SUP Paddleboard
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jetspeed, Mar 5, 2019.
  1. Mar 5, 2019 at 8:24 AM
    jetspeed
    jetspeed [OP] Well-Known Member
    MD
    19 TRD Sport DCSB 4x4 Manual Taco
    Getting ready to buy 2 SUP's each a bit over 10' tall. Looking for transport ideas with both gate up and gate down for 2 boards in my short bed Sport.
    I do not have a roof rack and do not want one; bed transport only. I saw a coupe of older threads; but any new info would be great.
    THANKS
  2. Mar 5, 2019 at 8:32 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Hard SUPs or the inflatable semi-rigids? I went with the inflatable just so I could pack them down when I needed to.
    tcjacado likes this.
  3. Mar 5, 2019 at 8:34 AM
    jetspeed
    MD
    Rigid / epoxy
  4. Mar 5, 2019 at 8:35 AM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    I've got inflatable as well. Seemed like transporting the hard one's looked like a pretty big hassle. I also kept it under 10 feet so I don't have to stop at the invasive species inspection each time we go by.
    I think I got mine on an eBay sale for like $200.
    Gunshot-6A likes this.
  5. Mar 5, 2019 at 9:08 AM
    Jaque8
    Jaque8 Well-Known Member
    2017 Inferno TRD OR
    My SUP is 10'6" and I just hang it out the back diagonally, if I'm going on the freeway or long distance I'll put a tie down.
    I've done it with multiple boards as well never had problems. Just put a towel in the front corner where the nose of the board is going so it doesn't rub, I also put a towel on the tailgate so bottom of the board doesn't scrape.
    But I also have a roof rack which is great, OEM rack is like $250 I'd just get one.
  6. Mar 5, 2019 at 9:21 AM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
  7. Mar 5, 2019 at 9:24 AM
    jetspeed
    MD
    I'm thinking the use of pool noodles and heavy blankets at this point. Someone HAS to have a similar set-up.
  8. Mar 5, 2019 at 9:26 AM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    How far are you transporting the SUPs, highway speeds?
  9. Mar 5, 2019 at 9:28 AM
    whoispurplegoo
    whoispurplegoo Well-Known Member
    SE Florida
    2018 MGM Sport 4x4 DCSB
    i use a Rola T3 to transport a 14’ SUP. Runs about $325.
    It’s also easily removable so you don’t have to drive around with it permanently installed.
  10. Mar 5, 2019 at 9:31 AM
    jetspeed
    MD
    25 miles, half at highway speeds.
  11. Mar 5, 2019 at 9:36 AM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    What about after you own them, how far would regular transportation be to use them? Might be worth the expense to invest in a rack system unless you have waterfront property.
  12. Mar 5, 2019 at 9:38 AM
    spyh0p
    spyh0p Silver Surfer
    Gulf Coast
    2019 TRD OFF-ROAD
    Just get a bed extender that goes in the hitch, Harbor freight $59.
  13. Mar 5, 2019 at 9:45 AM
    Tallgrass05
    Tallgrass05 Well-Known Member
    Bed extender, cheap and efficient.
  14. Mar 5, 2019 at 11:11 AM
    sakibomb
    sakibomb Well-Known Member
    Kevin
    DFW Texas
    2016 TRDOR DCSB 6MT
    Dual Batteries Blue Sea Fuse Panel
    I put my 10'6" SUP diagonal in the bed with tailgate down and ratchet strap the end to the rear bed cleats. Never moves.
  15. Mar 5, 2019 at 12:37 PM
    jetspeed
    MD
    I was thinking flip both boards over fin side up and using a ratchet strap across the boards using the vertical SUP fin to keep from sliding aft with the tailgate down. Pool noodles and cheap blankets involved in there somehow.
  16. Mar 5, 2019 at 1:16 PM
    whoispurplegoo
    SE Florida
    you seem pretty dead set on blankets, pool noodles, and just tossing the boards in the bed. are you even considering a bed rack or bed extender?
  17. Mar 5, 2019 at 1:19 PM
    jetspeed
    MD
    I have, just want to keep in simple, fast, and easy.
  18. Mar 5, 2019 at 1:24 PM
    whoispurplegoo
    SE Florida
    get a bed extender. It takes no time to set up and it will keep the boards secure
  19. Mar 5, 2019 at 1:39 PM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Cheap is what I'm hearing.
    Go with your gut and get what you want. If it doesnt work then spend a bit more to get a proper rack.
  20. May 5, 2019 at 5:35 PM
    Ulfr
    Ulfr Well-Known Member
    Tampa, FL
    2019 DCSB 4x4 Manual
    Where did you get an OEM rack for $250?
