming they are of a harder durometer.
    http://autoplicity.com/8069741-super-springs-ssr-610-47-sumosprings
    This is low ranges flip kit, and boy is it good lookin!!
    http://www.lowrangeoffroad.com/toyo...lts-by-low-range-off-road-tsp-bs-ssf-kit.html
    These are just the spring from the low range flip kit
    http://autoplicity.com/8069634-super-springs-ssf-106-40-sumosprings
    And These models look like they MIGHT be added to pre drilled flip kits
    http://autoplicity.com/8069737-super-springs-ssr-403-40-sumosprings
    http://autoplicity.com/8069712-super-springs-ssr-210-40-sumosprings
    http://autoplicity.com/8069736-super-springs-ssr-402-40-sumosprings
    https://www.amazon.com/SuperSprings...3705961&sr=8-4-spell&keywords=tacoma+bumpstop
    These plus allpros flip kit could be a less expensive alternative to the low range flip kit, if these do indeed fit, to be determined.
    Part # SSR-610-40 the tacoma specific model for non ubolt flipped trucks measures 5" or 6" tall measured from the axle, and have a 4" diameter. The blanks disk on the bottom is 4" in diameter.
    Reports have this model at 4 5/8ths" tall when installed on a stock truck, as they are slightly compressed. This makes sense as they give 5/8ths lift, and part of the sumo is squished.
    The sumosprings for the low range flip kit are reported to have a 4" height, diameter 3.5", per low ranges thread These, like other sumos, can supposedly compress 80%
    https://www.tacomaworld.com/threads...op-rear-u-bolt-flip-kit.422286/#post-12483979
    Please add pics and thoughts, whether you have them on a lifted truck or not, any input is welcome, thanks , auggie
    Anybody have these with dakar springs?
    scottalot, patbegley and AR15xAR10 like this.
  2. Sep 7, 2016 at 8:31 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    For that price why wouldn't you just go with Timbren?
    scottalot and AR15xAR10 like this.
  3. Sep 7, 2016 at 8:32 PM
    IronPeak
    AuggieX
    Back to Back
    It's my understanding that timbren bumps are hard rubber and very rigid, the sumos, like superbumps, are made from close cell foam that compresses
    scottalot likes this.
  4. Sep 7, 2016 at 8:35 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
  5. Sep 7, 2016 at 8:35 PM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Never seen that autoplicity place before.
    The cheapest place i could find sumosprings was Amazon for $212
    Shit for$165?! I'm ordering them right the fuck now
  6. Sep 7, 2016 at 8:36 PM
    AR15xAR10
    BEAT YOU TO IT
    scottalot and IronPeak[OP] like this.
  7. Sep 7, 2016 at 8:36 PM
    IronPeak
    AuggieX
    Back to Back
    Ya I just found that price> best I've seen, 20 in stock
  8. Sep 7, 2016 at 8:36 PM
    T4RFTMFW
    Too many people get Timbren's and then swap for Superbumps for me to drop the coin on them.
    Not really into that love or hate experimentation.
    scottalot, IronPeak[OP] and AR15xAR10 like this.
  9. Sep 7, 2016 at 8:37 PM
    T4RFTMFW
    I tried.
  10. Sep 7, 2016 at 8:38 PM
    AR15xAR10
    Thanks bah
  11. Sep 7, 2016 at 8:38 PM
    AR15xAR10
    Bout to be 19 when that cart loads
  12. Sep 7, 2016 at 8:39 PM
    hoarder23
    Shay
    NJ
    Scratches
    I've got superbumps and have no complaints but they are much shorter then sumosprings or timbrens
  13. Sep 7, 2016 at 8:40 PM
    IronPeak
    AuggieX
    Back to Back
    What lift do you have in the rear?
  14. Sep 7, 2016 at 8:41 PM
    diablo_Alex2777
    diablo_Alex2777 Well-Known Member
    Alejandro Gonzalez
    Mira Loma
    05 tacoma dcab Trd off road. 4x4
    Icon UCA's,coilover, Demello front,rear bumper All-pro 3in rear leaf spring Miler maker m8000 winch\ 33's coopers stt's Demello's skip plate 3 hellas 500's
    I have the sumo Springs. I might sale them. No longer need them.
    scottalot and T4RFTMFW like this.
  15. Sep 7, 2016 at 8:42 PM
    IronPeak
    AuggieX
    Back to Back
    What lift , and Why and what are you replacing them with?
  16. Sep 7, 2016 at 8:43 PM
    AR15xAR10
    Ordered.
    $170.78
    Thank you so much. Saved me $48
  17. Sep 7, 2016 at 8:44 PM
    IronPeak
    AuggieX
    Back to Back
    :cheers:Mine are in the cart, they let me to order thru Amazon, same price.....waiting for more feedback/ measurements
    scottalot and AR15xAR10[QUOTED] like this.
  18. Sep 7, 2016 at 8:47 PM
    hoarder23
    Shay
    NJ
    Scratches
    Dakars, 11" travel Icon smoothbodies, armortech shackleflip, all-pro ubolt flip with wheeler's superbumps. Bad things have to happen before the bump stop hits.
  19. Sep 7, 2016 at 8:48 PM
    IronPeak
    AuggieX
    Back to Back
    Isn't the bumpstops job to prevent bad things (shock bottoming out) before they occur? Or you are so sprung it's unlikely ?
  20. Sep 7, 2016 at 8:51 PM
    hoarder23
    Shay
    NJ
    Scratches
    Yeah but unless I'm jumping my truck or super off camber the shocks don't get close to bottoming out, and I don't plan on jumping my truck anytime soon. I drive slowly over rocks.
