Sunshine reflection from the back of the hood?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hate2work, Sep 25, 2008.
  1. Sep 25, 2008 at 5:43 AM
    hate2work
    hate2work [OP] Well-Known Member
    Washington State
    06 standard cab
    I just purchased a bright red 06 reg cab, and when I drive into the sun there is a very bad spot that reflects the sun and almost blinds me.
    It's right at the back of the hood, where that bent/rolled lip is. Do any others have that problem? If so, what is the best fix for it?
    TIA~
  2. Sep 25, 2008 at 5:47 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I personally have never had that problem, although my truck is silver not sure if that would make a difference. You could let her get dirty.
  3. Sep 25, 2008 at 6:20 AM
    OU812
    OU812 ban the term murdered out
    danusa
    Kilroy was here
    13 DblCab LB 4X4
    Nothing yet, brand new!
    Do you have the hood scoop?? I do and it's quite annoying to me but I just wear shades on bright days:cool:
    On the other hand when it's cleaned up and dark out it's really sweet looking to glance at the hood.
  4. Sep 25, 2008 at 7:21 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Just take it off road and get it dirty... glare problem solved :p That being said, my obsidian black access (trd offroad no scoop) doesn't blind me at all even when waxed up. Number of things to that though, sun angle/driving angle. Sitting position, ect... If it's really that bad, I think I stumbled on some covers like the bug-deflector that go over the windshield wipers.... looks retarted imo but it'd block the glare...
  5. Sep 25, 2008 at 7:24 AM
    hate2work
    Washington State
    06 standard cab
    No hood scoop. I suppose I'm gonna have to see if the detail shop can put a black strip across the hood where the reflection is, that should help quite a bit.
  6. Sep 25, 2008 at 7:25 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    what about putting some window tint on that area? It might be cheaper than a pro job.
  7. Sep 25, 2008 at 7:42 AM
    Coreyjon
    Coreyjon Northern Alliance: Airlift Div
    Upstate, Ny
    08 DCab 4X4 SR5 TRD Sport
    iPod Adapter, Bilstein 5100's @ 1.75" front, Wheelers 3-leaf 1.5" + overload rear (2"), custom carrier bearing drop spacers.
    Sun glasses seem like a logical answer here - or like someone else mentioned, change the angle at which you are sitting. dirt works too.
  8. Sep 25, 2008 at 8:20 AM
    hate2work
    Washington State
    06 standard cab
    I wear regular glasses, so sunglasses are an option, but kind of a pain to deal with.
    I've tried changing the angle that I sit, but to no avail, it's just as bad.
    Dirt works? You guys let your trucks get dirty? :D
    Yeah the guy that bought it new had it shined up pretty good, it's gonna take a bit of time for dirt to help. I think I'm gonna have to put some black tape right on the bend, that will help.
  9. Sep 25, 2008 at 8:35 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Don't put tape on it... you don't want it baking into the paint... you really don't want to have to try and clean up the adhesive after. I presume you're probably talking along the lines of electrical tape... a vinal strip would be 'ok' but still... You could just put a little hoola girl where it blinds you :p
  10. Sep 25, 2008 at 8:43 AM
    hate2work
    Washington State
    06 standard cab
    I was thinking of the detail tape they use, maybe they have something wide enough and dull enough to absorb the light instead of reflecting it.
    I do like the idea of the hula girl :)
  11. Sep 26, 2008 at 9:02 PM
    mainerinexile
    mainerinexile Well-Known Member
    central Maine
    2014 SR5 Access cab I4 4x4 5 spd
    Yup, I have the same problem. You are talking about the bent angle on the hood right up close to the windshield. Gives a strip of sunlight reflection so that you can't adjust your sitting location to avoid it. Unnecessary design flaw by Toyota. The Japanese engineers are probably too short to have the problem.
    I think it is only a problem in midsummer, otherwise the sun angle is too low. I put black electrical tape on that part of the hood for a couple of months, and then removed it with no residue.
  12. Sep 26, 2008 at 9:22 PM
    hate2work
    Washington State
    06 standard cab
    Yes, that's exactly where I'm talking about, right up close to the windshield on the hood. A real PITA when the sun's just right :(
  13. Sep 27, 2008 at 7:11 PM
    w8n4mud
    w8n4mud I'm back.
    Albert
    Chula Vista, CA
    2019 Tacoma Off Road DCSB
    Stock. Purchased 2/17/19. Cement!
    Dude I couldn't agree more...sunglasses. I have the same problem. It's the price we pay for being different. LOL.
  14. Sep 27, 2008 at 7:54 PM
    TSUNAMI*22
    TSUNAMI*22 Obama can suck-it
    Stockton, CA
    '07 Standard Cab / White / 2.7 I4
    ScanGuage 2 equipped. Toyota DIY aftermarket Cruise Control mod
    Fighter pilots used to have this problem because glare would obscure their target through the gunsight / windscreen. They fixed it by painting a flat-black (non-glossy) or flat-olive green strip across the top of the cowling from the cockpit to the nose.
    http://www.aviation-history.com/north-american/p51-11a.jpg
    Flat-black won't reflect any glare and will look much better than flat-olive green on red paint.
    My suggestion would be to take your vehicle to a sign shop and have a flat-black vinyl sticker made that can be placed on that flat part of the hood.
    It can be made to shape and it'll look very professional.
    Problem solved.
  15. Sep 27, 2008 at 8:07 PM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Sierra Denali Ultimate, 6.2
    A few additions to make me feel cool.
    Are you only 3' tall?
  16. Sep 27, 2008 at 9:52 PM
    hate2work
    Washington State
    06 standard cab
    That's a pretty f 'ing moronic question. But I'll just consider the source and move along.
  17. Sep 27, 2008 at 9:55 PM
    hate2work
    Washington State
    06 standard cab
    Yep, that's what I'm gonna have to do, put something flat black across there that will absorb the glare. Thanks :)
  18. Sep 27, 2008 at 10:05 PM
    JJ Customs
    Jay
    NV
    "That's a pretty f 'ing moronic question. But I'll just consider the source and move along."
    Well if you had noticed it was a joke! We tend to do that here and you had several answers to your question. If you took it the wrong way I am sorry, oh wait, no you should have gotten the joke. Try taking comments in stride and you will fit in here and get good answers to your questions. It is vital that you don't have a "someones out to get me outlook" here. If you show that you are not able to take a joke you will find it hard to get along. Also as for the "source" (being me) I supose, get to know a person before you judge the source. Thank you and have a nice weekend.
  19. Sep 27, 2008 at 10:06 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    I lol'd.
  20. Sep 27, 2008 at 10:54 PM
    TSUNAMI*22
    Stockton, CA
    You're welcome. :thumbsup:
