Sunk my rear end for about 10 minutes... how urgent is a rear diff fluid change?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DruncanIdaho, Jun 17, 2025 at 1:34 PM.
  1. Jun 17, 2025 at 5:22 PM
    Darty03
    Darty03 •‿•
    2021 Tacoma TRD Off-Road V6 AT
    Just pull the fill plug and dip your finger in the oil like said. Why make a big deal out of changing it if it is clean? Sure change it when you can to be safe but if you drove it more than a mile it is going to be mixed and have a hazy milk look to it or be full on mud colored so it should be obvious.
  2. Jun 17, 2025 at 5:27 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  3. Jun 17, 2025 at 7:40 PM
    JR_Roams
    JR_Roams Well-Known Member
    2002 Tacoma TRD-OR EXC 5MT
    Grandmas been around long enough to know you don't go into a water filled mud pit without some extended breathers and not wait 3 weeks to do a simple lube job.
  4. Jun 18, 2025 at 10:28 AM
    TacoGranny
    TacoGranny Well-Known Member
    2020 TRDOR DCSB Cement 6MT
    33's, Sliders, Skid Plates, Softopper, ATH rear bumper
    I'm always curious why we don't see more diff failures if this is the case, how many trucks are used to launch boats dozens of times a year? Are these people adding diff breathers or checking their fluid after every launch? I seriously doubt it.
    SR-71A likes this.
  5. Jun 18, 2025 at 10:45 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    I think very few people submerge their diff when launching. I’ve been launching my various boats for 50 years and never submerged the diff. Actually one time I did but I was launching from shore and not a launch ramp. Wheels went in a hole and the back of the truck was pretty deep. It was an old Ford, nothing affected that truck.
    Jakerou and amyracecar like this.
  6. Jun 18, 2025 at 10:53 AM
    JR_Roams
    It's more of a possibility than a high probability. The physics of it are definitely true. The negative pressure needs to exceed the axle seals, how hot the diff is to start and the temperature it cools to are the variables that need to be just right to create enough vacuum.
  7. Jun 18, 2025 at 11:36 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    You'll be fine till you can flush it. Let us know if you find any evidence of water when you get around to it
  8. Jun 18, 2025 at 11:38 AM
    HelloFelix
    HelloFelix Well-Known Member
    Felix
    Las Vegas
    2017 MGM 4x4 OR Tacoma
  9. Jun 18, 2025 at 11:42 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Just a bit of friendly advice- if your 4wd doesn’t engage anymore in a couple weeks, check the transfer case actuator - it may have flooded from the fun and its internal parts are corroded.
    Chew, PzTank and amyracecar like this.
  10. Jun 18, 2025 at 7:11 PM
    MGMDesertTaco
    Good way to trash the rear drums there. Clean them thoroughly asap.
  11. Jun 18, 2025 at 7:15 PM
    Darty03
    Darty03 •‿•
    How is that going to trash the rear drums? The mud and water will drain out and they will be fine.
  12. Jun 18, 2025 at 7:55 PM
    MGMDesertTaco
    Dirt and pebbles will make their way inside the drum and scuff up the shoes and score the drums.
