Super budget gov't shutdown tacoma lift :)
Discussion in '1st Gen. Tacomas (1995-2004)' started by oldblue1968chevy, Oct 12, 2013.
  1. Oct 12, 2013 at 8:23 AM
    oldblue1968chevy
    oldblue1968chevy [OP] Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    Hey guys quick ? (Trying to do a cheap lift)
    Tried to get someones old spacer lift for free or near free with no luck.
    Found this on the forum : http://www.tacomaworld.com/forum/1st...acer-lift.html
    Then this for the rear:
    (Soft ride for $80)
    http://toyteclifts.3dcartstores.com/...afs_p_303.html
    Or firm ride (I would think would be better/last longer) for $40
    http://toyteclifts.3dcartstores.com/...ide_p_260.html
    Then I would need longer shocks for the rear and new U bolts? Or can I re use my old ones if I can get them off with threads still in good shape? Or are the U bolts actually longer?
    Thanks
    Ps, also would it sit level with a 3" front 2" rear? It will be on a A/T type 31" tire
    __________________
    So $25 for the spacer
    $40-$80 for the AAL (What brand, is the one posted a good one/best one?)
    $? Rear shocks???
    Install (me)
    Alignment $60
  2. Oct 12, 2013 at 9:45 AM
    604YOTA
    604YOTA Well-Known Member
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    Grey wire mod, eibach, 5100's & 5125's, ome Dakar leafs, 1.25 rear shackle, Gibson exhaust, ram air intake, throttle body spacer, boot slide mod, poly bushing kit, extended brake lines.
    Your u bolts might be too short. You will need new rear shocks...
    My advice ..from someone who has done it your way. Save your money and get some 5100 front shocks and new coils. Might cost a bit more. Cuz pucks suck big time
