SUP (Paddle Board)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by slinkskees, Aug 8, 2018.
  1. Aug 8, 2018 at 1:42 PM
    slinkskees
    slinkskees [OP] Active Member
    2015 Double Cab Tacoma
    Hey everyone! I’m new to TW, but I’ve read many threads over the years when researching anything and everything that has to do with Tacos.
    I figured this would be the place to get some good insight and expertise on the best way to transport my paddle board.
    It’s a 10’6” all around SUP which I recently bought. I used to do lots of snow boarding at Big Bear, but once I moved to PR...well, I can’t find local snow :) I miss getting out on a board so I started researching something I could do almost anywhere and obviously SUP Boarding popped up.
    I went out a few times and liked it so I bought a board.
    My issue is that I don’t feel comfortable transporting it on a soft pad removable roof rack system if I want to go long distances and at the moment I can’t quite afford a nice system.
    Experts, I want your advice!
  2. Aug 9, 2018 at 10:22 AM
    Htnswches
    Htnswches Well-Known Member
    E
    Lost Angels
    2006 Precummer Tacoma
    310,000 and counting
    Welcome to TW. I have no advise as I’m in the same situation and hoping for some solutions. I have an RTT over the bed and a naked roof, 10’ board on a DCSB.....
  3. Aug 9, 2018 at 10:43 AM
    slinkskees
    Hopefully someone comes across the thread and can give some good advice :fingerscrossed::)
  4. Aug 9, 2018 at 11:50 AM
    WhiskeyTaco
    WhiskeyTaco Well-Known Member
    Zach
    Denver, CO
    2011 White Tacoma Access Cab TRD Off Road
    You have a couple options.
    1) If you have a topper, use the rack on top.
    2) if no topper, then you can purchase a bed rack (Thule xsporter, Trac one, cab height steel, etc.)
    3) Use Thule, Yakima or prinsu rack over cab to transport.
    With all these options you'll want to put a barrier between the SUP and the rack, most people use pool noodles or foam.
    The cheapest option would be to find a used bed rack on Craigslist or here
    Good luck
    Apexgigi likes this.
  5. Aug 9, 2018 at 11:52 AM
    slinkskees
    Thanks for your response Zach! Do you have a specific setup?
  6. Aug 9, 2018 at 11:55 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    make a frame out of 2x4s to put in the bed
    can get pallets free to make it and pull out the nails to re use
  7. Aug 9, 2018 at 11:57 AM
    slinkskees
    Hey Knotty! Happen to have any pics of that sort of setup?
  8. Aug 9, 2018 at 11:57 AM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Search for used racks (Yakima or Thule).
    Either of their websites will provide details on what fit kit you will need to mount to your vehicle and the necessary attachments for a SUP.
  9. Aug 9, 2018 at 11:58 AM
    slinkskees
    Hey Zack! Would these be bed racks?
  10. Aug 9, 2018 at 12:00 PM
    WhiskeyTaco
    Zach
    Denver, CO
    I have a camper shell, so I just strap my SUP on top of the bars.
  11. Aug 9, 2018 at 12:01 PM
    slinkskees
    Oh I see. What kind of camper shell?
  12. Aug 9, 2018 at 12:01 PM
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    It really depends on what you are looking for. Thule makes a bed rack in addition to roof racks. Yakima only makes roof racks as far as I know.
  13. Aug 9, 2018 at 12:02 PM
    slinkskees
    I’ll have to do some research and see which would be easiest for me with regards to loading and unloading and securing for longer distances
    stickyTaco likes this.
  14. Aug 9, 2018 at 12:05 PM
    knottyrope
    Knotty
    Bahstun
  15. Aug 9, 2018 at 12:07 PM
    slinkskees
    Thanks Knotty! That looks pretty nice and not too hard to do
  16. Aug 9, 2018 at 12:08 PM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    x2. The easiest route would be a hitch mounted bed extender and lay the sup flat and strap it down using the bed drings. I highly recommend buying a few more d-rings and make a few more tie down points in the bed. There's a recent d-ring post and I've done this recently to my bed. You can also transport it via roof rack just like what you would do with a kayak using J-hooks carrier or even flat on the rack w/o a carrier. Always use a front/rear bow-stern tie downs and like stated by whiskeyTaco, use foam noodles to give some protective cushing to prevent warping your SUP at pressure tie down points.
  17. Aug 9, 2018 at 12:11 PM
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    I ride with the tailgate down and strap the 10ft SUP to the d rings. I also have a tonneau cover that i close on top of it.
  18. Aug 9, 2018 at 12:14 PM
    Miami Chillin
    Miami Chillin Well-Known Member
    DCLB TRD Sport 4x4
    I have a 11'6'' SUP and a DCLB. I just put it in the bed with a cut of a foam noodle protecting the nose and the another noodle cut to slot into the top of the tailgate where the board is laying down on. After that I strap it down. Driven quite a ways like this without an issue.
  19. Aug 9, 2018 at 12:28 PM
    slinkskees
    Are there any front/rear bow-stern tie downs you recommend?
  20. Aug 9, 2018 at 12:29 PM
    slinkskees
    What anchor points do you use to strap it down?
