Sunroof problems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dcam123, Sep 20, 2016.
  1. Sep 21, 2016 at 5:38 AM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Just my opinion, but checking/clearing the drain tubes ought to be part of anyone's regular maintenance if they have a sunroof. Dribble a bit of water into each tube and if it doesn't flow cleanly, clear it out using some moderate thickness weed whacker nylon "wire" or similar.
    I don't know the specific vehicles you cited, so maybe they're worse setups than others, but for most vehicles the problem is solved with the above maintenance.
    Edit: here's an example of the technique: https://www.youtube.com/watch?v=CIaZ_3qMhvM
  2. Sep 21, 2016 at 5:39 AM
    jdiru
    jdiru Well-Known Member
    Jeff
    southern NH
    2016 Taco DCSB TRD OR- MGM
    Toyota's have had sunroof problems for years... I have had a few that leaked, all around the drain tube design... they clog & get kinked.
