Sunroof drain issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Moriarti2001, Mar 20, 2023.
  1. Mar 20, 2023 at 9:14 AM
    Moriarti2001
    Moriarti2001 [OP] Well-Known Member
    Cali
    2016 Tacoma Sport
    Yep
    Hey all,
    So I have gone round and round on this water issue, and with the steady rain here it is clear that I have a passenger side sunroof drain issue.
    I have snaked the drain tube repeatedly and it seems to be clear, but the issue keep going back.
    That leads me to believe that I have clogged "pinch welds" as suggested in this video.
    https://www.tacomaworld.com/threads/sunroof-drain-cleaning.521548/
    My question for all of you is, does anyone have a god method for inspecting and cleaning said "pinch welds" on the undercarriage?
  2. Mar 20, 2023 at 5:44 PM
    Moriarti2001
    Cali
    2016 Tacoma Sport
    Yep
    I was able to fix the problem with hot water and coated baling wire.
    rtzx9r, Speedfreak and ktbell444 like this.
  3. Mar 20, 2023 at 6:11 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    OP solved his problem with quality elbow grease! TW failed to respond in quality suggestions or in snid comments! Jeesh :annoyed:what is going on around here!!!
    Nice work @Moriarti2001 , any idea what was plugging up the drain?
    Moriarti2001[OP] likes this.
  4. Mar 20, 2023 at 6:22 PM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    So if you have bllocked su roof drains what size tires “can” you fit on a Tacoma?
    LoCal247 and Speedfreak like this.
  5. Mar 20, 2023 at 8:02 PM
    Moriarti2001
    Cali
    2016 Tacoma Sport
    Yep
    Thanks ! I am stoked because we have more major rain headed our way. I am not exactly sure what the blockage content was made of, but I am guessing a mix of dust and vegetative decay. I did order a particular snake to help keep it clear. I am guessing it is not 100% clear as I ran hot water through the driver side front after as maintenance and it cleared faster. The outflow water was light brown / grey. I do live on the edge of the country. My suggestion is to add cleaning these drains to your regular semi-annual maintenance routine.
    Speedfreak likes this.
  6. Mar 21, 2023 at 2:10 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Weed eater string works best.
