Sun roof leaks?
Discussion in '4th Gen. Tacomas (2024+)' started by Lexpd1145, Oct 17, 2024.
  1. Oct 17, 2024 at 3:38 AM
    Lexpd1145
    Lexpd1145 [OP] Active Member
    Charlie
    24 TRD Sport
    I have been watching to see if anyone else is having similar issues with the sunroof leaking. I have no problems with just rain, but the car wash is another matter. I do consistently have a small leak when I go through the car wash. I have also noticed on the back power window I will have a few drops of water on the inside of the window after the wash. The truck is going in soon for its first service check and I plan to bring it up but was curious if anyone else had a similar experience. I have also noticed on the roof, the piece of trim that sits at the back of the roof line seems to have some pieces of it that have chipped off? I can't really tell but I will take a few pics and post them in another thread.
  2. Oct 17, 2024 at 3:51 AM
    pushgears
    pushgears Well-Known Member
    2021 OR DCSB MT
    Depending on the type of car wash you use, the dryers at the end of the tunnel can flex the windows and even push a few drops of water through.
  3. Oct 17, 2024 at 3:58 AM
    Lexpd1145
    Charlie
    24 TRD Sport
    That is a strong possibility on the back window. I have noticed the sunroof is prior to the dryers and during the high-pressure wash portion.
  4. Oct 17, 2024 at 9:05 AM
    Johnsl
    Johnsl New Member
    Before I traded it for a 2024 Taco SR5, I had a 2012 Highlander. It developed a leak around the sunroof also. Turned out it was just a plugged up weephole for water drainage. Borrowed my son's compressor and blew it out gently. Problem solved! (It did take a minute to find the opening hole though).
  5. Oct 17, 2024 at 10:12 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The Owners Manual for my 2017 says not to use car washes if you have a sunroof, guessing the 24 says something similar.
    Stevie17 likes this.
  6. Oct 17, 2024 at 10:47 AM
    Lennyz1
    Lennyz1 Well-Known Member
    Len
    2024 TRD Sport Premium Hybrid 4x4 Bronze Oxide
    My RAV4 will get a little water in the sunroof when I run through the touchless carwash. The high pressure/high volume water will get through at the right angle.
  7. Oct 17, 2024 at 2:34 PM
    Lexpd1145
    Charlie
    24 TRD Sport
    Thanks for the responses all!
